Question about Sony Televison & Video
Two TVs go on with one remote
Have two Sony TVs one above the other in a cabinet. One is a new LCD flat panel,other is a conventional tube set about 8 years old. Both remotes are on the same frequency--they are both Sony. So when I want to turn on the lower screen LCD, the upper TV goes on too. The remotes don't have provsions for multiple frequencies that I can see. Any ideas? I would say the sensors are about 30 inches apart.
    Sergeant:
  • Sony Expert
  • 296 Answers
I am sorry my friend, SONY TV uses the same remote control code, there is no way to change it.
Posted on Aug 02, 2017
3 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: Sony remote control conflict
As Sony has same remote frequency for its TVs so option is left to unplug that tv which you don't want to power up or put piece of paper tape on front of remote sensor in tv and make it blind for IR waves.
No way to set both tv on different remote frequencies.
Posted on Sep 24, 2008
welcomejee
  • 10594 Answers
SOURCE: Toshiba TV Model No.
As you already an experienced tech, picture rolling top to bottom happens in two conditions, either video signal level is weak/ less than standard or video signal is missing vertical sync signal.
Please check does picture roll fast in all inputs of tv?
If yes, then video processor seems bad that is mounted on main board and main board will be replaced and if any specific input gives rolling picture and other input is fine then check bad input's buffer parts like chip resistors, chip capacitors and buffer transistors that might be causing low video signal level.
Hope these info will help you.
Thanks.
Posted on Oct 30, 2010
Why does the picture only fill the screen if I zoom in?
Hi Anonymous,
Please use the P SIZE key on the remote control and choose the picture of your liking. It will not be as we are used to see on the conventional Picture Tube TVs.
Dec 04, 2015 | Televison & Video
How to control my cable box with the tv control
hello!
refer to your TVs owners manual. You will find codes for common set top boxes there. all the new TV remotes are universal. If you see "cable" or "cbl" button on remote, you will be able to do so. Worst case scenario: you need to buy universal remote or use your cable box's remote to control basic functions on TV. Codes for TVs are included with cable box's remote control. Or, you can call your provider and ask for "Sony Bravia"codes. If you have a satellite box, codes are supplied right inside "setup" menu of the box.
Good luck,
Alex.
Jan 30, 2012 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
I am looking for the Sky remote code for a Sony KDL-40V2000 TV can you please help.
Sky don't have a specific code listed for this model yet, so the first thing to do is try the Generic Sony codes first. These are:
1679, 1533, 0678, 0681
These codes are for a "Rev 8" Sky remote. If the above codes don't work or you need further assistance, please post back and I will investigate further. When posting back, please state which Sky remote version you have and whether it is also Standard Sky, Sky+ or Sky HD. The version number can be found on a sticker inside the battery compartment. RC1600/00 is the old original. Newer remotes will also have either "Rev 4", "Rev 6" or "Rev 8" on the sticker.
Please note that Sky remotes wont work with all TVs. I've been informed that a new revision of the Sky remote is due soon but I have been unable to verify this.
Hope this helps. Please post back with the information requested above if you need further assistance.
Regards,
BElectric
Nov 21, 2010 | Televison & Video
There is a flashing red light on the bottom of the tv, and it only turns on for a second then turns itself back off...help
Then the problem is in the main power supply section and will need to be analysed by a technician; if you can find one for conventional TVs in your area. We are becoming rare.
If the set had been otherwise OK before this failure, I would recommend having it repaired since it will probably outlast any new flat panel set you might buy, they are not very reliable and service for them is expensive.
You can check for yourself by doing a search here at Fixya on 'LCD TV' and you will see a variety of makes and models with problems, many of them only a year or two old.
May 24, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture on tv screen is smaller & concave on all four sides compared to the edge of the screen.
well just tube only has 80 tos hours on thes eok time for new tv lcd sharp samsung are best on market for pcie plamsa tvs also nice in those 2 brands i would say time t o upgrade u love it those parts not avb anymore u will have hell of time fixing it if i can fid u parts on top of it new lcd flats so much more cleaner better and save 500 watts a day pays itself ok
Oct 06, 2008 | Sony KV-36FS12 36" TV
Sep 24, 2008 | Televison & Video
Programing Remote
Most Polaroid flat-screen TVs won't program to the Uverse remotes. Try buying a different universal remote that shows coding for both Uverse and Polaroid.
Apr 19, 2008 | LG 47LC7DF 47 in. LCD HDTV
LCD Durability?
The answer is Yes definately to you question. The reason being is easy. The image cannot be burnt into the phospor of the LCD SET because it is "Liquid crystal Display which is backlit and is very durable. Just look at all the laptops out there and how reliable they are. All LCD. Also lighter, but dimmer then Plasma. I hope this helps you and your parents for some clairification. Good luck gaming. And have fun... Jay the GURU
Sep 11, 2007 | Sanyo DP32746 32 in. LCD Television
Televison & Video Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
