Question about Microsoft Xbox 360 Console
My xbox 360 wont load any games.
When I try to play a game, my xbox stops loading the game and starts to make some weird noises.
  • 7 more comments
  • ShaunB Sep 26, 2008
    Mine does the same thing when i try too play a game on my xbox
  • t carrots Sep 26, 2008
    When i enter a disk at the Xbox 360 Dashboard, it makes a weird noise and the Xbox doesn't read the disk
  • 3RDSREET Sep 26, 2008
    my 360 doesnt load anything the first time except scarface,everyting else i have to turn it on and off up to 30 times.i get the play dvd message.if it doesnt whir and click i know its not going to play.
  • Anonymous Dec 22, 2008
    my far cry 2 wont load so i can play can you help
  • R1Dragger Feb 15, 2009
    I can't load Far Cry 2 after I'm at 80% done. I just got this xbox back from the ring of death recall.
  • 3RDSREET Feb 16, 2009
    if you hear clicking or a grinding noise when loadingthe box is tearing up your disc and soon you will get the unplayable disc message.i have just e-mailed micro soft about this problem.it will take a day or two to get a reply,when i do i will post it here.
  • nwjones42097 Feb 16, 2009
    mine starts grinding when i put in my game and says game is not readable....and there looks like a ring has been scratched around my game ........i got this game for christmas, so its only 2 mths old........
  • zacness02115 Apr 01, 2009
    my xbox goes staight to dashboard and when i click play game it continues to say 'open tray'. It also make a buzzing noise
  • xboxlegend Apr 09, 2009
    yesterday my 360 was fine went to sleep got on later after i woke up and it just totally ignores the disc i put in and says open/close tray and dosnt make a grinding noise but like a trying to pull tray in even though it is noise
I had this same problem on my 360, the disc drive is very sensitive to dust, cig. smoke, pet hair, etc... so i took the case off, took out the disc drive, and opened up the disc drive and cleaned the little lazer optic thing(looks just like what reads a cd in a cd player) very gently with a q-tip dipped in rubbing alcohol, and used some canned air to blow all the dust and pet hair off of all of the internal parts, not only disc drive but fans, heat sinks, mother board etc. then put it all back together and tried it out and presto, good as new!! two months later and it still reads all discs first try every time. no more opening and closing the tray for twenty mins. till it reads the game disc!! Try this out if your warranty is over!!(this will void the warranty) Worked for me and saved me a bundle!!!
Posted on Jan 19, 2011
It has happened to me twice and unfortunately the only way to solve it is sending the device to msoft. You can do this either through the phone or using the xbox.com site.
The second time it happened to me the machine was out the warranty, they offer me to pay 87 € to fix it and extended the warranty for an extra year after it.
At the end when I send it the second time they just sent me a refurbished one to avoid the problem to happen in the future.
Posted on Feb 15, 2009
I rang microsoft today about it and they said i would have to sent it away to be repaired. If any of you do want to ring microsoft the number will be on the back of the getting started manual. They will ask for your serial number (its located on the back of your console where the wreless adapter is) and they will also ask you, your contact details and other details aswell
Posted on Sep 27, 2008
I installed homefront onto my hard drive to make my xbox 360 quieter but it doesnt say 'play from hard drive' and so i just select 'play game' and then it makes the same amount of noise....
You don't -play- the game from the harddrive, and nor does it make less noise if you install it.
When you install a game to your harddrive, it normally makes the game quicker to load, not for older games, I think Homefront is a "newer" game.
The benefits of installing the game is that your optical reader is less in use, that the game saves and loads quicklier and is normally better performance in-game.
Sep 25, 2011 | THQ Homefront for Xbox 360
My 360 plays all games except this one
Check if your new cd has an uneven surface , like it's bent . Is the grinding noise occuring for all the other games ?, if yes you should check your Xbox's CD reader head .
Oct 04, 2009 | Microsoft Halo 3 for Xbox 360
Saints row 2 loading problem
try and save the game to your Xbox360 harddrive(HDD) and then run it off that?
Sep 26, 2009 | THQ Saints Row for Xbox 360
Xbox 360 will sometimes not load the game it makes weird noise like it is trying to load the game but the it says open tray
sounds like your cd player is dieing try a dif game and if it works on the first try its the cd if it takes more then one its the cd player
Jun 26, 2009 | Microsoft Xbox 360 Console
Xbox WONT read call of duty 4
If you don't have the tools to open your 360 go to best buy or an office supply store and get a can of compressed air and blow the dust out of the dvd drive. If that doesn't work then the lens needs to be cleaned with a q-tip and alcohol. This has worked for me on numerous occasions.
Jun 02, 2009 | Microsoft Xbox 360 Console
My xbox 360 premiun will not load any games
Send it back... hopefully u get the new mobo, this will stop the problems (cause = overheating)
http://forums.xbox-scene.com/index.php?showtopic=484726 - Contact details
Dec 22, 2008 | Microsoft Xbox 360 Console
Halo 3 not letting me play campaign
redownload all maps and blow air into inside of xbox or clean disk and check for scratches. if that doesn't work you were either banned or need a new game data will be same disk might be ****.!!
Oct 16, 2008 | Microsoft Halo 3 for Xbox 360
Disc wont play
i have the same prob my solution get a sony
Jul 01, 2008 | Microsoft Xbox 360 Console
Xbox 360
That's weird, if the Xbox needs a driver it should be installed or come on a Cd.
So the games don't play ?
Call support and threaten that you'll bring it back, it'll get them to help better.
Dec 21, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
1,368 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
