Question about Canon IMAGERUNNER 2230 Copier
ImageRunner 2230 Error E000001-0002
Hi
I have canon ImageRunner 2230 and failed in this error code E000001-0002
I change the fuser unit but continue fail E000001-0002. I like now a reset this condition. Thank.
  • neblovely Oct 29, 2008
    2230 Error E000001-0002 problem i like to know what is wrong with it?? please help me
  • Jesus Muganza Apr 27, 2013
    how to reset codename canon ir2230
Canon copier e000001-0002
Posted on May 11, 2009
  • 35 Answers
ImageRunner 2230 Error E000001-0002 - getfile.asp?rid=1258 August 31, 2007 getfile.asp?rid=3215 Product : imageRUNNER 2230 / 2270 / 2830 / 2870 / 3025 / 3030 / 3035 / 3045 / 3530 / 3570 / 4570 Title : E001 Error Code That is Not Resetable Error :
When the machine powers up the E001 error code is displayed but cannot be reset. (Note: The reset procedure for an E001 code is COPIER>FUNCTION>CLEAR>ERR)
Workaround :
In this case, the Main Power Supply PCB Assembly was replaced. The machine was powered up and the E001 code was able to be reset. The part number for the Main Power Supply Assembly is FM2-0260-000.
Remember, if the fixing unit circuitry has an open or a short, the code may not reset. Be sure to confirm the fixing unit wiring and try resetting the code before replacing the Main Power Supply Assembly. Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
Posted on Nov 09, 2008
Error code E000000-0002
try this solution: enter service mode by pressing *(additional function) then2 and 8 together and then again * select copier on screen>function>clear>error>ok. turn off the machine and re-start.if error appears again then there is faulty heater element in fuser unit and u will need a technician.
Jan 28, 2011 | Canon IMAGERUNNER 2230 Copier
My canon image runner 2230 photo copier showing the error code E000002-0000 at start up.
Jan 18, 2011 | Canon IMAGERUNNER 2230 Copier
Replaced toner cartridge in our cannon imagerunner 2230, but it still flashes error and will not reset back to copy mode. thanks
What is the error code that is Flashing??? That will till us what is wrong.... They range from E000 to E900, you guess is as good as mine
Mar 12, 2010 | Canon IMAGERUNNER 2230 Copier
Image runner 210s error code E000. What to do?
Your problem in the fuser unit.Check and clean the fuser unit component parts:thermistors,thermofuses,verify the continuity of the heater lamp,and verify the upper and lower fuser roller mechanical.
Nov 24, 2009 | Canon imageRUNNER 210S Copier
HAVE CANON IR C6800 WITH THE FOLLOWING ERROR CODE... E000001-00ff
moz-screenshot.jpgmoz-screenshot-1.jpgIt is a Fuser error code .
Could be a poor connection with the draw connector on fixing feeder unit.
Try shimming all three connectors on the fuser draw side can resolve the issue. Another thing to check is the upper fuser roller for flat spots this can also cause fuser error codes
May 07, 2009 | Canon imageRUNNER C6800 Copier
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
Canon imagerunner c3220
Were the heaters at fault. It is more like a thermister problem. Replace the thermisters, both. And I would also change the thermostat as well. When you are sure thatyou have removed the faulty unit reset by doing the following.. service mode/copier/function/clear/error followed byswitching the machine off and turn on again.
Oct 31, 2008 | Canon imageRUNNER C3220 Color Copier
5,009 people viewed this question
old marine
old marine
Corne Viljoen
