Question about Compaq Armada M700 Notebook
Error reading hard drive laptop Armada M700
When I start the laptop, I received a msg that said that there is an error of hard drive reading... push Ctrl + Alt + Del to re-start...but after that I return to the same screen
  • felcen Sep 26, 2008
    Thanks!!
I have a problems
Posted on Oct 04, 2008
    Scholar:
  • 188 Answers
It's sadly possible your hard drive is bad or corrupted. Can you boot from a CD? Or a floppy disk? You could run diagnostics on it from a CD. If you don't have one available check the HP website for support.
Posted on Sep 24, 2008
SOURCE:
When a compaq armada m700 laptop is showing non-system disk or disk error replace and strike any key when ready
this usually happens when the computer is trying to boot from a disk that isn't a valid boot disk.
if you have a floppy drive plugged into the multibay and a floppy in the drive, try removing the floppy.
if there is no floppy involved, try to boot from your system recovery disks, as it's likely that the boot record on the hard drive will need repaired. your system recovery disks should walk you through the process.
Nov 03, 2011 | Compaq Armada M700 Notebook
101-I/O ROM ERROR. F12 NETWORK SERVICE BOOT. SEEMINGLY THE SAME PROBLEM THAT JOSHUA HAD. CAN YOU HELP?
I/O error could be the hard drive or the driver on the mainboard
take out the hard drive and see if you still get the I/O error
if you dont get the I/O error than its the Hard Drive
hope it will help
Aug 23, 2010 | Compaq Armada M700 Notebook
What hardrive for my armada M700?
Hard Drive Installation Instructions 40 gig IDE DRIVE
  1. Shut down the computer and remove Battery Pack and AC adapter.
  2. Locate Hard Drive compartment on the front panel, just left of the head phone jack.
  3. Turn Notebook upside down.
  4. Remove the one torx screw that is securing the hard drive. (A security screwdriver was provided with the computer.)
  5. Push down on the hard drive bezel on the front of the hard drive.
  6. Lift the bezel up 90 degrees to create a handle. Pull the hard drive out of the hard drive bay.
  7. Remove the 4 black screws at each corner and lift off the black tray.
  8. Gently remove the silver bracket and connector.
  9. Place connector on new hard drive.
  10. Place the black tray on the HDD. When looking at the hard drive with the label up, the black bezel goes along the left side of the hard drive.
  11. Replace the 4 black screws from step 7.
  12. With the hard drive bezel pulled down, slide the hard drive into the hard drive bay.
  13. Push up on the hard drive bezel to secure the hard drive in the bay.
  14. Secure the hard drive bay by replacing the screw from step 4.
  15. Replace the battery pack and all cables
Aug 08, 2009 | Compaq Armada M700 Notebook
101-I/O ROM error and 162-system option not set
sound slike theres a fault with a cd dvd drive or that it's disconnected, possibly the driver is corrupt
Jun 08, 2009 | Compaq Armada M700 Notebook
Ticking noise and error message
usually the only thing that causes a "ticking" sound is a defective hard drive. Backup your data and replace the drive before it permanently fails and your data becomes unrecoverable.
Sep 27, 2008 | Compaq Armada M700 Notebook
Fujitsu Drive installation on Armada M700 Laptop
I would stay away from fujitsu hard drives. They are complete trash. I would stick with either Seagate Western Digital or IBM. I have the hitachi that came with the machine and although it is slow it still works after over 10 years. I would like to know more about your situation if you need help installing it tell me what it is doing.
Sep 17, 2008 | Compaq Armada M700 Notebook
Error messages
You may want to make sure it is the right type, this laptop take the older ide hard drive.
Sep 03, 2008 | Compaq Armada M700 Notebook
Hard drive
The Compaq Armada M700 laptop has a PATA (or IDE) hard drive verus a SATA hard drive which is the newer standard. This computer's factory hard drive could not have been any larger than 20 GBs. However, one this size is not readily available anymore so you'll have to go larger. Here is the type of hard drive that you need: http://www.bestbuy.com/site/olspage.jsp?skuId=8692373&type=product&id=1198286608739
Apr 08, 2008 | Compaq Armada M700 Notebook
Will not read DVD-ROM
Computer DVD Support.
Good Luck, Please dont for get to Vote, Follow instructions.Thank you.
Dec 26, 2007 | Compaq Armada M700 Notebook
My laptop armada m700 gets no power
the hard drive was damaged. Inside the drive, the tiny moving head took the hit. They really are not designed to take shocks like that. Many laptop mfgrs offer "industrial" duty laptops that have on-board shock absorption suspension for hard drives.
Aug 26, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700 Notebook Logo
104 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
