Question about Philips VR550 VHS VCR
Blown fuse/ power supply vr550
Fuse keeps blowing at power inlet a flash appears on what I think is a rectifier diode/transistor
  • 1 more comment
  • Del bone Sep 24, 2008
    vcr only used twice
    thanks for info .Please advise on component and spec. can solder this in thanks.Del bone
    PS what is fuse value i.e.milamps
    Del bone
Could not locate heatsink previously mentioned,only a "v" shaped slot beneath tranistor close to transformer,could you please furnish information on transistor so that I can replace it.
Delbone
Posted on Sep 29, 2008
Could not locate heatsink, component in question is located over a small "v" slot about 1/2 inch long in front of transformer, hope this helps to locate said component.
Del bone
Posted on Sep 27, 2008
  • 4,234 Answers
There is a small glass fuse there as well. These units have aswitch mode power supply and the transistor that is attached to the heatsink sometimes gets shorted. This is the most likely problem. If you feel comfortable working on these and can solder, let me know and I'll provide more detailed information.
Dan
Posted on Sep 24, 2008
  • ABRsvcs Sep 24, 2008
    The fuse is usually a 3.15 Amp fuse (GMA type). I need to look up the transistor.
    Dan
NAD Electronics 7020e 4A fuse keeps blowing on power up
Well you are on the right course. I suspect you think the problem is in the power supply and it's probably not. I think that what's gone is either a transistor (or more) or an IC amp - if it uses one - on the main power amp stage. Look at the devices on the heat sink. I think that's where you will find your shorted device.
Nov 28, 2012 | Audio Players & Recorders
JVC RX 505v stereo receiver keeps blowing fuses. Replaced fuse with specified rating (125v 5 Amp) but still keeps blowing fuse. Fuse appears black inside and I see a flash when I apply power. Can...
The likely cause of this is a dead short in the power supply. I don't receal the specifics of this unit, but there should be a set of four(4) diodes or a single bridge rectifier in the main power supply area. Check this/these for a direct short using a diode checker. Other than that, the output transistors being shorted can cause hte same symptom. Without seeing the actual unit, I can not tell for sure. If you know how, check the output transistors as well. Report your results here.
Dan
Nov 30, 2010 | Audio Players & Recorders
Keeps on blowing fuse
Hello
If fuse blows off repetedly, it shows that there is a direct short inside the power supply section. You just check the mains rectifier diodes for short. iIf a rectifier stack is used desolder it out and check for short. In some sansui sets, ther is a metal oxide variste connected across the supply line inside directly. It is for line spike suppression and an overvoltage protection. If any of the above appears on the power line, the varistor will get shorted, and the fuse will go out, to prevent further damage to the circuits. Check that varistor for short. Check the resistance across main filter capacitor for any direct short. If it seems shorted, check the switching transistor for collectror to emitter leak, Resolder it out and check. These are the main reasons for blowing fuse. If the switching transistor has got leaked, you must check the entire SMPS control section, especially in case of used zener diodes, before replaceing a new transistor. OK.
If you wants anu further assistance, inform me through Fixya. Ok.
Nov 05, 2010 | SansuiS2746 TV
A small 2.5 amp fuse keeps blowing. It is located at the back of the unit just after the ac inlet
When a fuse blows suspect an overload in the power supply or power amp section.
For culprits in the power supply check the transformer, large capacitors, rectifier, voltage control semi-conductors, diodes.
In the amp section any semi-conductor on the heat-sink.
Semi-conductors - transistors and IC's are the biggest cause of fuse blowing. They become short-circuit acting like a piece of wire!
Because of this transistors and diodes are easy to spot with an Ohm Meter, as it will be like you have just touched the probes together.
Very often they have holes, or damage, or have burnt up with this kind of fault.
If it is a fault on the main amp section, check your speaker wiring as the + & - wires could have touched to cause it.
Apr 18, 2010 | Pioneer A509R Amplifier
Samick sga 120 amp keeps blowing fuses. replaced all rectifier diodes and tranformer seems to be working fine. any suggestions?
Fuse blowing is due to excessive current drain and the the first clue is the blown fuse itself. If the fuse blows with a flash a bang and splatters copper across the inside of the glass you have a hard blow caused by a dead short on the power supply, check for power switch flashing over internaly. Short circuit main filter capacitors. Shorted turns in power transformer primary winding. If fuse just separates check for short on output transistors C to E. Try isolating fault by disconnecting LT pos/neg supplies to output stage. Also check for partial shorts on speakers and speaker wires using an analog ohm meter on low ohms setting.
Mar 27, 2010 | Audio Players & Recorders
MAIN INPUT FUSE KEEPS BLOWING
theres a shortage in the circuit try check the rectifier diodes at primary power supply section, not dangerous to little knowledge,refer to a qualified service technician
Jan 03, 2010 | Samsung TXP3275H 32" TV
Proscan lcd tv model 26lb30h blows fuse on power board
If the fuse blows again after replacing it, there's a shorted diode, bridge rectifier, capacitor or transistor in the power supply.
I repair these power supplies. If you need furhter assistance, write to jah2mil@hotmail.com
Jun 20, 2009 | Proscan 26LB30H 26 in. LCD TV
JVC RX-318 keeps blowing fuses
could be several things, speaker wires touching,shorted output transistors, a shorted rectifier diode,bad filter caps in the power supply,those are the most common
Jan 06, 2009 | JVC RX-318 Receiver
No Power and Blown Fuse
This often indicates either a power supply problem or shorted output transistors. In either case, the unit will require replacement parts. If you have a multi-meter that can check diodes, check the rectifier diodes or bridge rectifier in the power supply first. If those are OK, next check the output transistors. If you don't have access to the meter, expect a parts cost in the $15-$25 range plus the local labor rate for the repair. This should not be a difficult repair for any shop that does audio repair.
Dan
Nov 12, 2008 | Sony STR-DE595 5-Channel Amplifier
Have a nearly 30-year old Akai stereo receiver AA-R30. Power light just stopped turning on. Opened up case and found main fuse between AC power cord and power transformer blown. When I replace the fuse,...
Look for shorted output transistors or possibly shorted rectifier diodes. An immediate fuse blowing up usually means that the power supply is the problem. Keep us posted.
Dan
Apr 08, 2008 | Audio Players & Recorders
Philips VR550 VHS VCR Logo
268 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
