Question about Nikon Coolpix L11 Digital Camera
HEEEEELPPPP No matter what batteries I put in, my camera will not stay on.... also I cannot find an output for an ac adapter
  • 1 more comment
  • SARAINDUSTRY Sep 24, 2008
    Is it possible that my camera did not come with an ac output? I have checked under the hood of everything and my manual says it is optional? However it really does not make sense that it would not have one..
    No corrosion or rust it is a nikon l11.. yeah not seeing an ac output anywhere
  • 57 Answers
Sometimes the AC output connection is covered by a plastic cover. Just peel back the cover and you will see a Firewire type connection more then likely.
Posted on Sep 24, 2008
  • fixyadude1
    fixyadude1 Sep 24, 2008
    What is the model number of the Camera?
    It is possibly, but pretty rare for it not to come with a ac output.
    Also, I know some cameras use certain kinds of batteries. Like Panasonic us OxiRide batteries. You can also try the rechargeables just get a strong higher rated rechargeable.
    Are the connections that are metal inside the battery area rusted / corroded?
  • fixyadude1
    After reading the reviews it does not come standard with AC Output. Also it does not recommend using any special batteries, just AA's.
    Sorry couldn't be much more of a help.
The AC power indicator light does not torn on when the adapter is plugged. The adapter was tested and it puts out 19 volts. At first the prolem was intermittant, but now it is not working. The battery...
The AC adapter have two measure:
Output volt: 19 volts
Amp:
the Volt output can be tested and show 19V, but can`t leave the correct Amper.
I see these failure in anothers AC adapter. I measure the Volt and show 12 V, but don`t work the survellaince camera. I recommedn replace the adapter
Sep 14, 2011 | Computers & Internet
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
Advent laptop will not turn on
Test your battery on another similar laptop or use a known good working battery just to help rule the batter out. If it does not power ON using AC adapter, it could be something on the motherboard or your AC adapter. I suggest you first check the output of your AC adapter using a multimeter. The voltage reading you get should equal the one on the adapter's label.
Also check DC connection (where output jack of adapter plugs into the laptop) as sometimes it breaks and does not make contact with the motherboard.
And lastly may be you can try a power drain... remove the battery and unplug ac adapter. Press and hole power ON button for 30secs at least. Put back the battery and plug back AC. Power ON as normal.
Jul 28, 2011 | Computers & Internet
My Kodak Easyshare V1233 will only power up when plugged into the wall charger. Even after staying on the charger it will not power on unless plugged in.
Kodak has 3 types of charger that can be connected to a wall socket
USB AC Adapter - is especially useful when traveling, away from your computer, or just plain on-the-go. Connect your camera's USB cable to the adapter and plug it into a wall outlet to conveniently charge your camera.
5V AC Adapter - Provides in-camera charging for all KODAK EASYSHARE M and V Series Digital Cameras
Input: AC 100-240 V 50/60 Hz Output : DC 5.0 V
3V AC Adapter - Provides direct power to your camera but it will not charge the camera battery
Input: AC 100-240 V 50/60 Hz Output : DC 3.0 V
* You need to check the type of adapter your using. If your using the 5V AC adapter or USB adapter and the camera won't charge the battery contact kodak support line 1 800 235 6325 (23KODAK) for possible repair.
Nov 16, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Lost ac power adapter ac cord panasonic sdr-s7 camcorder
Go to Radio Shack, bring your camera, and they will sell you an AC adapter part number: 273-1696 for $30.
May 05, 2009 | Panasonic SDR-S7K Flash Media Camcorder
How do i know if my battery is being charged in my camera
The AC adapter does not affect the battery in any way. You use the AC adapter as an alternate power source to power the camera. In order to charge the battery you need to remove it from the camera and use the charger that came with the camera.
Mar 11, 2009 | Olympus FE-220 Digital Camera
The screen is not going on ? its black and when i turn it on only the lens part goes on and when i turn it off its stays the same way ? so wat should i do ?
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Oct 10, 2008 | Cameras
Batteries AND ac adapter?
Make sure the ac adaptor ius the right polarity for the camera, negative outside plug and positive centre,also make sure the voltage output of the charger is correct 5 volts dc.You do not need batteries as well as the charger.
Sep 04, 2008 | Toshiba PDR-M60 Digital Camera
Camera lense
There is a very very easy way to fix this problem..
This can happen if...
1.) If the battery dies when the camera lens is open (and you close it manually, or sometimes, even if you dont.)
2.) If you used a AC adapter with too much voltage or not enough. (this can happen even if you used the correct voltage, refrain from using AC adapters at all)
... all together its ethier a voltage or camera lens problem...
TIPS:
..to fix this...
Do as i say..
1.) Remove battery
or...
or...
5.) Turn it on.
Hopefully all this information helped,
May 05, 2008 | Minolta Vectis 2000 APS APS Point and...
A/C adapter
The camera should be fully functional with just the AC adapter. I hope you're using the Olympus adapter and not a substitute. Some substitutes will work ok but others can cause problems. The AC adapter output should be 6.5 volts at 2000 ma (2 amps).
Sep 06, 2005 | Olympus Camedia C-2020 Zoom Digital Camera
Nikon Coolpix L11 Digital Camera Logo
41 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
