Question about HP Computers & Internet
After having computer on for a while I get a notice comes up which says `input not supported`which I do not understand
  • 57 Answers
Sounds like one of the devices connected to the computer might need a update firmware or driver update.
Posted on Sep 24, 2008
I WOULD LIKE TO UPGRADE THE FIRMWARE ON MY SONY KDL40EX400 LCD TV.I BOUGHT THE ?FLASH DRIVE FOR IT. HOW DO I DOWNLOAD THE INFORMATION ON TO IT?
You must go to the Sony website and answer the questions about your TV. Model number etc. Then go to support and input your model again. Look for software/firmware upgrade and it should take you to the firmware upgrade and download for your Model number. Download the firmware upgrade "INSTRUCTIONS and the firmware to your computer. Then plug in a blank formatted USB flash drive into your computer and transfer both the instructions and the firmware files to the flash drive. Be sure to unzip the firmware files on the flash drive. Print the firmware upgrade instructions so you can have them there when you are ready.Special Notice!!! Read and really understand the instructions and follow them to the tee. Do not power off the TV or unplug the flash drive while the TV is upgrading the firmware. Let the TV finish.
Nov 11, 2017 | Sony Televison & Video
How to source AV Input on remote
Search Results
    How do I change the input on my television? ' FAQ ' Cogeco ...
    https://www.cogeco.ca/.../how-do-i-change-the-input-on-my-tele...
    CogecoClick on the TV button near the top of the remote. Click on the video source button on the bottom left corner of the remote. Using the arrow keys to highlight/select the inputyou want. Some televisions may require pressing the source button multiple times to change the inputs.
    Understanding Inputs - Harmony Support - MyHarmony
    https://support.myharmony.com/.../understanding-different-input-changi...
    Televisions, AV receivers, soundbars and other home electronic devices switch ...Devices with toggle (or cycle) inputs have a single button on their remote that ... In the below example, you would press the Source button to bring up a list of ...
    Changing AV input on TV using Sky remote ' AVForums
    www.avforums.com > ... > Satellite TV, Sky TV & FreeSat
    Changing AV input on TV using Sky remote. Discussion in 'Satellite TV, Sky TV ...VSX-924 LG simplink changing AV source to TV. Posted By djrobmac In AV ...
    Selecting the DVD, VCR, Game Console, HDTV, Camera, or ...
Feb 08, 2016 | Venturer KLV39150 15" Under Cabinet LCD TV...
Hi, I connect my samsung tv to my pc with vga wire, I can't get the volume to work. can you help me please?
If I understand you correctly, the sound from the computer is not passed through the VGA cable.
You will have to connect the line out from your computer to a sound input on the TV. Sound is supported via RCA jacks or on some TV's the Scart plug.
Mar 13, 2015 | Samsung Computers & Internet
My problem is getting a "This signal is not supported message" on an HDMI input into a Pioneer PDPR05G media receiver.
No need to understand - just read the message, It clearly states that the unit will not accept that particular signal because its electronics are not configured to deal with it. And that is it - end of story.
Basically, you cannot force a square peg into a round hole.
Mar 13, 2017 | Pioneer Televison & Video
When switching ford one user to another a input not supported
You get input not supported because the another user had set the video resolution too high for the monitor to display. Try looking into the resolution setting.
Mar 26, 2010 | Computers & Internet
During setup, got a "INput not supported" message
Reboot the computer and enter into Safe Mode through pressing F8 repeatedly on the keyboard.
If Windows will not come up, then you have to access the system through system restore.
In windows xp, it's c:\windows\system32\restore\rstrui.exe
In windows vista, it's c:\windows\system32\restore\rstrui.exe
This is done through Safe Mode with command prompt or command prompt; depending on the operating system.
Aug 08, 2009 | Acer AL2016W 20" LCD Monitor
Input not supported?
Chances are your Winders resolution is not supported. Start Winders in "Safe Mode" and reduce the resolution on the monitor.
You can do this by right clicking the desktop, selecting properties, Settings tab. Adjust the slider to a lower resolution. Also, be aware that flat panel LCD monitors to not use refresh rates the same way the old CRT monitors did. Look in the manual that came with your monitor and find the "Native Resolution" for it. This will tell you the optimal settings for resolution and refresh rate. If the rate is set improperly, you'll get a very fuzzy output. If it is too far out of whack, you'll get nothing but an error message like you are getting now.
Jun 06, 2008 | Acer AL1716 17" LCD Monitor
EMU 1616m (cardbus) not offerring its input sources to Reaper
While you probably solved this already here goes. I'm not familiar with reaper but most audio recording software can select between using windows wdm & ASIO. If you aren't set to ASIO you won't be able to see the Hi-Z (Dock A/Dock B) inputs. It looks like Reaper supports ASIO so that should be fine. If though you are using a program that doesn't support ASIO you need to use the EMU patchmix and 'patch' the input through to a 'wave' channel.
Mar 19, 2008 | E-Mu 1616M Sound Card
Sharp LC30HV4U
YOU CAN USE IT AS A COMPUTER MONITOR. WITH THE DVI CABLE.
DON.
Oct 05, 2007 | Computers & Internet
VGA Input
If it says no support then it can't read the computer. There is no way around this unless you have a RGB (this is a computer input port) input port on the TV
Jul 10, 2017 | Polaroid FLM-2625 26 in. HD-Ready LCD...
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
