PCI express fire wire card driver for Vista
Ive ppurchased your hardware. Do you have the latest driver?
5 Suggested Answers
iqbal_del
  • 652 Answers
SOURCE: USB 2 PCI card installation on IBM NetVista with MS Vista
Lucy,
USB 2.0 cards require 2 IRQs.
  • 1 IRQ supports USB 1.1
  • and the other the Enhanced (USB 2.0) controller.
Installing the USB 2.0 card in a slot that does NOT share an IRQ or shares an IRQ with onboard USB produces the best result. Consult your motherboard manual or online guide to determine which PCI slot is best for you.
You should also try disabling the on board USB support from BIOS setup.
Thanks
Iqbal
Posted on Apr 28, 2008
JohnE5
  • 34 Answers
SOURCE: Acer AM5100-e5311a - Does it support PCI-Express v2.0?
PCI-E is backwards convertible with any other version. Don't worry about mixing versions up. Instead ensure you select the right size. x 16 is the standard right now. Just pick up any card that is a x16 and you'll be fine.
Posted on Nov 16, 2008
  • 77 Answers
SOURCE: more compatibility problems ?
what you will need to do is accertain which cpu format you have in your machine and find out if you have pcie 1 or 2
regards rich
Posted on Feb 24, 2009
  • 77 Answers
SOURCE: upgrade compatibility continued
hiya
as this pc is skt 775 and has dual core support then it is quite likely that the e5200 will work but may need a bios update to support this cpu...
just goto dells site and choose the pc u have and select drivers then download the lastest bios, transfer it to the dell pc run it as its a self extractor system will reboot perform the update then bobs ya uncle.......pop in new cpu and hey presto cheapo ugrado
#and as for the graphics card you will need to accertain which pcie version u have as most dell pc's only have pcie v1 so wont be able to handle the newer gpu's on the market.......
hope this helps
Rik
Posted on Feb 25, 2009
HeXx13505
  • 65 Answers
SOURCE: PCI Express slot not working
go into the bios and change the video settings from onboard video to pcie video
Posted on Mar 27, 2009
VPU recovery problem
I had the same problem (sorry for my English). Ive installed all the updates for XP, then i updated my drivers to top, but it doesn't work. BUT! I was installing drivers without ATI panel, only the driver. The last version of drivers on time of writing the post is 27/01/10 (catalyst 10.1 or something, dont remember)- installing this helped the video to run for an hour, copmparing to 4 minutes before using this drivers. After being stopped again(DAMN), i ve decided to slow down the clocking of card in ATI panel- originally it was 650-400 MHz, then ive made it 400-400 and black screen of death dissapeared for ages. I had very much troubles with this, so i hope it would help somebody. Dont feel any differience in games.
the only thing for thinking is the count of triubles with this card- like ATI_AMD cant create a stable hardware.
Jan 28, 2010 | ATI RADEON HD 4650, PCI Express Video...
After installing into my vista machine, computer
maybe the monitor is still connected to your mobo, not on your vidcard.
Dec 30, 2009 | HIS HD 4350 Silence DDR2 PCIe, PCI...
Xp Pro PCI EXPRESS ATI Radeon will not install Unified Video stream driver for capture card
use latest catalyst driver from amd site on net.
make sure you have at leasdt 2gb system memory.
ok
Sep 15, 2009 | ATI RADEON X600 Pro, (128 MB) PCI Express...
Fire wire to PC Express
yes...al so known as ieee 1394 ..or fire wire ...or greyhound....it might though prompt you for a driver ...
http://en.wikipedia.org/wiki/FireWire
Jul 18, 2009 | JVC GR-D250 Mini DV Digital Camcorder
Unable to find drivers supporting vistax64 ultimate(asus enhanced display drivers)
Here is a link to download the driver for your card:
http://www.nvidia.com/object/winvista_x64_185.85_whql.html
Your card is listed on the "Products Supported" tab.
Remember to click the box to "Agree to terms and conditions..." before clicking Download Now button.
Thanks for using Fixya.
May 19, 2009 | Computers & Internet
My system sees this graphic card (4870) as ATI 4800.WHY?
It will say that because is between the integer of 4800-4895. It doesn't mean the system thinks it's a 4800 it just means it's in that series. Shouldn't be causing you any problems however as the hardware will do all the work regardless of what Windows thinks it is. The catalyst utility should be more accurate by the way,
May 08, 2009 | HIS H487F512P RADEON HD 4870 HDMI Dual...
X1900GT Problem
Sounds like a setting issue. You could try enabling triple buffering, waiting for vertical sync, etc. It is most likely an issue with the game you are playing and the card.
Dec 20, 2007 | Connect3D RADEONĀ® X1900 XTX, (512 MB) PCI...
Computers & Internet Logo
David Payne
David Payne
