Question about Lucent PARTNER18 Corded Phone
Setting the time
I have changed the time on the phone but as soon as a call comes in, the time advances 4 hours. My phone now says it's 4:35pm when really it's 12:35pm. I have followed the procedure but it changes every time someone calls. Help!
  • 1 more comment
  • jreno7655 Sep 24, 2008
    Yesterday, our phone lines were ported to our new T1 line. Could this have caused this issue? Our T1 was installed in August but the phone lines were just moved yesterday and the time was fine until I noticed it this morning.
  • Carl Navarro
    Carl Navarro May 11, 2010
    Even though I still don't see it in the manual, get your T1 provider to adjust the time offset in the clock.
    I'll bet that's what's causing the time reset.
  • Carl Navarro
    This one's a puzzle because nothing through ACS 7.0 says anything at all about CID adjusting system time. If your outside lines are coming in via VoIP or SIP, it may be that the offset from the VoIP box is wrong, causing log errors. I don't have a clue how it is affecting the system time.
There is a new release for ACS R7 that syncs the time with the caller ID. If the local provider is sending the incorrect time on caller ID, this will cause the problem you are having.
Posted on Nov 20, 2008
How to set clock
THE WATCH IS SET OUT AS TOP LEFT BUTTON = B
BOTTOM LEFT BUTTON = A
TOP RIGHT BUTTON = C
BOTTOM RIGHT BUTTON = D
10 Half Digit Digital FL145, FL186
Normal Time Display
1. Press A to change mode.
2. Press B for EL.
3. Press C to toggle 12/24 hour format.
4. Press D to stop alarm sound.
Time/Calendar Setting
1. From normal time display, press A three times to enter setting mode. Seconds will begin flashing.
2. Press C to reset seconds to zero.
3. Press D to set and advance to next setting value.
4. Press C to increase digit; press and hold C for fast advance. Press D to set each setting value.
5. Setting sequence is: seconds, hour, minutes, month, date, day of week.
6. Press A to exit setting mode.
Alarm Setting
1. Press A to change to alarm mode (AL).
2. Press and hold C for alarm sound testing.
3. Press C to toggle alarm/chime on/off.
4. Press D to enter setting mode; hour will begin flashing.
5. Press C to advance digit; press and hold C for fast advance.
6. Press D to set hour and minutes.
7. Setting will automatically exit setting mode mode after minutes are set.
Chronograph Mode
1. Press A to change to chronograph mode (ST).
2. Press C to start/stop chronograph.
3. Press D to reset chronograph when it is not running.
Split Time
1. Press D while the chronograph is running.
2. Press D again to return to the chronograph.
3. Press C to finalize timing.
4. Press D to reset to zero.
Mar 29, 2012 | Fossil Fuel Josh JR9120 Watch
Change 12 to 24 hr & date
Hi bobwesley,
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Nov 17, 2010 | Timex 1440 Nylon watch
How do i change my timex wr30m from 24 hour to 12 hour display
Hi cbrichw,
Hope it helps.
Nov 13, 2010 | Timex 1440 Nylon watch
L need to find out how to set time and date on this phonw
Hope this helps:
Voice Time/Day Stamp
1. Make sure the answering system is ON.
2. Press and hold the day/check button on the base to set the day of the week.
3. Press and hold the hour button on the base to set the hour (a.m. or p.m.). Example: 12AM, 1AM, or 12PM, 1PM.
4. Press and hold the min button on the base to set the minute. The time advances in 5-minute intervals, or tap and release to advance in 1 minute intervals.
Speaker Volume
Use the speaker volume (- / +) buttons to adjust speaker volume on the
Jan 30, 2010 | GE 25952EE1 Cordless Phone
How do I switch from 24 hour time to 12 hour time?
Hi greg780,
Hope it helps.
Oct 12, 2009 | Timex 1440 Nylon watch
Timex 1440 time from 24 hour clock to 12 hour
Hi bowingman,
Hope it helps.
Oct 09, 2009 | Timex 1440 Nylon watch
Change from miliary time
Please follow the procedure below.
Hope it helps.
Oct 02, 2009 | Timex 1440 Nylon watch
I can change everything but the date. How can I change just the date on my watch. The model I have has 4 buttons (Mode, St/Stop, Set, and Light). Can someone tell me how to change nothing but the date?...
Hi 1234910,
To set the digital time and date on your Timex, please follow the steps below.
Hope it helps.
Jul 16, 2009 | Timex 1440 Nylon watch
I get CL blinking on the base
A flashing “CL” in the message window indicates that you must set the correct
day and time at the base unit.
1. Press the TIME button. The system announces the time and day of the week,
followed by "To set day and time, press TIME/SET."
2. Press the TIME button. The system announces the day.
3. Press the CHANGE button repeatedly until the system announces the correct day.
4. Press the TIME button to save the new setting. The system announces the setting.
5. Press the CHANGE button repeatedly until the system announces the correct hour.
NOTE: Be sure to select the correct time of day (e.g., 3 AM or 3 PM).
6. Press the TIME button to save the new setting. The system announces the minute.
7. Press CHANGE to advance the minutes one at a time. –OR– Press and hold the
CHANGE button to advance the minutes in increments of 10.
8. Press the TIME button to save the new setting. The system announces the year.
9. Press CHANGE to advance the year one at a time. –OR– Press and hold CHANGE to advance the years in increments of 10. When the system announces the correct
year, press TIME. The system announces the clock setting.
Mar 24, 2008 | Motorola Mobility E51 MD7161-3 Quad...
Date/time stamp on answering machine
Set the correct date and time by pressing "time/set." Then, follow the voice prompts. Press "time/set" again. Use "change" button to advance day. Press "time/set" again to adjust hour. Use "change" button to advance hour. Press "Time/set" again to adjust minutes. Press "change" button to advance the minutes. Press "time/set" when finished.
Aug 14, 2007 | AT&T 1480 Phone
Lucent PARTNER18 Corded Phone Logo
Top Lucent Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Computer Repairing
Computer Repairing
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
