Question about Dishwashers
Dish washer continually draining - Dishwashers
My Bosch SHU33A had the same problem - appears to be the "don't flood the House" safety switch sticking. On the Bosch turn the breaker off, undo the 2 screws on the lower front and pull the kick plate off. with a flashlight and your head on the floor look into the underside of the washer; you will see a red plastic rod on the extreme left side. use a long screwdriver to gently move the rod up and down (don't pry!); you can likely hear a barely audible "tick" from the switch as you do this. turn the breaker on and see what happens.
You may want to reset the machine - on mine with the power off hold the two outside switches (stop & drain?) for 5 seconds then power up.
hope this helps
Posted on Oct 04, 2008
  • kdausman Mar 13, 2011
    This is exactly the problem that I've been having with my Bosch SHU33A. Jiggling the red plastic rod worked to stop the endless draining. My worry is that I don't want to have to take off the kick plate and jiggle it every time it sticks... how do I fix the sticking?
Whirpool dish washer has water coming out the air gap when flushing out of dish washer
I think you have a clogged line. the drain from the dishwasher goes up to the air gap and also into your sink drain pipe.
hope this helps
Jul 05, 2012 | Whirlpool Dishwashers
Deloghi dw67s dishwasher, drain pump on continuously, showing E4 and no water in washer. What is used to detect the overflow?
Hello
There is a slight leak somewhere or the machine keeps overfilling causing the drain pan to activate via the flood switch.
remove all dish trays from washer, unscrew and remove lid off salt softener, almost and thoroughly remove as much excess water as you can, it could be the vacuum switch/water level float.. do the tip over again, and be sure you get it all,
replace all trays and softner lid and machine should work again.
Aug 09, 2011 | Dishwashers
How to install drain to maytag in cabnet dish washer
ON MOST DISH WASHERS DRAIN IS HOOKED INTO SINK DRAIN.
May 01, 2011 | Plumbing
Dish washer has a sulper smell when turned on.
Without seeing it and assuming the dishwasher is functioning properly, the drain hose from the dishwasher to the sink drain might have a kink in it from when the put in the new sink.
You should be able to visually look at this under your sink.
Good luck
Get back to me if you need more assistance
Kurt
Mar 19, 2009 | Plumb Pak Continuous Waste Center Outlet,...
Mucky water after cycle complete
poss a blocked drain or a backe feed from the sink remuve drain hose and check.
Nov 13, 2008 | Dishwashers
Cancel drain light continue to flash and dish washer will not make a sound
Hi sandsmi8,
I'm Harvey the Master Plumber.
You're telling me only: cancel drain light continue to flash and dish washer will not make a sound.
Based on this info alone you might be able to reset the d/w with power interuption. Try turning off the breaker for ten minutes. With some models this will reset the d/w computer. If that dosen't work you might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Dishwashers
Neff intergrated dish washer
Drain pump is either faulty or blocked, follow drain hose back to d/washer pump is at the end, always isolate from power supply before attempting any work
Jul 24, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Have a trouble: dish-washer will not drain.
I just moved into a new house and builder had provided a dish washer drain just below my kitchen drain line.
DIsh washer install was done by me, every thing worked out OK except dish washer would not drain after a wash cycle.
Cause: drain provided by builder was blocked and needed a circular small cut before mounting drain hose over it.
Mar 21, 2007 | Electrolux 24 in. ESI6220X Free-standing...
Dishwashers Logo
141 people viewed this question
Top Dishwashers Experts
