Question about Indesit W 123 Front Load Washer
Indesit Washing machine spider bearings
Hi, yeah my bearings collapsed on this machine as well. Been sounding like a jet engine for a while now.
I snapped my one and only T40 can't work out if it's a left or right hand thread. Would appreciate it if anyone who manages to get the spider off the drum can tell me which thread it is. Going to try some heat next :)
    President:
  • 1,462 Answers
Bolts holding spider to tub have loctite on them. only way i found to shift them is heat till they turn easy. i do refrigeration so have oxy/propane burner which makes it easy.
it is easy to damage tub when trying to lever spider out. i use three wood wedges and tap them in turn.
it is a pig of a job
threads are right hand
Posted on Oct 16, 2008
I have a IDL146 washing machine, always the 1400 spin cycle was noisy but now it sounds like a jumbo jet taking off! Are there bearings that can be replaced by a DIY person? If so,please can you tell me...
Hi and welcome to FixYa,
These are the bearings making noise.
http://www.yourspares.co.uk/parts/hotpoint/washing-machines/widl146/parts/ys75567/bearing-kit-HPTC00203002.aspx
However.. this is not a task the average mechanic will be able to accomplish. It involves complete disassembly of the cabinet, the removal of the outer tub front cover and finally removal of the inner tub.
Additional issues that can be encounterd are:
1. Establishing a proper "Tub balance" post bearing / seal change
2. Outer tub seal leaking in the front of the machine.
3. Drive belt damage
4. Tub spider damage if the bearing is very difficult to remove.
This is one of those tasks that has resonably priced spare parts for the initial problem but, can very easily result in the need for several other spares and added expenses.
If your going to DIY just understand what your getting into and take your time. Make sure to clean the front outer tub seal quite well as it will leak if there is even a hint of debris on the seal post repair.
Thanks for choosing FixYa.
Kelly
May 29, 2011 | Indesit W 123 Front Load Washer
How to change the bearing on indesit wil 123 s uk
you take the back off then using a 40 torx u take the wheel off, recomend you use a slide hammer not a pri bar, idid and now ive got leaks, so next you take the concrete wieght off then you take the spider shaped support bar it has two bolts on each end its tight but can be done with out moving anyting then you slide hammer the spider shaped bearing carrier off once off you drift the bearings out using a 1\2 " extension bar and a socket and hammer
Nov 18, 2009 | Indesit W 123 Front Load Washer
Drum bearing very noisy on my hotpoint wma44 wshing machine
Sounds like the seals have gone as did the ones on mine. It need a complete new spider frame and bearing set as the front bearing had collapsed and groved the bearing spindle. Open the door and try lifting the drum to see if there is any up/down movement.
Aug 31, 2009 | Hotpoint WMA44 Front Load Washer
Bearings on a indest wie 167 washing machine
You can download a user manual for your m/c, but not a repair manual, Go to>
www.indesit .co.uk
Follow the links. To remove the spider, remove the rear panel, remove drum belt, undo drum pulley, you may have to heat the screw holding the pulley,undo all screws that you can see holding the spider to drum rear.
Withdraw spider, you may have to use some force to pull it off.
Fit new bearings or spider, and reassemble..
plz rate this solution.
Dec 15, 2008 | Indesit WA 115 Front Load Washer
Indesit W 143 S UK Sounds
either bearings or a foreign object in machine
bearings are a pig to replace on this machine
Oct 16, 2008 | Indesit W 123 Front Load Washer
Indesit wash machine drum bearing
depends on the model that you have some indesit machines you only have to undo the spider and others can be a bit of a pain because you have got too split the drum would recomend an engineer regards jason
Jun 13, 2008 | Indesit W 123 Front Load Washer
Indesit washing machine w1235
could be the bearings or heater/heater may of lifted or spider sometimes a coin can get trapped
May 20, 2008 | Indesit W 123 Front Load Washer
First of all, what kind of a loud is it making?  Is it a loud squeak, clunk, bang, or jet engine sound?
If it is a loud jet engine sound, then your tumbler bearing is wearing out.  You could try oiling it, but [probably you will have to replace it.  It’s a big job and even if you do it yourself, the best and easiest way to do it is expensive.
I recommend first of all ordering a repair manual.  Or at least see if the parts come with detailed instructions on how to take out the old bearing and install the new.  You will probably have to replace the entire outer drum assembly.  It's much more expensive in parts to do it that way than to just replace the bearings and seals, but much much easier and faster.  Personally, I've replaced the entire drum assembly and also tried to replace just the bearings and seals.  In the end I wasted the money on the bearings and seals and got an new assembly.  I'd recommend just going for the new assembly and saving time.
Oct 14, 2007 | Indesit WA 125 Front Load Washer
Irregular banging during cycle
these washers are a swine to dis-assemble and i would not recommend it unless you are experienced. on most indesit, the bearings are in a spider bolted to the outside of the tub. take the back off and see if you can localise the noise to the bearings worthwhile also taking the heater out (one nut in the middle), peer in and check no foreign object causing the noise
May 21, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
168 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
