Question about Dell 946 All-In-One InkJet Printer
I just got this and need help setting up everything!
I don't know how to set up this all in one printer . can anyone guide me. also how do i set up the fax machine
    Genius:
  • 1,124 Answers
You can go to Dell Support and download the manual of this printer here:
http://support.dell.com/support/edocs/systems/prn946/en/index.htm
Posted on Sep 24, 2008
Before I moved, my Lexmark all-in-one printer worked perfectly, but after I moved, everything worked EXCEPT printing of an incoming fax. Everything sounds the same through the sounds the telephone makes as...
Please go through the following checklist:
  • Make sure to plug the telephone fax line from the phone jack in the wall to the Line port on the back of your printer. For more info, please refer to the Lexmark X125 User's Guide.
  • If you have an answering machine connected to the same fax line, be sure to configure it so that it answers first before the fax machine (e.g. if your answering machine picks up on the 3rd ring, set your fax to pick up on the 6th ring or more)
  • If the line has a voicemail feature, disable it or request for a distinctive ring from your phone company.
Sep 14, 2011 | Lexmark X125 All-In-One InkJet Printer
I would like to make copies faster and don't know the procedure? Please let me know if this is possible. Thanik you, Nancy Ludlow
You can set the printer to "economy print mode"
For printing:
Also, in your printer propeties on the computer, set it to print "grayscale"
Here is the user guide:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_7420_7820N_EN_1156.PDF
Jun 29, 2011 | Brother MFC-7420 Laser Printer
I want to set up my new HP PHOTOSMART eSTATION C510 series Printer. Where I bought my printer said I would need a router. So I bought a new CISCO linksys E1000. When I got home and started to get...
. The printer's instruction guide should show you how to set the printer's IP address ?
it has to be in the range of what the modem / router you already have is.
If set to auto ip address on the printer
The existing modem / router would have a DCHP server most likely you could log into this router and look sat the ip leases and when it allocates a lease to the printer you set it as Static or permanent lease. There would be an ethernet port on the back of the router to plug in your printer to.
If manual setup then log into router / modem and set the dchp leases to start above 10 . it would be xx.xx.xx.1 to xx.xx.xx.254 just change it to xx.xx.xx.10 to xx.xx.xx.254 and xx means whatever it is set to for its network address. eg 10.0.0.1 - 10.0.0.254 . Set the printer to ip address to eg 10.0.0.9
On your MAC you may need to download and install a printer driver .
Mac is very clever and may set up the printer once you do this automatically by detecting the printer and setting it up in the MAC
If it is a wi fi printer you need to know the encryption settings by logging into the wi fi router and then set this up on the printer ?
May 13, 2017 | Computers & Internet
Ricoh prints everything in left Margin
Check the printer properly and see what size paper the printer thinks is in there, or check at the controll panel.
-Carl, please let me know if this helps.
Jun 25, 2009 | Ricoh CL3500N Laser Printer
Trying to print 8x11 borderless on Konica Minolta 2400W
http://www2.konicaminolta.co.uk/more-information/support.html
Try this link for assistance
Jun 16, 2009 | Konica Minolta magicolor 2400 Laser...
Printer epson lx-300+II
Changing the default settings in the printer using the printers panel may be a bit difficult but it should be manageable. As soon as you enter the default setting mode it will print a guide, the guide will include the current setting. The guide will also give you the corresponding value of a certain setting according to the status of the light. The first two boxes will correspond to the font lights and the last box on the guide refers to the pause light. pressing the lf/ff button cycles through the options and pressing the tear off button will select the current option and cycle through the options as well.... However, in any printing environment, the setting in the APPLICATION OVERRIDES the setting in the PRINTER. So, whatever setting you select in the printers' default will be overridden by the applications' settings....
Jun 24, 2008 | Office Equipment & Supplies
Loss of ethernet card after reset
u need to put the right IP again, do u know how to do it??? if don´t ask again.
Jan 13, 2007 | OKI C5100n Laser Printer
Dell 946 All-In-One InkJet Printer Logo
51 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
