Re: WD-52725 service manual, Trouble shooting manual
You can get the Mitsubishi WD52525, WD62525 Training Manual from www.tvrepairworld.com under the service manual category which includes the factory training manual and also the factory service manual
There are small surface mounted capacitors on the dm Board and the fmt board that have gone bad. They need to be replaced. Most tv techs will charge about $400 to do this.
Ur tv have convergence problems before,that why tv getting colors lines somtimes alot,sometimes not.The 2 STK convergence ICS was defective.Now the 2 STK convergence ICS are now totally dead.The shop will cost u $300-350 for parts and labors for the 2 STK convergence ICS,and it supporting resistors.
Unplug for a few minutes then plug back in to try to reset it. Sometimes it could take as long as overnight before pluging back in to reset. Number of blinks is usually a trouble code.
Most likely the Main Chassis Assembly needs to be sent to Mitsubishi for refurbishing. It has been a real issue. You may want to call Mitsubishi a call at 1800-332-2119 to see if they could help with the repair cost. They also could help find a local Mitsubishi Service near you.
Hope this helps,
Skyassoc
I believe the format, or FMT board is going bad. this is not a do it yourselfer type repair, unless you have extensive electronics background - I have one myself with the same problem. I am waiting to get a new FMT board for mine.
