First remove the power source from the dock wait for 30 min and then power it on if this fails then its is the problem the connector which connects the ipod to the dock.... you need to replace the connector on the dock...
Good luck...
Check the connector of dgipod
Take the battery off and then look for a reset to refresh the device. see also the settings of your configuration of your device.
CHARCOIS
the device used to work without batteries, with the ac cord-- I just put the batteries in to see if that would help with the sound problem..
I SEE NO RESET BUTTON-- if there is one, where is it?
I have no instructions for the settings, but all I see are the time & alarm settings on the front of the isound. (The clock is working.)
please give SPECIFIC DIRECTIONS FOR ISOUND on where to find buttons to reset or reprogram
thank you
reprogram or whatever you recommend
the connector is fine
does someone know the unit so they can make a concrete suggestion
for getting the speaker to work?
AJKILL-- you hit it on the head!! THANK YOU SO SO MUCH!!!!!
you are a wiz!
