Question about Gateway Computers & Internet
Monitor is shutting off and no signal appearing on monitor .
  • 57 Answers
Sounds like the power supply might be bad on your monitor.
Posted on Sep 24, 2008
Monitor shuts itself down, "no signal" message.
nope. the resolution has bumped up for some reason out of range for the monitor. Does it only happen in the game? that might be a clue.
Feb 17, 2014 | Envision 19" Lcd Monitor H1981
Everytime i start up computer a sigal appears saying "no video input"
I'm assuming after a few minutes, it does get a signal from your computer and all works? It does take about 30s +/- 90s for a computer to generate an output video signal so if your monitor comes on first, before the computer can send a video signal, then you'll see that message. You should see the same message if you shut down your PC and leave the monitor on.
Aug 15, 2011 | Philips 170C4FS 17" LCD Monitor
No video signal to monitor GA-MA78GM-US2H.
firstly troubleshut your monitor with working monitor
if problems result same.
open your computer cassing and troubles shut ram and display card.
then problem still appear
troubleshut your power supply
and lastly troubleshut your motherboard if that problem still no display.
No display problems is associated with hardware problems
Jul 08, 2010 | Gigabyte Computers & Internet
I have connected the cables....no display
disconnect the signal cable and power on then see the massege on monitors screen "NO SIGNAL CHECK THE SIGNAL CABLE"if it appears then monitor is ok if not then monitor is faulty check the signal cable and replace it if faulty problem will be solved
Jun 16, 2010 | Samsung SM943N 19" LCD Monitor
The monitor says there is no signal
there are possibility of cable broken in the path so bend the signal cable left and right and see whether display appears or not. tight the vga connector also try monitor on another cpu if display appear then monitor is ok if not then there is a dry solder inside the monitor
Mar 18, 2010 | Acer X203H bd Monitor
When computer is started no signal appear on the monitor.
If your monitor is working fine, my guess is you might forgot to turn on the monitor power switch which is located at the lower right bottom corner. try it
Sep 13, 2009 | Computers & Internet
Monitor comes up shows "acer" then says no signal and goes black
The interface between the monitor and the cable might need replacement. Please check it.
Jan 12, 2009 | Acer AL2016 W 20" TFT LCD Monitor
LG Monitor Display Problem
1. Mostly Loose contacts in video section that means CRT Neck board dry points checke it.
2.Pl check VGA Cable RGB signal pins 123 to ground 75 Ohms (on OK condition).
3.check 5v supply
4.check SDL and SCL signals.
Oct 05, 2008 | LG Studioworks 563N 15" CRT Monitor
No picture on 215tw monitor. appears briefly on start-up then goes
when you say appears briefly is it shutting off cause its not getting a signal. have you tested the video card with another monitor to ensure there is a signal. also make sure all the pins are on the connector and none are broke off. also check the settings in the menu on the monitor if you can if you cant and it still goes out. then unit may have a bad pcb or ic board. and youd have to test them to figure out which board was bad.
Jun 13, 2008 | Computers & Internet
No driver appearing in Vista
Sorry this is late but:
Unplug the monitor from the PC and then boot.
after you hear the windows starting sound wait for it to load everything up (say 1 min) and plug in the monitor
Windows then plays the "i have found an unknown device" sound and begins to search for drivers
Wait 5 min for it to do this and then shut down the computer with the power button.
Re boot
Monitor should work.
Note: you must be connected to the net for this to work.
- Adyhood
Dec 14, 2007 | Acer AL2017 20" LCD Monitor
Computers & Internet Logo
43 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
