Question about Sony VAIO GRZ610 Notebook
Battery not charging.
I have a problem with what I believe is the connection in the computer that the power cord plugs in to. For a while I could wiggle the cord and if I hold it just right the battery would charge. Not no matter how I hold it it will not charge. Is that internal connection something that I can fix or could it be something else?
Tom. . .
    Genius:
  • 1,124 Answers
This issue can be caused by any of the below possibilities.
  1. Computer AC / DC cable is bad not allowing the computer battery to charge.
  2. Battery is bad.
  3. Battery charger board is bad.
Posted on Sep 24, 2008
  • Alley LU
    Alley LU Nov 25, 2010
    Check if the laptop can work if only install battery, and also install adapter only to find the problem.
    You can find Sony power supply here:http://www.hismarket.com/laptop-ac-adapt...
My panasonic Hc-v100 camcorder is not charging when plugged in to USB cable - cursor light is not flashing and battery is running down
you DON'T charge the camcorder with the usb cord,you only move files between cam and computer,you need a power cord that plugs into the wall,see pic, LETO 2A AC Power Charger Adapter USB Cord For Panasonic HC V100 HC V500 HC...
ihave the same camcorder,
Mar 24, 2015 | Video Cameras
My new battery is not working with my Sony vaio laptop
What do you mean the new batter is not working? Does the computer turn on with the Power Cord? If not, the power cord is bad and cannot charge the battery. I have seen times when new batteries are defective. The new battery does not come charged so you have to plug in the power cord and let it charge overnight.
Apr 06, 2012 | Sony Computers & Internet
Charging my juke with a usb cord
Fully charge the battery to maximize playing time. However, it is not necessary to fully charge or completely discharge the battery each time. You can charge the battery by connecting the jukebox either to the AC power adapter (fastest) or to a USB port on the computer. The battery icon in the upper right corner of the screen indicates the remaining battery charge.
  1. Connect the USB combo cable to the AC power adapter, and then plug the power adapter into an AC power outlet. Or, you can connect the USB combo cable to a USB port on the computer.
  2. Plug the combo cable into the jukebox. Make sure that the top of the plug (the side with the arrows) is facing the same direction as the front of the jukebox.
    View Picture
  3. If you are charging your jukebox from the computer's USB cable, turn your jukebox off. If your jukebox is on, it cannot charge from the computer's USB cable. Note: If you are charging your jukebox from the AC power adapter, you can leave your jukebox on as it charges, but it will take longer to charge.
  4. If the jukebox is on, the power cord icon appears in the upper right corner of the display. The keypad's backlight turns on while the battery charges, and then turns off when the battery is fully charged.
  5. When your jukebox battery is finished charging, pinch the two side buttons on the plug, and then pull the plug out of the jukebox.
Feb 25, 2012 | Samsung SCH-U470 Juke Cellular Phone
Laptop battery is not charging
Hi, this information represents a basic troubleshooting guideline. Refer to your user guide for specific charging and connection instructions. Manuals may be available online in the Support Web site of HP.
Remove the battery from the computer.
Confirm the battery contacts are free of any foreign material that may prevent charging.
Reinsert the battery into the computer.
Verify that the AC adapter cord is properly connected and plugged directly into a known working AC power outlet.
NOTE: If the battery charges correctly when the AC adapter is plugged directly into an AC power outlet, but not when plugged into a power strip or surge protector, the problem is with the power strip or surge protector and not the computer battery or AC adapter.
Verify the correct AC adapter is being used.
Ensure the AC adapter box power light is on. This will be an illuminated green light.
If the AC adapter power light is not on, the AC adapter and power cord will need to be replaced.
Verify the charging indicator is illuminated on the computer.
If the issue still exists, install a different compatible HP battery, if available.
NOTE: If a replacement battery charges and operates correctly, the problem is with the first battery.
If neither the original nor a replacement battery charges, service may be required for the computer.
Dec 21, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
I have dell c840. Suddenly only the left most light of the three lights gets orange when power is switched on and then there is no activity and screen remains blank. Bty light when plugged in also remain...
hello
shut down computer - unplug power cord from laptop - remove the battery from laptop - plug Ac adapter into computer and Ac outlet (wall)
turn on computer
if computer does not turn on, replace the AC adapter and cord - then place battery back into computer
plug in new Ac adapter and cord - recharge battery - if orange light stays on after 4-6 hours of charging battery, you need new battery as well - replace battery, charge it up and it should be fine
if you have attempted these steps before and no change occurs, then you may have issue with power connection in computer - locate a service centre to replace power connection on computer
Nov 07, 2010 | Dell Computers & Internet
Battery on HP nc6400 does not charge - new battery from hp - what could be the problem
CHARGING IC PROBLEM bq 24703 ITS CHARGING IC NUMBER .........THIS IS BURN OR BAD CONNECTION ......
GO TO TECHNICIAN AND REPLACED THIS IC ....
CH.OWAIS SHER
SENIOR TECHNICIAN IN PARADISE COMPUTERS (LAHORE) PAKISTAN
Mar 24, 2010 | HP Compaq NC6400 Business Notebook
Battery will not charge/ keep computer on. laptop must be plugged in to be used. I have tried a different battery and power cord (my wife by sheer coincidence bought the exact same model laptop as me a...
Sounds to me like the transformer circuit that enables the batery to charge. If you have bought your machine within the last 12 months it should still be covered by warranty so go back to the supplier. If not covered I wouod still try as it is not beyond reasonable expecations that the machine will operate perfectly in very way for more than 1 year.
Feb 13, 2010 | Acer Aspire 3000 Notebook
How do I charge the battery on a new Acer Aspire One Series?Netbook
Just plug the computer into the wall with the supplied power cord (while the battery is in the computer). This will charge your battery.
Sep 22, 2009 | Acer Aspire One A150-1006 Notebook
HP zd8000 will not charge battery or run on power cord
check the dc jack probably is loose that cause the batterie dont get charge
Aug 13, 2009 | HP Pavilion zd8000 Notebook
WE CHARGE THE MAGELLAN GPS AND TURN IT OFF. BUT WHEN WE GO TO USE IT AGAIN IT IS DEAD. I ONLY HAVE THE LIGHTER OUTLET TO HOOK UP FOR POWER SO WHEN I NEED TO PROGRAM IT IN THE HOUSE I DO NOT HAVE A WAY TO...
Hello kdiltzbook,
Most GPS units can be charged three different ways:
1. Connection to a computer via USB port
2. Connection to a automobile via cigarette lighter plug
3. Connection to a wall outlet via an AC adapter
Typically most GPS devices these days include only the USB cord. Some GPS units also include the cigarette lighter plug. For most GPS units the cigarette lighter plug and AC adapter are optional accessories have to be purchased in addition to the GPS.
You don't mention which model of Magellan GPS you have so I am not sure which cords your GPS should have included. It sounds like you have the cigarette lighter cord and the USB cord? I am sure that Magellan has an AC adapter available for your GPS. You will want to contact them directly (their website is http://www.magellangps.com) or visit an electronics store that sells Magellan GPS receivers (such as Best Buy™) to purchase the adapter.
However, most GPS receivers can be charged from the USB programming cord on the computer. However, ensure you are plugging the cord directly into a USB 2.0 on the computer itself NOT a port on a USB hub. (A USB hub may not output enough power to actually power and charge the GPS.)
You will also want to check and replace the fuse on the automobile plug.
I believe that both the USB and automobile cords should be charging the GPS. If neither adapter is charging the unit then the problem may be the GPS unit itself. The GPS may have a bad battery or problem with its charge circuitry. If that’s the case the unit may require factory service as the battery pack is generally not considered to be end user replaceable.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 07, 2008 | GPS
Sony VAIO GRZ610 Notebook Logo
201 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
