Question about LG LDF6810ST Stainless Steel Built-in Dishwasher
Kitchenaid Dishwasher KUDS24SEWH?
When I press the Normal Wash , the light above the Normal Wash button lights, the Rinse Aid Empty light comes on and nothing happens when you press the start button. What should I do to diagnose the problem?
  • johney_33 Sep 24, 2008
    same issue with my dishwasher
  • 423 Answers
This problem was aparently classified under the LG dishwasher / LDF6810ST section, I don't think this problem got looked at by KitchenAid gurus.
Were the problems resolved?
Posted on Mar 30, 2009
'low rinse' stuck on with full rinse aid, can't start wash cycle
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol above the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the Sanitize button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
Mar 11, 2015 | Samsung DMT400RHS Builtin Dishwasher
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol ABOVE the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the SANITIZE button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
Unknown control panel symbols bosch dishwasher super silent
Wash Cycle Options
Delay Start (model dependent):
This option allows you to delay the start time of your dishwasher up
to 19 hours.
Sanitize:
The Sanitize feature is available only in the Heavy, Auto, Normal and Half Load cycles. Press the
"Sanitize Option" button to activate the Sanitation features during these cycles. The technical sanitation
measures may also improve the drying results. The sanitize LED or The "Water Pipe" symbol will light when sanitation
requirements are met.
Note: The dishwasher automatically defaults to Auto Wash when turned off and back on. If you used the sanitize option
in your last cycle, the dishwasher will default to Auto Wash with the Sanitize option selected when you turn it on.
To achieve proper drying, always use a liquid rinse aid, even if your detergent contains a rinse aid or
drying additive.
Note: The dishwasher indicates low rinse aid by turning on the Refill Rinse Aid indicator LED (for units without
a display) or The "Spray Looking" symbol (for units with a display).
If this light is on, you need to refill the rinse aid dispenser
I got the idea that the "squiggly arrow" has something to do with the sanitize feature also. If you post your model number "on the inside right hand side of your dishwasher door" I'll go get your manual and post the link here. Hope this helps so far! :)
Jun 18, 2012 | Bosch 500 Series SHX55R55UC Fully...
Kitchenaid dishwasher KUDS01DJ Rinse only light is flashing. control panel is frozen with only rinse only light flashing. does not respond to pressing of any buttons. I flipped the breaker switch,...
Ok, Turn breaker off at breaker panel. Just off then on. The rinse only light should be on.....not flashing. Now press the start button first and hold; then press the cancel button. That should cancel all lights. Then press wash button then start. If the light is still flashing after you turn off breaker....you might have a bigger problem. May need new control panel.
Aug 19, 2011 | KitchenAid KUDS01DJ - Multiple Color...
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
Talking about a kenmore 665.16389300 dishwasher. the "normal wash" button is blinking, but none of the other buttons seem to work and the cleaning cycle will not start when i press the...
Hi
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad. Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Kenmore Dishwashers
Dishwasher control light blinking
1 Press down the overfill protection float on the floor of the dishwasher's tub in the right, front corner near the door. If it cannot move up and down freely, the "clean" light will flash.
2 Make sure the dishwasher's water supply is turned on.
3 Look for suds on the inside of the dishwasher and wipe them off with a wet cloth. If the washer's sensor detects suds or foam, it may not run. Use the correct amount of dishwasher soap, not hand soap or detergent for washing dishes in the sink, to ensure suds and foam do not form. Also, make sure the cap on the rinse aid dispenser is secure--this will keep suds and foam from forming as well.
4 Close the dishwasher door. Push the "normal wash" button, then push the "heated dry" button. Push the "normal wash" button again, and push the "heated dry" button again.
5 Watch for all of the lights on your Kenmore dishwasher's panel to turn on and then turn off. The washer may start a new wash cycle at this point; if you do not want it to do so, press the "cancel" button. Otherwise, allow the dishwasher to run through this cycle.
Nov 25, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
Good luck.
Jul 14, 2010 | Microwave Ovens
I have a Bosch dishwasher with a rinse indicator light. When the light is on it's supposed to be indicating that the rinse aid is emptybut my rinse aid container is not empty even though the light is on....
Phone Bosch 08448 928 979 for a step by step solution. Program select at 12 o'clock. Press ON/OFF and Time Delay button together. Press time delay button, display should change from 1 to 0, indicating warning light is inactive.
Jun 25, 2010 | Dishwashers
Dishes are not always dry, even after sitting overnight
hi
make sure you are using rinse aid as this helps to evaporate the water at the end of the cycle in the drying stage. I know tablets have rinse aid built into the tablet but this can wash away on some wash cycles and do nothing so even if you are using tablets i reccommend still using rinse aid.
Jan 24, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
LG LDF6810ST Stainless Steel Built-in Dishwasher Logo
245 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
