Question about Compaq Pentium 4 , 1.5 GHz (244318-B21) Processor
My display colors are fadded and shadowed I have switched monitors and same on both monitors?
I am having problems with my display, colors are faded and shadowing occuring some Horizontal lines visible. I thought the monitor ws bad so I bought a new one and it displays the same. I thought it was the Microsoft SP3 update so I deleted it and the display is the same. so maybe it is the graphics card>64mb nivida geforce2 mx graphics card with tv out........ My computer is an Compac 2001 model pent4 1.5 ghz 512k Ram. Ihave checked and verified that I have the proper drivers for both the graphics card and monitor. both show enabled and working properly. I have windows XP now running SP2 update.
    Problem Solver:
  • 12 Answers
Check you plug to see if one of the pins are bent over and also pull the video card and reseat in the computer sometime it only takes a little bump to make them move if it is not that then its the video card seeing that you already upgraded your software
Posted on Jan 04, 2009
  • vincebt
    vincebt Nov 02, 2013
    DR16R22-948R22S-L6BHRBG-WNGUZM8
  • vincebt
    Serial number: DR16R22-948R22S-L6BHRBG-WNGUZM8, ID: 017002-39, Activation Code: (I need activation code on...
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
17" flat screen not displaying
This message "safe mode press any key" sounds more like the problem is in the PC. You need to try another monitor with this PC, also try the monitor with other PC. Need to narrow down the problem first. Plase post back.
Apr 08, 2010 | Dell E171FPb 17" TFT LCD Flat Panel...
Fadded screen
NEED TO CHANGE YOUR PHONE
Aug 08, 2009 | Cell Phones
Display is fading
Check the batteries first before trying to tinker with the display. Also check for accumulation of fungus, if any, which can also cause the display to fade..............sodeep
Jul 21, 2009 | Computers & Internet
Acer AL 1912 (black) resolution issue
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
May 27, 2009 | Acer AL1912 19" LCD Monitor
My display lcd suddenly fadded to a faint display .
I really don't know if it will work, its been a long time since I had a PC, sorry if my possible solution sounds stupid
Check in Properties, in the section of battery or display, there's an option (i think) which fades the display when the battery is at a certain level.
Feb 14, 2009 | IBM ThinkPad A31P Notebook
Temp/clock display faded
its the display that is going out on the ovenlike everything else things just fad away. Actually I have had LED meter displays do the same thing.
Dec 23, 2008 | Thermador SC302T Electric Double Oven
Colour fade of my 793s
rainbow colour is normally due to magenatic effect on monitor
see that any magnetic thing is near monitor
 if it is there remove it
.after that put off monitor for 15 minutes & then put on.see if any change is there
 if there is any change is there wait for 2 or 3 days it will be ok.
if brightness is also less along with fad color then
 check for video output section & crt electrodes for normal voltage.
it that is also ok then crt is getting weak,
please be in touch with me unless it is solved.
hope this will help.
Oct 11, 2007 | Samsung 793S 17" CRT Monitor
Compaq Pentium 4 , 1.5 GHz (244318-B21) Processor Logo
187 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
