Question about Epson Stylus C44UX InkJet Printer
C44ux problem MY COMPUTER IS SHOWING A PROBLEM PARTS INSIDE YOUR PRINTER ARE AT THE END OF THEIR SERVICE LIFE. CAN I SOLVE THIS MYSELF?
Most likely the ink pads need changing or you can take them out and give them a good wash and drip dry
Posted on Sep 30, 2008
  • invan1 Oct 11, 2008
    1. Unplug the power and USB cables from the printer. I pried open my C42UX printer, careful not to break anything. I use a flat blade screwdriver to pry it apart; there are two-three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
    2. Next I removed the two (2) waste ink pads. They are located at the back on the left hand side. I used the flat blade screwdriver to lift up the ink pads (they were soaked). Please use rubber gloves as it gets very messy.
    3. Next I took the pads to the kitchen skin and washed them with just plain hot water until they were white again. I just let the hot water run on them (the pads are about three inches long).
    4. Once washed I dried them using a hair drier. (you could place it the sun for a few hours or on top of your heater or maybe in a heated oven; (make sure you do not set it on fire with too much heat).
    5. Once dried I placed the pads back in the ink waste bin at the back of the printer.
    6. I closed the printer cover and put back all the pieces and plugged in the USB & power cable and turned it on. (Yes the lights are still flashing).
    7. Go to this link and download this software: http://www.ssclg.com/epsone.shtml
    8. Install the software and run it.
    9. Select your printer and model number ( It only says C42 there is no UX, choose it anyway).It will ask if you replaced with new pads; say “YES”. Then close the window.
    10. Now right click on the SSC service utility, it looks like a printer icon near your clock in the task bar.
    11. Then click on reset counters. You can do all other stuff with this utility too.
    12. Turn off the printer power and then turn it on again. If necessary un-plug the power cord from the back of the printer, wait 20 seconds. Plug it back in.
    13. THERE YOU GO! IT WORKS AGAIN.
My epson r 230 printer is showing 'service required parts inside the printer are at the end of their service life' please find the solution
Epson programmed their printer to monitor the waste ink counter and your printer has reached the maximum value allowed, you have to reset your printer to clear the waste ink counter.
You may read the information regarding "end of life" and "waste ink counter" here: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
To reset the counter, download re-setter program here, install and follow the instruction in the web site.
Good luck and thank you for using FixYa.
May 20, 2010 | Epson STYLUS R230 InkJet Photo Printer
Epson stylus cx5500 printer problem
probably refers to empty cartridges
everything has a service life and it could be a possible part that is wearing out and needs replacing
you have 2 options --ignore it untl it stops performing
or get in a service technician
Oct 28, 2017 | Epson Stylus 2200 InkJet Photo Printer
It's is asking service required,
parts inside your printer are near the end of their service life. This is message is coming, how can i do this problem, please tell me
Sep 06, 2009 | Epson STYLUS R230 InkJet Photo Printer
Parts inside your printer are at the end of their service life.
This message refers to the waste ink pad in the printer, when this is 'full' this message appears, You can reset this yourself by downloading the right software which you can download from here:
I have also checked the C46 is supported
Sep 03, 2009 | Epson Stylus C46 InkJet Printer
How to reset waist ink counter
I have resetter for this type. aicazx@yahoo.com
Jun 03, 2009 | Epson Stylus Multifunction Inkjet Printer/...
" parts inside your printer are at the end of their service life.
This usually happens when the waste pads become full and need to be replaced.
You can try to do it yourself like this guy did on his printer:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
you can actually just use the software to reset the printer but eventually the pads will overflow and start to leak.
The last option is too take it to Epson and ask for a quote.
May 14, 2009 | Epson Office Equipment & Supplies
Parts inside your printer are at the end of their service life. See your printer documentation Parts inside your printer are at the end of their service life. See your printer's documentation for details
when i swich on my Printer C43, both the indicator lamp is blinking, and tehn appear the message:
"Parts inside your printer are at the end of their service life"
Feb 26, 2009 | Office Equipment & Supplies
My Epson Stylus C46 woant work. it says on my Screen that parts inside my printer have reached the end of there service life.it woant do anything.Is there anything i can do to fix it myself.
well!! duh you said that your printer have reach the end of its service life!!
then it's dead!!!!
Get it???
Just Buy A New One!!!
Some Printers are cheaper now and also better like my canon pixma ip1880...
It's worth it man!!!
Aug 03, 2008 | Office Equipment & Supplies
Epson Stylus C44UX InkJet Printer Logo
125 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
