Question about Nokia 6630 Handheld
Memory full i just had my phone reformat.. it still says MEMORY FULL DELETE SOME APPLICATIONS. I can't send messages every time this appears. I just have to restart my phone for my message to be sent..what should I do?
  • ashu_7577 May 23, 2009
    same problem with my nokia 6630. Says memory full all the time. It donty have much loaded. 3.4 MB is still left of the 10 Mb. Sending messages becomes a pain even with no programs running in the background. Says that the memory is full. Please close some applications and try again
  • Nokia Master
  • 1,800 Answers
Try this code its might help in this casse
*#7370# the code is 12345
plz do rate this post
Posted on Sep 24, 2008
I Can't Send Text Messages.. It Fails and the
Go to messages
Then text messages
Then to options
Then SIM Messages
Then delete the SIM Messages.
The memory after deleting sim messages is empty,and you dont need to delete any application
Jun 11, 2011 | Nokia 6682 Cellular Phone
I hav d nokia E63..! & i cannot send any msgs.....it says "memory full , close some applications first...(& i hav absolutely no applications on except messaging)...... before it said that...
hi, the memory might truly be full...check your memory status and see if truly it is full....if after checking, you realized that it is full, then you will have to delete some messages and delete some applications that you use less often..but, if you check your memory status and you realize you still have space, then it means you will have to scan for virus.
cheers
Mar 16, 2011 | Nokia E63 Cell Phone
Hi ! Every time I try to send a text message, it appears Memory full! Close some applications and try again.I did erase my pics as well as those file saved in my memory card, but it still hopeless. It's 3...
Go your message setting. There is option where you'll save your message and choose save to memory card.
Delete all message in inbox and outbox folder, delete all cache in your browser and close all active applications. Try to send text message.
If the notification "Memory full" still appear you must uninstall a one or more application (not just close it but uninstall it) to make some space in your phone memory. Choose application that you don't use the most.
If the problem persist, format your phone back to factory setting.
Hope this help and if helpful RATE please.
Feb 09, 2011 | Nokia 3230
Cant send msg. it says memory full, close some applications snd try again
dear sir,
1.Such notifications appear when your phone memory is full.
2.by deleting some data from your phone memory you can overcome this problem.
you can delete un-wanted messages,images,videos,etc from your phones phone memory
thank you
Dec 26, 2010 | Nokia 6120
I keep having an error come up saying Messaging: Memory full close some applications. I have also had an error saying General: Memory full close some applications. I have no applications open can you...
clear your browser cache as well
set your messages in messaging - options- settings - other to 999 and e memory.
restore factory settings *#7780# default code is 12345 that might just might help you a bit and turn off and on your phone when you do all these things see if it helps any.
“Memory Full…Close some applications and try again” is a normal
message that usually comes on Nokia N70. It showed the memory used in the phone doesn’t have space anymore. But if the message still appears although the user already closed some applications it can be theproblem.
Someone who experience in this memory full problem said, an error message of memory full like above is appears each time he’s opened the
Camera. It also happens for a few times when he’s trying to open
messages, Gallery, or other applications. And then it will force to restart the phone.
Seems like it’s a RAM problem and might there are some applications unable to close completely. If your Nokia N70 phone has gone a start
menu button you can try to hold it down. This way will show you
everything that you have open and they can be closed easily so that
you can continue to take your photos.
So if it can resolve the problem you can reset/format by pressing *#7370#
Oct 30, 2009 | Nokia N97 Cell Phone
My nokia 6120 is not sending sms phone says general memory full close some applications and try again
YOU NEED TO CHANGE THE MESSAGING MEMORY
BY FELLOW THIS TIPS :
PRESS THE MENU
AND PRESS MESSAGING
AND PRESS OPTIONS
CHOOSE SETTINGS
CHOOSE OTHER
CHOSE MEMORY IN USE
THERE YOU CAN CHANGE THE PLACE THAT MESSAGE STORAGE IN .
Oct 12, 2009 | Cell Phones
My e66 cannot send text messages....it shows the error.. general:memory full. close some applications and try again... but there no apps open..
sir your phone memory is full.empty your inbox and outbox and format your handset by using the following code *#7370# it will require your phone lock code which is 12345 in default.
good luck
Oct 08, 2009 | Nokia E66 Smartphone
My n73 gets memory full all the time, i can' send messages or receive them. I've tried reformatting but still it didn't work. What should I do?
go to phone memory and delete some files images music or transfer them to memory card then format your phone *#7370#
Oct 06, 2009 | Nokia N73 Cellular Phone
Can't send text messages
You need to delete some of the data from your phone memory or card memory. or delete some applications which you do not use quite often (like games etc.) It will work.
Jul 11, 2009 | Nokia 6120 classic Cellular Phone
Memory full. Please delete some data.
press *#7370# to reset phone but make a backup
Jun 30, 2009 | Nokia N73 Cellular Phone
Nokia 6630 Handheld Logo
174 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
