Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony TV won't turn on
I have a 32" sony that has worked beautifully for 10 years or so. A few weeks ago it would turn itself off. Then you turn it back on and its fine. Then it would turn itself off and when I turn it back on it's in black and white. Then it went back to gorgeous color again. Now it just turned off and won't turn back on. ???? Help?????
  • Louanne Sullivan
    Louanne Sullivan Sep 24, 2008
    The model # is KV32S45 Serial # 8014679
    Manufactured July, 1998
    Is it still worth getting fixed?? Thanks, Louanne
  • 188 Answers
Unfortunately it's 10 years old. I can't recommend fixing it because something else may go wrong in a month or two and then you would be looking for a new one. It's too bad though because the problem is most likely not the picture tube or it could even be a loose connection but you'd still need a repair person. THEN AGAIN....
I just found this remark elsewhere on this forum from volts.
Don't beat it with a bat LOL, the problem your having is a simple solution, however this would be best left to a qualified tech to do, the Screen Voltage needs to be tweaked up just a tick, I've worked on alot of these sony's and 9 times out of ten thats what it is.
Posted on Sep 26, 2008
I have the sony 32' 10 years ago. Today I turned the TV only I learned that top half is totally black the bottom half is fine. Please let me know the problem and can we solve it. Thank you very much!
This can be caused by several different things.
Among them are: tube failure, digital comb filter failure, convergence failure, capacitors failure, i.c. faults, power supply providing incorrect voltage.
Unfortunately, being that your tv is so old, there is very little that can be done other than get a new tv.
It is because the repairs will cost as much as a new tv.
I'm sorry your Sony gave out on you, but 10 years is a good long time in the life of tv's nowadays.
I hope you get another that gives you as many years enjoyment, or more!
Mar 07, 2011 | Sony Televison & Video
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Jun 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony wega turns itself off
Try to resolder the main board, cold solder only.
Jul 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
T V blinks to black every few seconds otherwise works fine
Sony put i pic killer circut in there tvs. if the tube was not
giving the proper feed voltage on the guns in
the pic tube it blinks off ,sound good no pic.
if you turn up the brightness
on the flyback transfromer you can
get a little more life out of it ,
Jun 28, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The green is taking over all the color on the tv
March 14, 2009
I have the same TV which had the same issue ( green in picture ) - back on 10/2007. I called Sony. They had their technician replace the optical box ( factory defect ). There was no charge for the repair even though TV was out of first year of warranty. Call Sony.
Sony Repair (866) 282-7412
Mar 12, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
your picture tube is bad. rejuvenate may work ..
Apr 01, 2008 | Sony KV-32S25 32" TV
Re: Sony KV-24FS120
your problem in system control ic section related to stand by pin check ckt related to stand by section in remote ic check power to system ic loose coniact in remote or system ic thanks
Sep 09, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Its the BULB people! You need to change it every 3 to 5 years! I have had my sony 55" for 6 years... I had Best Buy come out 3 years ago, changed the bulb... it worked fine. Just started flasshing and shut its self off and back on again. Time for another bulb.
May 23, 2007 | Sony KV-28FX60 28" TV
Sony KV-32S26 32"
One of the front control switches, that are located in the back of the buttons on the front of the set most likly are damaged or broken. These switchs are small and your going to need to pull out the entire chassis of the TV set to replair or replace them. If you have solid state TV repair experience thenm it should not be a big deal, but if you DONT please seek out a local tech to assist you with this repair as sliding out a TV printed circuit board can be a tricky thing, as it can bend ,crack or pop the surface mounted componets right off the board. A repair like this shouldnt cost alot. really all depends on if the board is damaged or not. good Luck
Sep 12, 2006 | Sony KV-32S26 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
