when i get pictures inside the picture is ok but when i get pictures outside there is a white lines appear.what is the problem of my camerawhen i get pictures inside the picture is ok but when i get pictures outside there is a white lines appear.what is the problem of my camera
i also have the same problem...i tried to change the settings but then it is still white when taking pictures outdoors. can i fix this myself or should i bring this to the repairman or should i buy a new cam(coz it can never be fixed)?
Possibly a bad control board in the outdoor unit. Pull the disconnect outside to stop machine, wait 10 seconds and out back in. White mist was likely frost built up on indoor coil due to condenser running without the fan.
It could be over exposure or maybe it is set to indoor or night settings.. Try setting it to automatic or to "outdoor" when you go outside and then take a picture.
hi,
you have shutter unit defective. indoor works fine but outside too much over exposure..due to shutter unit has oil contaminated on blade or sand damaged.
your local repair shop could charge you around $45 to 65 if they are willing to repair.
Good Luck with you!
Go to the menus and reset to default or factory settings. Make sure that the white setting in the picture adjustments in the menus are set to zero or you may have to adjust + or - to get the normal effect again. Test the camera by taking pictures and saving to a sd card. Then put the card in a card reader/writer which is connected to the computer. Copy the pictures or files to the computer and view them to see if they are in good shape or if there is some problem with exposure or the way it looks. If the computer pictures show that they are good, and they are not showing good on the camera LCD, then the LCD has a problem, and is possibly either cracked or has some other display problem. These LCD screens are not that hard to change if you are good at working with small items and screws. If you do this, make sure you have a way to remember where you got each screw, as they can vary in size and kind.
