Question about Maytag Neptune MAH5500B Front Load Washer
Maytag 5500 AWW Turns off randomly shortly after starting
My Maytag 5500 AWW Front Loading Washing machine turns off randomly shortly after starting, sometimes 3 or 4 times before it finally decides to stay on. When it turns off the red indicator lights go out and the machine stops, however it usually starts back up when you depress the start button. Sometimes it requires that you open and close the door and then hit start. I still washes fine, you just have to baby sit it to make sure it stays on. After the first 10 minutes of the cycle it runs fine and the random shut downs do not occur.
  • janetecheek Mar 21, 2009
    Our maytag front loading washer will start but it shuts off jsut after starting. It will not continue running. The circuit board was replaced already from the problem maytag had with the washer a few years ago. This is very frustrating and we will likely not buy another of these washers.
    How much is the motor control board?
    Scholar:
  • 79 Answers
Check out the motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt electronic components. If you have either... then you will need the the new motor conversion kit which includes the new motor, new motor control board and the wire harness. What you describe are signs the motor control board is nearing its end of life...
The kit takes about an hour to install. See www.neptunewaxmotor.com for disassembly photos so you can inspect the motor control board.
Posted on Sep 24, 2008
Clothes getting burnt & torn in maytag front loading washer...how to resolve this issue asap?
Check the inside of the drum. Chances are, there is a sharp object pointing out that is doing this.
Jan 13, 2014 | Maytag EPIC MFW9700S Front Load Washer
How can i bypass my maytag neptune TL aww lid lock???
You will need to open the switch and short the switch using a wire, if what you meant is that there is a switch failure which will not start the program and so the motor will not start on the machine.
Mar 14, 2012 | Maytag Washing Machines
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    Front Load Washer - Error F30
    hI I HAVE REMOVE THE TOP COVER. YOU WILL SEE AT LEFT A PLASTIC ACTUATOR WHO MUST BE UNPLUG FROM ANOTHER PLASTIC PIN. JUST PUT IT BACK TOGETHER AND THE PROBLEM WAS GONE!
    Jun 16, 2008 | Washing Machines
    Loud noise -- water pump??
    Yes you definately need a new pump assembly part number 21001906 $59.95. That is a maytag part number and it is a very common repair. The new pump is a revised design and will look different but will mount the same. Axcess through front panel.
    Nov 25, 2007 | Maytag MAV7200 Top Load Washer
    My Maytag Neptune 7500 front load washer will not turn on when the AC or heat is running
    Check voltages at the outlet. My guess is that you are on the HVAC circuit, and the Neptune is more sensitive than your hvac equipment. Also check that the neutral is about the same potential as the ground.
    Jan 02, 2007 | Maytag Neptune MAH7500WH Front Load Washer
    Maytag Neptune MAH5500B Front Load Washer Logo
    264 people viewed this question
    Top Maytag Washing Machines Experts
    Richard Roth
    Richard Roth
    Bill Long
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
