Question about Toshiba Gigabeat MEG-F10K MP3 Player
NO SYSTEM FOUND ON HDD
Anytime I put on my toshiba U202 F10 it displays "NO SYSTEM FOUND ON HDD"
  • Anonymous Jan 13, 2009
    some1 just give us trhe ******* answers already?
    Problem Solver:
  • 16 Answers
This Worked For Me!!! Check this link it is the only thing that fixed my "no system found" problem. This guy really did his homework. http://home.comcast.net/~mmoyars1316/Gigabeat/Giga_fix.htm
Posted on Jun 20, 2009
No system found on hdd
00100060
Posted on Oct 27, 2008
Me also same problem in my f20 so plz help me to get that software to fix my problem
Posted on Oct 15, 2011
What´s up bro, this link is broken http://home.comcast.net/~mmoyars1316/Gigabeat/Giga_fix.htm do you have other way to see this guide, i have a f20 with the same problem, help please...
Posted on Dec 15, 2009
Error code F10 can you tell me what this means Thank you
[F10] HDD Initialization error
What u can do:
1. Format HDD. 08-690 "2"
2. Replace new HDD, update firmware.
May 29, 2011 | Toshiba e-Studio 45 Black and White Copier
Can not start window vista operating system?
this error is the system corruption error and indicate that the system files have gone bad due to some reason. system recovery can be done to relode the operating system//
shut the comp off // restart it and start tapping f10 key on the keyboard// go to recovery option and follow the steps to do system recovery// remember you will loose all your documents which is saved if you do not have the backup on external HDD.
but there is no other alternative/ the HDD will get formatted and the o/s will be reloaded in new way/
your system will be as good as new // if f10 will not work then you will have to call toshiba support and get the new set of recovery cd to do the recovery on the computer//
May 09, 2010 | Toshiba Satellite A215-S4747 Notebook
F10 error code for a toshiba e-studio 28
Your HDD is having issues. You can try formatting the HDD (make sure you backup templates and address book if you use them.) To format HDD hold 0 and 8 while turning on the copier, when the machine comes ready key in 690 and hit start. It will then display "2 2", hit start again. Wait for it to say please reboot the machine, turn it off and back on. Hopefully this will work but if not, your HDD will need replacing.
Dec 03, 2009 | Toshiba e-STUDIO 282 Black and White...
Toshiba e-studio 550 call for service F10
Do the following.
Hold down 0+8 and turn the copier on.
Type in 690 then hit start.
Make sure there is the number 2 displayed.
Press enter on the touch screen.
Reboot the machine when told to.
Jul 22, 2009 | Toshiba E-STUDIO 650 Copier
OPERATING SYSTEM NOT FOUND MESSAGE
HI,
This can be an issue with the hard drive..
Go to bios by tapping F10 while the system boots > go to diagnostics and select hdd self test.
If it given an error "No IDE device found" then try reseating the hard drive. i.e. take it out and put it back in.
Otherwise try changing the boot order by going to advance / system configuration > select boot order > select the hdd and pess F6 till it goes to the top. Press F10 to save and exit.
Hope this helps..
Regards,
Anup
Apr 08, 2009 | Compaq Presario 700US Notebook
New HDD inserted into Pavilion ZD7000 - will not boot from XP CD
Try your old HDD in it and see if that works. If it does work then nothing is damaged except your DVD drive/Controller. Try putting the new HDD in another computer, installing windows then putting it back in the HP. If all else fails then flash the bios with an updated image and see if that rectifies the problem.
Feb 01, 2009 | HP Pavilion zd7000 Notebook
TOSHIBA GIGBEAT MEG-F20S MP3 - ERROR NO SYSTEM FOUND ON HDD
When formatting occurred a key system folder was erased - Toshiba no longer maintains the replacement software -sorry
Feb 28, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
Gigabeat u202 sl, winXP sp2
I have a similar problem. I bought a new gigabeat U 2Gb in USA last week. It functioned properly in computers in USA. Now I'm in Argentina and I can't connect it to my computer (windows XP and windows media player 10 both in spanish)I tried install WMP 10 in english that came in the CD and the other
two files windowsmedia10-kb902344-x86-intl.exe and windowsmedia10-kb895316-x86-enu.exe and in the last case apear this message:
"Setup cannot update your WMP 10 files because the language installed on your system is different from the update language". Do you have any suggestion to solve my problem? Thanks
Jan 04, 2008 | Toshiba Gigabeat U202 MP3 Player
Toshiba Gigabeat MEG-F10K MP3 Player Logo
1,505 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
