Question about HP LaserJet 2820 Printer
HP LaserJet 2820
I replaced the black, cyan & magenta toners. Went to rotate to yellow, and printer skips that color like it doesn't exist. It tells me I need to order yellow, but won't stop on yellow to change the toner.
  • barb4ue Sep 24, 2008
    Thanks for a good solution, and I was about to use it when it did respond and rotate to yellow, and was able to change the toner.
    Novelist:
  • 170 Answers
Push the button to align another color and open the door and take notes on where the carousel should be when changing a toner, Not sure why it would bypass yellow altogether but may be resolved by manually changing out the yellow. When you open the door to the toner compartment there should be something on the door that depresses something in the machine which will unlock the carousel and allow you to turn it by hand when you depress the same lever with some type of tool that will fit in the slot. Rotate the carosel until the yellow is where it should be when replaceing it then let go of the locking mechanism and replace the yellow toner. hopefully between changing the toner out and powering the machine off/on will get you back in business... Hope this helps you out and if it does please list as a fixya... if not, you may need to upgrade the firmware and that's not to hard if your on the network already...
Posted on Sep 24, 2008
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
Cyan and Magenta does not print on the right side of the paper. Toner indicator shows three quarter of the cartridge to be full. Yellow and black prints are perfect.
I have worked/ serviced similar Laserjet Color Printer with same issue.
Actually, prints with faded colors or different colors are due the the dust/ toner dust accumulated on the optics (mirrors and lenses) inside the printer, which refect the laser beams to form prints. For instance, red color is formed by a mix of yellow and magenta toners. The color is replaced by yellow due the the partial or complete blocking of the image laser beam for
magenta as the mirrors which reflect laser beam get covered with dust and toner (which partially blocks the laser beams). Hence the image is not produced properly. This needs professional hands for servicing and cleaning of the optics inside the printer. Note that first magenta goes off, followed by yellow, then cyan and lastly black. This is due to the mirrors placement inside the printer. Magenta is the last one facing upwards at 45 degrees angle and gets most of the dust and goes off first.
Rest assure that the printer requires ONLY CLEANING OF THE MIRRORS, which are inside the printer. So, it is advised that you get the printer serviced by any printer repair/ service professional. (Please note that the mirrors, lenses and scanner assembly inside such printers is extremely complex and can get damaged very easily especially the mirrors).
Hope it would help. If you need any clarification, let me know
Good Luck!
CreativeTECH
Mar 31, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
My boss want to replace the black ink cartridge for one that prints color. Can this be done with the HP 12-a cartridges? HP Laser jet 1022
Unfortunately laser printers don't work this way. The laserjet 1022 was designed for black and white prints only. In order to do color printing with a laser printer you will need to purchase one that is designed to print in color. The laser printers work a bit differently than the inkjets - the laser printers have 4 toner cartridges, one each for Cyan, Magenta, Yellow, and Black, that work together to print a full color page. With the old inkjets you could just replace a black cartridge with a color one.
So, short answer: Sorry but no you can't make a laserjet 1022 print in color. :)
I would recommend looking at an entry level color laser printer from hp, such as the CP2025 (http://h10010.www1.hp.com/wwpc/us/en/sm/WF25a/18972-18972-3328060-15077-236268-3673580.html) if you are looking into purchasing a color laserjet.
Hope this helps
Please rate this post, thanks!
Mar 09, 2011 | HP 645A Magenta Toner Cartridge (C9733A)...
5 0f 6 cf message when initializing
Hi
replace all colors toners ( black magenta cyan yellow)
in order to start working again
Nov 25, 2010 | HP Color LaserJet 5500 Printer
Took out drum, and yellow cartridge to release jam, cannot get yellow back in
On the topmost part of the printer, there are four buttons in the following order (top to bottom): Black, Cyan, Magenta, and Yellow.
Besides the four button is another button with 4 dots (Black, Cyan, Magenta, and Yellow with a rotating arrow), press this once and you will see that the Yellow button on the left will light up, press it again and the light besides Magenta will light up and so on. Anyway, you get the idea.
Just keep on pressing it until the light besides Yellow lights up again. When it does, lift the top cover of your printer and insert the yellow toner.
Jun 03, 2010 | HP LaserJet 2550L Printer
We use HP Color Laserjet CM1017; Magenta color is not printing
Dirty laser unit - needs (careful) cleaning internally.
See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
All the same laser unit
Apr 14, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
Newly replaced original magenta toner not printing
Dear this printer is solve this problem just
chnge the magenta toner scaner ok ........after that is working but ...do not any idea about this just call me :+91-09328015664
and Email:support@compudesk.in
Jul 14, 2009 | HP Color LaserJet 2600n Printer
HP Color LaserJet 4500N Toner Cartridge Stuck
Hi, i have the same printer and regularly get this problem. Open the top cover and rotate the cartrige that is on top slightly backwards towards the back of the printer. Once you turn the printer on again this usually solves the problem
Nov 13, 2008 | HP Color LaserJet 4500n Printer
Re-installing yellow cartridge in HP 2840
There is a gray button right of the LCD display that has a black arrow circling clockwise and four color dots (magenta/black/cyan/yellow). Push it until you see the "Rotating to Yellow" in the LCD display, then open up the top of the printer by pushing the big gray latch next to the picture card reader at the right front of the printer. You now have access to the cartridge. pull it out and examine it. If it is a new cartridge, check to see if you pulled the plastic dam strip out (which keeps the toner in place in shipment etc).
Sep 07, 2008 | HP LaserJet 2840 Printer
HP LaserJet 2820 Printer Logo
181 people viewed this question
Seeker5211
Seeker5211
