Cd stereo system adjustment for sensitivity
Cd track jumps with volume and bass ?
    Sergeant:
  • 196 Answers
May seem obvious but the higher the base/volume the more vibration to interfere with the player.. if you can move the speakers farther away from the player or if you can't do that try to minimise vibration by maybe putting a piece of material under it
Posted on Sep 24, 2008
2008 nissan pathfinder stereo auto volume adjustment
go to the MENU, and then to AUDIO setup, and proceed according with Balance, Bass, etc However you must read your owner manual for better illustration.
God bless you
Jul 17, 2013 | Cars & Trucks
Tip
Noise Control and Being a Good Neighbour
Whether you live in a private dwelling, or in a multiple home dwelling, such as a condo or apartment building, one should pay attention to controlling the sound from home theatre and stereo systems. In this case, we are generally talking about managing the bass frequencies of the sound system. High frequencies tend to be absorbed by common building materials. The physical/mechanical aspects of sound transmission are complex, but the average person can apply some simple and inexpensive methods to minimize the unwanted transmission of bass frequencies beyond the listening space. <br /> Transmission of bass frequencies can often be controlled by placing bass-producing speakers on pieces of rubber material. These can be as simple as scrap pieces of rubber mat, salvaged rubber feet from other equipment, etc. The physical placement of speakers can determine the amount of bass frequencies that the sound system produces in the listening space. Generally, more bass is generated by placing speakers in corners, and along the shortest wall of a room. <br /> Of course, adjusting the bass and volume controls is a method that can be used to satisfy personal tastes or to control the sound in any situation. Many home sound systems now employ a subwoofer to provide enhanced bass response. This can add lifelike sound quality to the home listening experience, but it is probably the source of most noise complaints. The subwoofer channel of most video program sound tracks has more bass intensity than one generally finds in television, radio or music sound sources. To prevent disturbing the neighbours, one should employ all of the methods detailed above, to reach a happy medium of being able to enjoy full spectrum audio within reason. Personally, I ask my neighbours listen in their homes, while I adjust my maximum sound system volume to a level that they would not complain about. <br /> <br /> <br /> <br /> <br /> <br /> <br /> <br />
on Oct 28, 2010 | Audio Players & Recorders
How do i calibrate my powered subwoofer for my car
OK assuming you are referring to after market sub and amp whether or not added to factory head unit (stereo). #1 start your engine, and have your amp adjusting knobs accessible #2 insert a CD of the most listened to type of music (Rock,rap,classic) #3 adjust your stereo volume to YOUR max preferred db level with your amp levels at the lowest settings possible #4 start by increasing your freq. rang by 2 bands at a time then the same with gain, once you have gotten your bass to the level you like with out distorting or popping try increasing your bass boost (if available) till your preferred sound(may need to back off gain and freq. add bass boost accordingly until you like what you hear.play around with it for a while make sure you do this at the peak volume in which YOU listen to music because if you do it at a low volume and then turn it up you can blow your equipment . side not 8''in is for very fast bass reps, 10''in is for average rock and 12''s 15''s 22''s are for your low long deep bass reps such as rap and R&B anything else just e-mail me
Jan 10, 2012 | Mazda MAZDA3 Cars & Trucks
I recently bought a JVC KD-R311 car stereo, its a great stereo but my settings dont save, for instance i set the perfect sound adjusting bass/treb/mid/loudness and whenever i turn my car back on after...
You need to have the yellow wire from the stereo connected to constant battery/12 volts. That wire supplies power for the memory, if it is connected to ignition power, when you turn off the car, the power for the memory is off also.
May 13, 2010 | JVC AM FM CD DET FACE CAR STEREO
How do i adjust the treb/bass?
my initial reply was...On the function button you may need to depress it for 3 seconds to activate base, treble, balance etc But
then I found this, "Rotary Volume Control: The CD receiver uses a 7-way rotary volume control that increases and decreases the volume of the stereo from 0 to 35. The rotary knob also controls other audio settings such as Balance, Fader, Bass, Mid, Treble and preset EQ settings. In addition, the rotary knob allows you to scroll through and select your music tracks when the Music Search function is activated.
Cheers, this should help ya.
Jan 01, 2010 | Kenwood KDC-BT742U
Sharp CD PC3500 CD Shelf System CD track jumps and doesnot complete song
it seems tht u have a faulty lazer which is common in these types of stereos try smeering **** over it or eating it if it dnt work u will still feel much beter about yurself
Nov 09, 2008 | Sharp CD-PC3500 CD Shelf System
Bass sounds only
That is tricky one. Did you try adjusting the EQ on both the stereo and the amp? Is the Mute turned on because it will act like that? Is both rca jacks plugged in on stereo and amp?
Aug 20, 2008 | Alpine CDA-9856 CD Player
Bose car stereo speakers
You can purchase a bass cd with test tracks....just be careful, these tracks can damage speakers not rated to handle the stress of extreme bass.
Dec 19, 2007 | Boss W-127DVC Car Subwoofer
Car stereo receiver
Maybe the owners manual would help. It says you can adjust the sensitivity of the AUX input through a menu. It sounds like the AUX sensitivity is just set to max. Look for the 'to change other settings' chapter, instructions are in there.
If you don't have the manual, find it on the official website.
http://www.clarion.com/us/en/products/2005/audio/source_units/cd/DXZ555MP/us-en-product-pf_1133851137392.html
The link to download it is on the upper right.
Apr 23, 2007 | Clarion DXZ555MP CD Player
81 people viewed this question
 Grubhead
Grubhead
