My philips remote does not wok?
When my remote acted up i removed the cover to check on the batteries tested the batteries they are still good but i put them back [and yes they are in the right way] the remote stopped working at all lost book with codes so need a code to reformat my remote can you help?
  • 57 Answers
The codes are different per manufacture of the TV, you will need to contact your TV manufacture and ask them what the remote code is for their TV. Some will and some won't give this out, as they prefer you buy the original remote.
If you can't find it just Google your brand/model and remote code and you should be able to find it.
Posted on Sep 24, 2008
How to change batteries on the remote control of my Panasonic air conditioner Model Number CU_RE24LKR
  • Remove battery compartment cover
  • Observe battery orientation and polarity
  • Remove old batteries
  • Install new batteries
  • Test operation
  • Install battery compartment cover
Aug 30, 2016 | Panasonic Heating & Cooling
Need to no how to make my Sony DVD player remote work the volume and power on my Philips TV
Does the remote have a TV setting? In other words, is there a setting on the remote where you can go back and forth between TV, DVD, Cable, etc? If not, you cannot use it for that purpose. If it does, try setting up your remote with one of the following codes.
11454, 11054, 10690.
Jan 01, 2016 | Sony DVP-SR200P DVD Player
My tv remote quit working for a awhile then it started working again then it quit again i have tried universal remotes but none will wok my tv
You need to fix this your self, take the batteries out from the remote control, take something sharp like knife, and clean the springs where the batteries are placed, all of them needed to be cleaned. Try to check if this does work, if not then, take a flat screw driver, open the remote cover gently and use a bit of alchol or any solution, to clean the pcb board. Try to fit things back and check the remote again..this should work. We had done to most of remote control..it works...good luck.
Sep 17, 2011 | Samsung Televison & Video
The philips universal remote codes for my apex tv don't wok. Since I put new batteries in none of the codes for apex tv work
Hello
Philips universal remote control cannot be synchronised with Apex Digital TV. There is no code for Apex with it. There are very rare remote controls which have codes with Apex Digital. Comcast On Demand Custom DVR 3-Device Universal Remote Control is one amoung them. Codes for Apex Digital Tv; with this remote are:
0748, 0765, 0767
Buy this one. It can be sychronised with most of the present devices. OK.
May 31, 2011 | Apex Digital GT2015 20" TV
The remote control is no longer working - how do you change batteries?
Remove the back cover from the remote, note how the current batteries are oriented, carefully remove the batteries and check the terminals for corrosion. Corrosion can easily be removed with a small piece of tin foil or the blade of a knife. Once the terminals are clean and the batteries are out, replace with batteries of the same type. Close the back cover and test the remote.
May 04, 2011 | Televison & Video
How do I remove the battery. 2004 750 Honda Shadow Areo
1st remove the seat. There is a small nut at the back and 2 on the side which will require a hex tool. After that there will be a cover on top of the battery. 1st pull the attached wiring harnasses off to the side, and remove the one philips screw to remove the cover. After that, there are only the 2 remaining screws that attach the positive and negative terminals. I had a hard time getting my battery out for the first time. It acted like it was still attached by something, it was just stuck.
Dec 16, 2010 | 2004 Honda VT 750 Shadow Aero
Remote not working
i've a philips video player model no  ( DVD622),remote not working
May 23, 2009 | Philips DVDR3575H/37
Neet battery cover for Philips TSU600 Pronto remote control
Battery Covers sell worldwide at Rogers for around $3-$10. Also, cheaper 50c ones are sold on EBay, Kijiji, and Craigslist.
May 03, 2009 | Philips TSU6000 LCD Touchscreen Remote...
Unievrsal remote code
you can try these codes and if they do not wok check the websites also listed. They might be able to help you. I hope this helps you with your problem.
Search results for Philips Codes For Cyberhome Dvd RC Forums: Cyber home DVR player codesPhilips Pronto Professional TSU9600 vs TSU9800 ... sale at half-price, these iclude the 15-133, 15-134, and 15-135. each has 5 Cyber Home dvd codes ... http://www.remotecentral.com/cgi-bin/mboard/rc-one4all/threa... Philips PMDVD6Philips PMDVD6 Universal Digital DVD (6 Devices) ... CYBERHOME: 0940, 0100, 0595: CYTRON: 0246, 0440 ... DVD-Recorders + RW. Where codes are shown like this [###] each one ... http://www.remotecodelist.com/remotes/philips/philips_pmdvd6...
May 03, 2009 | Cyberhome CH-DVD 300 DVD Player
How to open an remote control
  1. Remove battery cover & the batterys
  2. Remove 2 screw (torx 6)
  3. Take a (new) 1 " putty-knife
  4. Pry gently the putty-knife between the front (metal look) cover and the grey back-cover on the long side.
  5. Start in the middle and work the the corner.
  6. The grey backcover should be lifted gently outwards and unhooked from the front.
  7. Be careful , don't break the plastic hooks
Nov 02, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
