Question about Mitsubishi WD-52525 52" Rear Projection HDTV
PS3 not recognized by Mitsubishi WD=52525 tv through HDMI
The new PS3 will connect to the tv through the front panel RCA jacks but I want 1080i support using HDMI cable to the back of the set. After connection the TV does not see the PS3. Is there any way to get 1080i via the HDMI input, and how in the world does one select it from the tv?
    Problem Solver:
  • 4 Answers
FYI,
PS3 has output settings and would need to be adjusted if you are coming from the RCA input. Check out www.sony.com/ps3 trouble shooting under display problems. I believe the solution is to turn on the PS3 unit and keep holding the I/O button for more than 5 seconds. I had the same issue going the other way.
Good Luck.
Posted on Jan 10, 2009
With ur remote u can actually add on imputs to the tv so do that and place it towards the front of the tv and see if ur ps3 is now visual if not sorry dude but it worked for my 360
Posted on Sep 25, 2008
I am trying to connect my ps3 to this TV. i have tried with AV ables and through HDMI but it does not seem to work. is there a problem with compatability?
hi,
PS3 outputs hi definition video through HDMI ie 1080p. Your tv will not support that resolution. Because its a HD ready one ie 1080i. If you wnat to connect the PS3 through the hdmi then you have to down convert the video output resolution of PS3 to 1080i. for that you have to connect the PS3 to any FULL HD tv and go to the HDMI video setup and down convert the resolution to 1080i. After that you can connect the PS3 to you tv. Surely you will get the video.
There is one more way to get the video in you tv. connect the PS3's component video output to the component video input of you tv and the audio output to the corresponding component audio input . Select component video input on the tv. You need a component video cable and a stereo RCA cable for that.
ok
Aug 29, 2011 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
Cannot connect ps3 to tv connected with hdi cable but no response, just saying not supported or no signal
  • Have your ps3 in standby mode (red light).
  • Now, press and hold the power button in the front down. Your ps3 will beep twice. Let it go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
Jan 01, 2010 | Televison & Video
How to conect dvd player to my mitsubishi tv model WD-52525
You have several options with your TV depending on your DVD player. The best quality video will be achieved with an HDMI cable if your DVD player has an HDMI output. Next best would be to use a component video connection which consists of 3 RCA cables for video and two for audio. The third option is S video (round connector with pins inside)
Dec 05, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Ps3 lines
does the tv have hdmi? try a hdmi lead and change settings on ps3 for hd use.
Jul 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
4yr old Mitsubishi DL 52525, HDMI input vide problem
Are you sure its the TV and not the source? Are you sure its only the HDMI port on the TV? The only reason why you must HDMI is to get 1080p and your TV doesn't support 1080p. Its supports up to 1080i. Your TV has a native resolution of 720p which means it can accept a 720p image and not need to scale it, so the picture will look the best at 720p but will support 1080i. I would use component cables to connect your sources and set them to output 720p.
Mar 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi with monlink new DVD player HDMI How to make work
the monolink is the hdmi on the mitsubishi. it acceps up to 1080i
Dec 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Installing PS3 with HDMI
there must be a HDMI option in the picture settings on the tv and select 1080i or 1080p in the ps3 video output settings
Sep 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Set-up big screen tv
just hook up by color coding. or through HDMI which will be the easiest for you. (if you things support HDMI)
Aug 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD 52525 & PS 3
First make sure your hdmi cable is connected from the PS3 to the TV. Then go to netcommand, review, and make sure "monlink" is checked, click next, and finish. Select "monlink" from your device manager and turn on your PS3. If the screen is blue, go to the next step. Connect the PS3 via regular a/v cables to the front panel "input-3". Create a net-command device for input-3 as well. Switch to the input-3 device you created and turn on your PS3. Choose display settings, and change the settings to HDMI. Then click change. You'll have 30 seconds to hit device manager, change the device to "monlink", and let the PS3 unit know the setting has worked. From there you can configure. Good luck!
Dec 25, 2006 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
1,934 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
