Question about Panasonic Panafax UF-595 Plain Paper Laser Fax
How to fix this code????
Our cassette needed more paper after inserting paper and returning tray into the fax machine we have a message on the screen:
check cassette
info.code = 011
the cassette is fine..... what can we do?
    Sergeant:
  • 284 Answers
There is a little tab on the cassette that is broken. leave me a way to email or talk to you and this could be resolved
Posted on Sep 24, 2008
  • Brian DuBridge Aug 02, 2011
    why don't you post the resolution so the rest of us can benefit?
    The likely cause is a broken tab at the rear of the paper cassette which is supposed to extend into the slot of the cassette sensor. If you don't want to purchase a new cassette, you can tip the fax machine on its back (remove the power cord first). When looking at the bottom of the machine, locate the metal cover at the bottom left of your view about 1 inch square. Remove the screw and the cover, noticing the slot which is the cassette sensor. Fold a small piece of paper in about 8 layers and insert it into the slot of the sensor, making the square of paper large enough so that when you replace the cover it holds the paper in place. Replace the metal cover. Your machine will always thing the tray is in place, but it will work.
Our Panasonic UF-790 fax maching continues to issue the error Check Cassette Error Code 0011 even after replacing with a new cartridge.
sounds like a paper tray is not fully inserted into the machine. Also check for a smooshed piece of paper behind the paper cassette. The cartridge should have nothing to do with the error. Good luck ....
Jan 11, 2011 | Office Equipment & Supplies
Cant recieve faxes machine says check cassette? how do I do that?
remove the toner cart, cassette and rear tray and unplug the machine
set the machine on its back.
wad up a small piece of electrical tape and stick it into the black U shaped sensor on the left side.
the small tab on the end of the paper cassette is broken off, but you don't need it....just apply my fix.
Apr 13, 2010 | Panasonic Panafax UF-585 Plain Paper Laser...
How do you access bypass tray?
The bypass tray is refered to as the multi-purpose (MP) tray. It is located vertically on top at the back of the fax machine. The fax needs to be programmed (told what size of paper is loaded) by opening the One-Touch Speed Dialing panel, press the 'Data Registration' button, press 'Set' button, then using up or down arrows to select " 5.PRINTER SETTINGS ". Press 'Set' button, then press down arrow to display " 2.PAPER SIZE ". Press 'Set', use arrow s to select CASSETTE or MP TRAY. Use arrows to select appropriate size of paper loaded. Press 'Set'. Press 'Stop' button to return to standby mode. Reference pages 15-11 and 15-12 in LC 2050 Users Guide.
Dec 17, 2009 | Canon LaserClass 2050 Plain Paper Fax
Alarm - check cassette info code 011 - what is
The tab on the base of the paper cassette is broken off.
How to cheat it:
Remove the paper cassette
remove the tray in the back
remove the toner cartridge
set the machine upright
Wad up a small piece of electrical tape and shove it into the small black u-shaped sensor on the left side bottom.
it should work OK after this.
Nov 20, 2009 | Panasonic Office Equipment & Supplies
Panasonic Panafax UF-880 Plain Paper Laser Fax - Info code 011
Remove the paper cassette completely, look in the cavity for a broken magnet or crumpled up paper. The machine thinks that there is no paper tray installed
May 08, 2009 | Panasonic Panafax UF-880 Plain Paper Laser...
Message says check cassette Info. code =011
it means that you broke the little tab at the end of the paper tray
there is a way you can fix it.. take the tray out and put it on the side. look in where the tray would go on the left hand side if you follow the wall back you will see a hole with a upside down letter U. if you have a "sticky note, yellow note, what ever you want to call it" fold it into a small thick square and put it in the hole if you did it right the machine will say no recording paper.. if not add more paper or you can buy a new tray
Jan 26, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
Recording Paper Cassette
Error code 11 means that it does not see the cassette in the machine,. there is a tab on the back of the cassette that is broken . thats why your getting that code.
if you leave me a msg that you want to fix this i will contact you
Oct 09, 2007 | Panasonic Panafax UF-595 Plain Paper Laser...
Paper Feed Not Automatically Switching to Multi-Purpose Tray
Sounds like the paper out sensor for the cassette is either broken or jammed. Pull out the cassette tip the machine on its back and you should see a black arm hanging down. This should be able to swing back and fourth freely. Unless it is missing or broken.
Jun 08, 2007 | Canon LaserClass 2050 Plain Paper Fax
MESSAGE O A PANAFAX UF-790 STATES CHECK CASSETTE MESSAGE IN MEMORY
Check cassette means the paper feed tray. Pull out the paper tray, put in fresh paper. Close the paper tray and see if it starts to print. If not, let me know Ed
May 30, 2007 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-595 Plain Paper Laser Fax Logo
550 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
