Question about Whirlpool Duet GHW9150P Front Load Washer
GHW9150P Duet washer will not finish cycle
Washer makes a noise and stops, shows codes F02 & SUD. I read on-line
failure code at Appliance Factory Parts that says: " "F/02" Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
If I need to replace the pump, can you send me a repair manual to show
pump location and replacement procedure ?
Thanks,
T. Trekell ttwotees@austin.rr.com
  • 2,071 Answers
Just click below for code error;
WHAT IS WRONG WITH YOUR WASHING MACHINE?
GHW9150P Duet washer will not finish cycle - small_11_21.jpg For a detailed Washing Machine illustration, click below.
Top GHW9150P Duet washer will not finish cycle - redarrow.gifStyle
redarrow.gif Top Load Whirlpool Style
redarrow.gifTop Load GE Style
Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope it may help you;
Regards,
VOTIT
Posted on Sep 24, 2008
    Master:
  • 763 Answers
About your device you can contact the whirlpool on this site for some questions.
http://www.whirlpool.com/custserv/index.jsp
if your looking for a parts of your washing machine, you can buy it here.
http://www.appliancepartspros.com/Appliance-Parts/Washer-Parts/index.aspx
CHARCOIS
    Genius:
  • 3,422 Answers
First thing you can do take the drain hose can blow into it without restriction. If not take lose the hoses to the pump. You might want to get some pinch off pliers to save water from going ever where or a shop vac to **** out the tub. If the pump is getting warm current is flowing to it and propeller is jammed more than likely. The front should have a couple of 1/4 screws at the corners on the front I think. should pop after removing them.
Good Luck.
  • Priya darshan Sep 24, 2008
    I'll let you know if a repair manual is available for your model.
F2 code keeps appearing and then beep occurs and washer stops during random cycles. Have had washer repaired numerous times.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Potential Causes
cleaning a drain pump Check drain pump for foreign objects
• If the above does not correct the problem replace the pump
Oct 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer giving F2 error during wash cycle, cycle doesnt finish
HI. this code represents a Long Drain issue.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
Oct 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Mdl GHW9150PWO Washer stops
Potential Causes
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whrilpool duet front loader washer flashes f2
Potential Causes
• If the above does not correct the problem replace the pump..
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F02 code flashes and stops rinse cycle
Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be disp NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the displaylayedPress PAUSE/CANCEL twice to clear the displayCheck the drain hose and make sure it is not plugged or kinkedCheck the electrical connections at the pump and make sure the pump is runninCheck the drain pump filter for foreign objects.g. If the above does not correct the problem, replace the pump.
Jul 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Model GHW9150PW0 shows code F02. The washer did nor complete the spin cycle and water was left in the tub. How do I get access to the pump. How do I remove the panels. Thank you
Potential Causes
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
02 f error code
F/02 code appears because :---------Long DrainIf the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
to resolve this problem  :----------
  • If the above does not correct the problem, replace the pump.----------------
  • rate the solution.
thanks.
Jan 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer-error code "sud"
Just take off the bottom kickplate (3 screws on the bottom). You'll see the pump front and center. Twist the front face of the pum slowly to the left. All the trapped water will flow right out towards you. There could be a sock or some other debris there. Unclog, screw that faceplate back in and start it up.
Sep 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
96 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
