Question about IBM ThinkPad A21m 2628 Notebook
The first solution from BunnyDawg worked, now a new one!
I went to Bootdisc and thier help got my system up and running. 2 Days later I booted up and nothing, no BIOS, won't even read a Floppy or CD. All I get is a Black Screen. Could this be a System Board problem or am I overlooking something?
  • 2 more comments
  • Stephen Sep 24, 2008
    Yes I did, do you think I screwed up?
    Thank You for your help Sir
    I will gladly do all the research and the work! I have 2 top of the line computers but I like this Thinkpad and would love to get it back to Factory Condition
    Thank you for all your help.
  • Stephen Sep 25, 2008
    Thanks Robert
    I found the correct BIOS on Lenova's Support Website (I hope they gave me the right one!). Bootdisc had the Flash Utility. I will get those ready!
  • Roberta Smith
    Roberta Smith May 11, 2010
    You didn't happen to try and upgrade the bios by chance did you ?
    Robert
    Brigadier General:
  • 5,158 Answers
That's a nice way to put it... you can recover from that but it's quite an involved process and basically it is done blindly....i've done a couple.
Robert
when i have a few moments i'll get you the links but you will have to do all the research and work to get it going....
Posted on Sep 24, 2008
  • Roberta Smith
    Roberta Smith Sep 25, 2008
    First.... obtain from bootdisk.com a bios update boot disk. Second get the CORRECT bios for that computer. If not sure let me know and i'll find it and give you the link.
    What you are going to do is boot up blind... with a disk in the floppy drive... it will/should automatically install the correct bios....
    I'll point you in the directions of the instructions when you have those things ready... also when you get the correct bios also get the flash utility from the same site that is compatable with your bios and computer.
    Robert
My craftsman 25cc leaf blower wont start
pull the plug, plug into wire, touch head of plug to metal on engine. hold by rubber boot while touching pull starter, see if you get a spark across the plug gap, its small but you can see it. if no spark check switch. if plenty of spark clean fuel system and check primer
Nov 04, 2014 | Garden
I turned on my Dell Dimension 4700 computer,but the amber light started to blink . I held the start up button for 5 seconds and the light went out. I tried to start it up again and got the same thing,...
Vaughn it sounds like the power supply is going bad, try another known good working power supply. If that doesn't work then the motherboard would need to be replaced. If the power supply isn't giving the correct voltages that could cause the computer not to turn on. If the motheboard isn't able to convert the voltages properly then the motherboard could be faulty.
Dec 23, 2009 | Dell Dimension 4700 PC Desktop
Cannot repair vista
PAGE_FAULT_IN_NONPAGED_AREA (The error code, 0x0A, 0x01E, or 0x50 can also be helpful)
Faulty hardware is the most common cause, followed by a buggy system service, antivirus software, or a corrupted NTFS volume.
Disconnect any external peripherals, including the printer. If you have any internal media devices, such as card readers, make sure nothing is inserted in those slots.
Try running the Startup Repair from the Vista installation disk several times in succession. This has been shown to have a cumulative effect, in some cases.
Next try booting to the F8 safe boot menu again. If you get that menu, try the "last known good" option first.
If none of this works, I would recommend that you use your latest backup solution.
If you don't have backup or Windows installation CD, suggest purchase Windows Vista Business. It runs well.
Regards,
Maha
Feb 05, 2009 | Microsoft Windows Vista Home Premium with...
Cannot repair vista ultimate!
hmmm... try turning it on then while it's booting windows forece the computer off.
then turn it on again and select launch startup repair. you can try everything from there.
hope this helps!
Feb 04, 2009 | Microsoft Windows Vista Home Premium with...
I got the discs as you instructed.
I'll look for the maker of your bios later today to find the flash utility.... boot disc has the program to make a bios update disc which is what you want. sorry about the delay as i have some prior commitments i have to look after.
Take care
Sep 25, 2008 | IBM ThinkPad A21m 2628 Notebook
Sears Craftsman 1/2 HP 139.53985
Check the wiring. when you installed the new sensors did you run all new wire? Sometimes during an installation the installer staples the wires to the wall then across the cieling to the opener. Sometimes the stapler will pierce the wires or be too tight and over time a short will occur. If all the wires are exposed (you can see them) slide them abit and see if theres a really tight one. (Helpfull if you have an assistant stare at the sensors to see if something happens). If thier buried in the wall then run new wires. Sometimes the drywallers will hit a wire with a screw when thier doing thier job.
Jun 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Unable to boot
pls give the following detail
model of notebook
is not able to boot into any of the mode??
May 19, 2008 | Toshiba Satellite A25-S207 Notebook
Computer won't boot
yes its a coincidence.....u r bad luck....
may be AudioExcel AV512  not  working properly in  u r system.......i think it dont support u r system......try 1 another....may fix ur problem....
dont forget to tell me u r problem solved or not
best regards & best of luck..
Oct 26, 2007 | AudioExcel Chaintech AV-512 : C-Media 3D...
IBM ThinkPad A21m 2628 Notebook Logo
37 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
