Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Installing PS3 with HDMI
I bought a Play Station 3 which works fine plugged into the jacks in front of the tv (low res), but after plugging in the PS3 to the HDMI jack in the rear of the tv I have no idea how to select that HDMI input to be able to play games and/or movies. None of the "Input" modes or "Composite" modes seem to work.
Any ideas?
    Novelist:
  • 181 Answers
Hello!
If nothing worked for you, there are 2 options: 1. give up on 720p settings and use 480i on PS3. Your set is not 1080p, anyway. Only those, equipped with HDMI inputs are. 2. If your set is working well with cable box's component connections, the TV is OK. Have you tried that? If not, there is a problem with your TV's main board surface mount electrolytic capacitors. I've seen them getting near or completely empty. also, there are some capacitors in a sweep module, what could add up to this problem. If your set has hesitation to turn on after being unplugged off the power strip, or has too large picture size on any mode. In this case, I'd call for repair services. the age of your set suggest that, if it hasn't been repaired lately. There is no way for you fix it, unless you have technician's skills and adequate diagnostic and soldering equipment.
Good luck,
Alex.
Posted on Feb 24, 2012
After hours of racking my brain the solution is to CHANGE THE RESOLUTION OUTPUT ON YOUR PS3 TO 1080i BECAUSE THE HITACHI WILL ONLY DISPLAY 1080i AND YOUR PROBLEM WILL BE SOLVED!!!
Posted on Dec 27, 2011
    President:
  • 2,961 Answers
There must be a HDMI option in the picture settings on the tv and select 1080i or 1080p in the ps3 video output settings
Posted on Sep 24, 2008
I have an 52 inch lg5000 tv . it supposed to be full hd. i ve tried to connect my play station 3 via hdmi cable but the only thing i get is the no signal sigh on the screen i ve tried everything . is my tv...
plug the ps in with power cable only no hdmi. When turning on Hold down the power button until you hear a second set of beeps you have now reset the video settings. Turn the console off and plug in your hdmi and switch back on it should now work.
Jun 10, 2010 | Sony Playstation 3 (PS3) Console
Tip
PS3 Has no Video - Simple fix!
When you attach your Play Station 3 to an HD TV through an HDMI port, the Play Station 3 will ask you if you wish to switch to HD Mode.
However, if you decide to move it to another TV that is not HD compatible, you will get no picture because the Play Station 3 is “stuck” in HD (HDMI) mode.
Follow these steps to resolve your problem:
1. Turn off the PS3 so it only shows a red light. You can hold the power button on the front until it goes into standby. To be sure, flick the power switch on the back of the Play Station 3 off and then back on.
2. Make sure your Play Station 3 is connected to your regular TV (not HDTV) with the standard video cables.
3. Press and hold the power button until the screen "flickers" and then immediately release. This should reset the video settings.
4. Wait a few seconds, and the Play Station 3 (PS3) logo should appear.
If this does not resolve the problem, follow these steps:
3. Press and hold the power button on the front until the Play Station 3 beeps and then turns off again. This should reset the video for you and you can turn it back on after this.
That’s it! You can play your Play Station 3 again!
on May 13, 2010 | Video Game Consoles & Games
Tip
How to change or reset PS3 Video Display Mode
on Mar 12, 2010 | Video Game Consoles & Games
I plug my ps3 into my laptop useing the hdmi cabble.. but nothing pops up . how can i play my ps3 on my pc screen?
The HDMI cable on your laptop is most likely an output. If the computer does not say installing drivers directly after plugging your PS3 into the computer than it is most likely an output. Try using the HDMI from your laptop to your TV to confirm this. If the computer does not say installing device drivers right when you plug your PS3 into it that means it is not recognizing it, most likely because that port is for output.
Feb 24, 2010 | Sony Playstation 3 (PS3) Console
Ps3 broken
Nov 06, 2009 | Sony Playstation 3 (PS3) Console
My PS3 hdmi cable does not work
First off, if you want to use the hdmi remove the supplied composite cable from the back of the ps3.
You don't need both plugged in at the same time, and I'm not sure with the ps3 but some video devices will not enable both at once.
Have your tv selected for whatever hdmi input you have it plugged into. They should be labeled where you plug them in.
With the unit in standby, switch off and red light in front, hold the power button by the disc tray for 3-5 second. You will hear it beep, after the initial turn on beep, then you should see a display set up screen.
If you switch back to the composite, you will have to do this over again.
Jul 06, 2009 | Sony Playstation 3 (PS3) Console
Hello can you help with this error!
When you switch from one cable connection to another (Hdmi to AV etc) you need to reset the PS3 to its default settings. Basically what is happening is, your PS3 is set to HDMI, so when you plug in AV cables it doesn't know it. So you have to reset it. Hook your PS3 up to whatever cables (make sure system is fully off) then hold the front power button down for a few seconds.
Doing this will reset the display settings. You can then go into the XMB (main menu) and choose your connection. Although the PS3 should do this during the start up on its own.
Hope this helps.
Sep 05, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3
Have both the AV cables and hdmi cables hooked up from the tv to the ps3. On the TV Menu goto the av station which is different from the HDMi station...From the ps3 menu screen gotot settings then to video and audio and select hdmi then back to the tv menu and select the hdmi station and the ps3 main menu should be seen and you are all set
Jul 11, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
PS3 vs Toshiba 65" 65hm117
Sorry to here about your problem. I have a 65HM167 Toshiba tv which is the same as your model, and I have my PS3 connected HDMI with no problems. Try using a different brand HDMI cable and a different HDMI input on the tv if you have not already done so. Hope this does it for you, good luck.
Mar 26, 2008 | Sony Playstation 3 (PS3) Console
Optical inputs
In short yes!
If you have two optical inputs and two equipment (PS3 and HDVD) then you shouldnt have a problem at all. Just make sure you change the mode of the receiver to TV/SAT when you want to use the HDDVD. Your problem may be the video out put.
If i was you i would do the following:
1. Get rid of all your optical cables as you won't need it.
2. If your receiver support HDMI then by default HDMI will send both video and digital sound.
3. Plug the HDMI of the PS3 to the HDMI input of the receiver, plug the HDMI of the HDDVD player into the HDMI 2 of the receiver and plug 1 HDMI cable from the receiver to the tv/monitor you have.
That is the best set up so when you play PS3 you select dvd/ld and when you watch hddvd you select tv/sat.
However having said all that the fact that you have dvd/ld suggests you actually don't have HDMI at all on the receiver(...i just checked the specs of the receiver). Which means you will need to have 2 hdmi inputs for your tv and you will need to have the 2 optical connections.
But in short yes to your question.
hope this is not too confusing.
good luck
smeags.
Feb 05, 2008 | Sony STR-DE595 Receiver
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
346 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
