Question about KitchenAid KEYS850LQ Electric Dryer
Back heating grate inside dryer has become dark like it's burnt
The dryer works fine, but sometimes when it is done I smell a burnt smell and it seems that the back grate where the heat comes out is halfway burnt or darker on the grate. So, I have no complaints about the functionality of the dryer, but I just don't want to be at risk for a fire. Is this normal???
  • noblemolly Apr 20, 2009
    Yes I have the same problem but some black is coming off on my whites is there any way to clean off grate I have tried vinegar several cleaners even used steel wire mesh to scrub?
I used Bartender's Friend. You can find it at Home Depot. Its best to put it on a sponge, rub it on and let it set for about 5. Then scrub with a steel pot cleaner or copper one. It hard to do since the grid is in the back of the dryer but it came off!! Basically, clean it like you would a burnt pot or pan with the Bartender's Friend.
Posted on Feb 25, 2011
    Genius:
  • 1,028 Answers
Darkning of the element housing at that point is normal the smell may be coming from lint on the heating element ..may pay to have it cleaned to be sure there is not excess lint accumilation ..or if it has a bottom panel pull it off and clean the base and around the element housing or if filter is on top remove back and clean..still may have some odor simply from lint floating around but better safe than sorry
Posted on Sep 25, 2008
LEW0050PQ dryer works but smells like burning
In many machines, those elements, which are manufactured by "robots", are very cheaply made.
Rather than risk a fire, perhaps an investment of 20 - 30 dollars for a new element might be a good idea.
If you decide to do this, take a second look around for what specifically is getting so hot it is melting.
Likely the loose wire inside the element is doing that problem.
I should guess it is out of it's place and is melting an adjacent wire outside the heating element.
God bless your efforts.
Oct 05, 2017 | Whirlpool GEW9250 Electric Dryer
Neptune dryer turns on and works for about 10 minutes, then shuts off. When the door is opened it is very hot and has a burnt smell. The only setting that does not have a burnt smell is air fluff. All...
remove the front cover and drum and clean out all lint including lint filter blower wheel housing and all exhaust vent piping from inside dryer to outside discharge,if this is done and it persists,replace the cycling switch and high-limit thermostat as these may have welded themselves and can no longer control heat
Aug 23, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I have a burning smell in my dryer. it heats up and runs but the clothes have a burnt smell
Do not switch on the dyer unless this is checked out as the fault seems related to the coil heating some insulation or foreign particles when it is switched ON.
Sometimes this can be due to wires buring after coming into contact with the heater, the insulation being burnt out.
Also if the connection leads on the heater is bad then the JOINTS might heat more and thus burn the wires or any other materials that come in touch.
An inspection / with a good obserrvation lamp is most important.You can also start by observing the leads on the heaters.
Aug 18, 2011 | Kenmore 76972 Dryer
Kenmore 70 dryer smells burnt
There could be dust settled on the motor inside from the few years in storage. Unplug and remove back, with a hoover brush **** off all dust but do this lightly as to not disturb any connections.
Jan 04, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I have a Maytag Neptune dryer and it is only about 2 years old. I have several animals and yesterday, I opened the dryer and smoke started to come out. It was clearly the smell of burning hair and there...
hello mam remove the back cover of the dryer and detect for any rats and cockroaches, clean it and check the thermostat of the dryer.
Oct 02, 2009 | Dryers
Kenmore Electric Dryer Series 80 Model
Disconnect the dryer from your vent completely,. pull dryer out 3 ft. from wall and test to see if the smell continues, You have to test for a few minutes to clear out any burning lint from vent restrictions. If the smell hoes away then you know you have venting problems. Also check on the grate that covers the element( the part you look through when you see the orange glow from the element) sometimes plastic or clothing burns onto this grate and needs to be cleaned off. I the smell remains, you will have to tear down the dryer to see if you can find the cause of the smell.
Sep 21, 2009 | Kenmore 62802 Electric Dryer
Clothes smell burnt
THERE SHOULD BE TWO SCREWS ON TOP OF THE PANEL UNDER THE DOOR ONCE YOU REMOVE THESE THE PANEL SOULD COME OFF
Sep 21, 2009 | Whirlpool GEW9200L Electric Dryer
Overheating/burnt rubber smell
classical sign of a bad motor. the motor has a thermal switch on it telling the unit to shut off when it gets hot. after it cools down, the switch will tell the motor to turn back on again. good luck, i'm pretty sure that's your problem. contact me for further help if needed. thanks :)
Jul 06, 2009 | Kenmore 73952 Gas Dryer
Gas dryer does not seem to heat up the air
Do the gas burners come on at all and is the pilot light on as well. The orifices could be clogged or dirty or not combusting right. Do you smell gas any when you turn it on? Let me know so I can maybe help further.
Jan 17, 2009 | Maytag Dryers
Towels smell burnt after washing.
Are you sure the burnt smell is coming from the washer and not from the dryer? If you've placed a rubber backed rug or other similar article of clothing, it is not uncommon for that rubber backing to melt and get embedded in the heated duct of the dryer . Not sure this helps but if you can clarify the point at which the burnt smell is first observed that would help..
Thanks
Aug 31, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
KitchenAid KEYS850LQ  Electric Dryer Logo
2,113 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Oloyede Monsuru
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
