Question about Amana ATB1935HR Top Freezer Refrigerator
Outside of freezer is hot
All around the outside of the freezer is hot, though the refrig. is fine. THe freezer still maintains cold temperature.
  • MJPR Oct 08, 2008
    The refridgerator and freezer work fine. The edge closest to the door on refridgerator cabinet is hot in the middle on the top and sides.  I have cleaned the coils under the refridgerator, but it hasn't made any difference.
  • ceedge Mar 11, 2009
    I don't know if this is the exact model # but the fridge is hot on the outside on the top but is also making an annoying noise. High pitched if you ask me, but not sure how to best describe. Is it normal to make noise and be hot? The fridge is cooling correctly
  • 943 Answers
HI thanks for the question. the heat around the cabinet and doors is normal . the heat prevents moisture from hitting a cold surface, and turning to water , which would cause water to run down the sides, rusting the hinges. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 12, 2008
I have a woods chest style deep freeze and the lid is very cold on the outside, but the sides are room temperature and the freezer works fine. Why is the lid cold and how can I fix it
Yes, the freezer temperature means the lid gets very cold. Every time you open it some moisture condenses in the lid and the outside ambient also affects it. The insulation may be beginning to break down and the ice is forming inside. It is not a major problem however and many freezers go on for years with freezing lids!
Apr 18, 2012 | Woods Chest Freezer C1501W3
I have a Lennex heat pump unit which was installed in 2008. Our area (Savannah, GA) has experienced some abnormal cold temps lately. Yesterday, I noticed the outside of the unit had frost on the unit. ...
Heat pumps are the same as an A/C unit only it works in reverse. Instead of blowing cold air inside and hot air outside it blows hot air inside and cold air outside. The heat being blown inside is extracted form the cold air outside. Its called Latent heat Latin for hidden. Believe it or not even though its 20 degrees outside there is still heat in the air. Example if you want to drop the temperature of a freezer from 20 to 10 degrees you have to remove heat .I know your getting unusal weather and that is the problem. Heat pumps can only work no lower then around 20 degrees outside.Heat pumps are never used above the freeze line. With your unusal temperatures thats basically where you are now. Ride it out. When your temps rise a little your be fine. Im in Chicago.
Jan 15, 2011 | Heating & Cooling
Freezer and fridge running too warm
sounds like you might have a bad compressor or the start components for the compressor is bad.
Apr 25, 2009 | Refrigerators
Freezer does not maintain temperature/moisture in freezer
The door seals are letting air in or the seal at the ice dispenser has gone bad and is letting outside(hot) air in and it is the cause of the moisture.
Jun 10, 2017 | GE GSS25JFM Side by Side Refrigerator
FREEZER NOT FREEZING CONTENTS
I have a similar problem with danby and have been unable to get help - I now HATE Danby Chest Freezers
Mar 10, 2009 | Danby 5.5 cu. ft. / 156 liter Chest...
Outside of refrig/freezer hot
Heat exchangers for rejecting heat to air are built into the outside walls. This is normal. Just make sure you have enough clearance for free air circulation around it.
Apr 20, 2008 | Nor-Lake Norlake Refrigeration 4' x 6'...
Kenmore Side by Side Refrigerator, freezer doesn't work, refrigerator works
Unless specifically made for use in a garage most units won't work properly. The owners manual should say what the temp range for proper operation is (usually 55F is the low range). This is because the refrigerator section doesn't need to be "cooling" to maintain 37F if the temps on the outside are below 55F. These things are made to work in a 70F room and will not work properly if under 55F. Stupid thing thinks it's cold enough so it will never turn on, the refer section will stay cold/cool due to outside temps but since the compressor never runs the freezer will just be the same temp as the refer section (at best). Sorry, but in order for a freezer or refrigerator to work in an unheated space it must have the temp control device controling the freezer section NOT the fresh food section. In other words, that model will not work in a garage unless the temps are above 55F always.
Feb 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Amana ATB1935HR Top Freezer Refrigerator Logo
375 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
