Question about Polaroid Televison & Video
My tv will turn off but will not turn on
I have a 40" flat screen tv, when you power down the TV it turns off but when you turn it back on the blue light flashes twice and does not come back on - if you unplugged the tv and plugged it back in it would then come on but that is not working anymore
Benimur
  • 6966 Answers
SOURCE: i am trying to hook
I am assuming that you are connecting the Dell PC to the Samsung 40 inch flat screen by VGA connector/cable.
Perhaps what might be causing no display in the Samsung FlatScreen is that the video signal it is receiving is beyond its capability. To correct this, pls:
1. lower screen resolution of your laptop's properties.
2. it may also be of help if you likewise lower the screen refresh rate.
Both of the above may be adjusted through the appropriate settings in your Display Properties of the Dell PC before you remove the monitor.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Feb 26, 2008
RFICKES
  • 51 Answers
SOURCE: blue stripe down center of screen
Is this a tube television? If so, sounds like the flyback transformer is dead. Take it to the service depot FOR AN ESTIMATE!!!! It's probably cheaper to buy a new TV then repair the transformer.
Posted on Jan 03, 2009
  • 184 Answers
Its unfortunately a bad LCD panel. Even though the warranties for these TVs has expired, you should contact the manufacturer because there may be a hidden warranty ( when a manufacturer knows of an issue with a limited number of TVs and decides to quietly take care of those consumers who contact them.)
Be prepared for some resistance from the first person you speak with. Persistance pays off when dealing with the customer relations dept.s of large corporations.
michtech
Posted on Feb 15, 2009
  • 9 Answers
SOURCE: INSIGNIA LCD won't turn on
replace 2 condensers in the power supply with greater voltage ones.original are 1000uf 35volt...use 1000uf 65volt...99cents each
power circuit is made to fail with typical tv industry tactics...the warranty is reflected by the life of their condensors (capacitors) average life is 2000 hours..
easy...huh
if your a smoker...you must clean the button cover as they get stuck on with your stupid tobacco residue. 75% of all LCD tv's that smokers own fail this way...
\tough huh?
TRY TO STOP SMOKING...
Posted on May 18, 2009
ginko
  • 19396 Answers
SOURCE: HITATCHI ULTRAVISION P50S601...POWER LIGHT BLINKING...WONT COME O
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
Dec 19, 2015 | Westinghouse Televison & Video
What does it mean when your 42 inch TV has a blue screen
The blue screen means that the back light is on. There is no signal coming to the screen to modulate a picture though. Also since there is no sound it means that the main pc board in the unit is probably bad.
Sep 11, 2014 | Mitsubishi Lt-40164 40 Inch Unisen Led Tv
Entire screen has a pink tint. Can change to blue with settings. Cannot change to natural with tint etc.
Check that all cables are intact and plugged in correctly.
Turn of the TV completely. There might be a manual button on the tv for this. As the last thing, remove the power cord from the power outlet in the wall or where it is placed. Wait 1 min. Then put it back in, swith it on and turn on the TV again.
If this doesn't help and you have tried replacing the cable that you get the picture from (VGA, DVI, Antenna etc.) then it is most likely broken.
Jul 06, 2014 | Sceptre X400BV-FHD 40 in. LCD TV
Blank screen with blue light
Hello
Check the backlight inverter board to your TV. This is a common fault for most of the LCD TVs. If it is faulty, the backlight won't light up, resulting a balck screen with sound.
This is the picture of the backlight inverter board to your TV. OK.12_23_2011_4_29_45_am.jpg
Dec 23, 2011 | Sceptre X400BV-FHD 40 in. LCD TV
The whole screen turned blue while shifting it to get to inputs. Now I can't get anything but a blue screen.
If you have not turned the TV off yet then do that. Turn it off and let it power down completely. If it has a fan then let the fan stop spinning. Wait about 5 minutes then turn the TV back on. If you still see blue then you may need a new bulb or the light engine in your TV has gone bad.
Feb 28, 2011 | Sony KDF-E50A10 50 in. LCD HDTV
Blank screen Samsung LN-R409D, audio when turning on and off and blue light at power button in on position???
Hi there
Im afraid this sounds like a fault with the TV. Try turning it off at the wall for 3 minutes, and then with nothing plugged into the TV, turn it back on. If the problem persists contact the manufacturer.
Hope this helps
TV_Doctor
Jan 03, 2011 | Samsung LN-R409D 40 in. LCD Television
I just bought a sony kdl40ex400, 40" lcd tv and when i first turned it on the picture quality was poor and there are 2 vertical blue bars running down the screen at all times how do i fix this
The tv Tuner signal board is bad,must be replaced.This tv is new,bought it,under a year old?So this tv is still under warrenty.Call Sony for a warrenty repair.
Oct 16, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
TV won't turn off
Problem solved. I opened the configuration menu, went to Setup, More, Light Effect, changed setting from "Always" to "In Watching TV".
Dec 09, 2008 | Samsung LN-T4071F 40 in. LCD HDTV
Televison & Video Logo
19 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
