Question about HP LaserJet 2820 Printer
What does "order drum" mean
"Order Drum"
    Novelist:
  • 170 Answers
It means the drum drive assy is about to go out on you, I fond this is the cheapest price for that part and would'nt recommend you change it until you have quality issues. But it would be smart to have one on hand and ready to replace so your not down for any length of time. click here!
Posted on Sep 24, 2008
Data mb-460 drum life
Yes,
That message indicates the drum is getting close to the end of life. The printer shows the message a bit before the end of life on the drum so you have time to order one before it goes out completely. You can get them from your office supply dealer or from Amazon.com
Apr 04, 2013 | Oki Electric Industry MB460...
Removal of rear brake drum with dually wheels on 1986 Ford Econoline 350
are you sure that the hub is separate to to the drum
mostly with fully floating axles the hub and drum are one piece
that means that you have to remove the axle ( 8 studs )
pull then axle
then undo the axle nuts in the hub and then the hub and drum will come off
Nov 30, 2017 | Ford Cars & Trucks
Have a message on a OKI printer C530
The fault is not clear with your request, the drum need not be replaced until it is worn out. So the fault seen must be taken to account.
Nov 22, 2011 | Office Equipment & Supplies
Drum light flashes
This means that you will need to replace the drum soon. Order a new drum and when the light becomes steady or the print quality becomes poor, replace the drum. The drum should last ~12,000 pages. The part number is DR350. You may be able to order this from your Office Supply store; otherwise try the Brother Mall site: http://www.brothermall.com/Accessories/AccessoryDetail.aspx?AccessID=DR350&AspxAutoDetectCookieSupport=1 .
The procedure is similar to replacing the toner but instead of putting a new thing of toner inside the drum, you remove the toner and put it in the new drum. Open the front cover and pull out the drum and toner assembly. Place on newspaper or other disposable material (toner may spill). Push down the blue lever to unlock the toner cartridge. Remove the cartridge from the drum. Unpack the new drum (keep it out of the light until ready to replace the drum). Push the toner cartridge into the new drum until it locks into place; the blue lever should lift automatically. Put the assembly back in the printer. Clean the printer as recommended in the manual while it is open; this includes cleaning the corona wire before replacing the drum assembly.
After replacing the drum, reset the drum counter: with the printer on and the drum light blinking, open the front cover and press and hold the GO button until all of the LEDs light up (about 4 seconds). Then release the GO button and close the cover. Check that the drum light is off. (The manual says you should do the reset first but I tend to avoid this in case of distractions.)
I hope this helps.
Oct 06, 2010 | Brother HL-2040 Laser Printer
Error Code E00002-01c0
you probably mean E000020-01c0 bad yellow drum codes in order 01Y 02C 03M 04B
Apr 10, 2009 | Canon imageRUNNER C3200 Copier
Internal drum on hp laserjet 3330 damaged. How to replace?
If by drum u mean toner cartridge, you will have to order a new toner cartridge from HP.
WWW.HP.com
Dec 14, 2008 | HP LaserJet 3330 All-In-One Printer
Replace drum soon
means you need to order a new drum because this wont wont last more then a hudred pages or so
Nov 17, 2008 | Brother Office Equipment & Supplies
K image drum
The K drum sensor is probably covered with toner residue.
First clean out excess toner spill and see if you can clean the sensor , which should be an opening on the right side wall directly across the K drum. Use a cottonswab with alcohol.
If the sensor is bad, you should have a tech look at it, The sensor board is held in with14 springs!
Joe
Please remember to rate Techs who assist you for free :)
Oct 07, 2008 | OKI C5100n Laser Printer
I am getting the message "Drum near End". Can I obtain a drum and install it myself?
Yes, you can obtain a drum and install it yourself. You can find either a Brother brand drum or order aftermarket drums from other places. A Drum is good for 25,000 pages, and a catridge is good for about 7000 pages, depending on whether it is high-yield or not.
The drum must be replaced after printing 25,000 pages. So refer to the manual, order one or go purchase one in the store and you can replace it yourself.
May 02, 2008 | Office Equipment & Supplies
Message on printer
Your printer has counter on it that keeps track of the number pages that have been printed with it. It is warning you that the drum unit is coming close to the end of it's rated life. Order a black drum unit and have it on hand. Some time in the near future the printer will stop operating until you install the new drum which will come with instructions on how to install it. If you order it now, you will avert a "Crisis" later. Ed
May 22, 2007 | OKIDATA B4350N LASERPR 23PPM ETH-W/ PS BLK...
HP LaserJet 2820 Printer Logo
177 people viewed this question
Seeker5211
Seeker5211
