Question about E-Machines etower 667ir PC Desktop
Onboard video has went out
Onboard video does not work, I can not get to the bios to shut it off after I have installed a pci video card. monitor is good have checked it on another machine, the pci card is good, but I cannot get into bios to shut offonboard video
  • LittRBike May 19, 2009
    When I plug the eTower in, it immediately powers up. The hard drive & keyboard appears to become active. But, I get no video. &, when I press the power button, it appears to become inactive. But, when I release the power button, it powers back up.
  • Roberta Smith
    Roberta Smith May 11, 2010
    no video to either video port ?
    You weren't updating the bios by chance were you ?
    Robert
No video to either
no have not been in the bios
Posted on Sep 24, 2008
Why will HP a6700f onboard VGA connector will not provide a signal ?
have you tried when in the vga card to go to control panel/display and look at change display settings and connect to a projector?
Mar 07, 2017 | HP Computers & Internet
I am trying to install a pcie-x1 video card on a ibm eserver x206m i salvaged from work. I am running windows 7 64bit . I have tried to turn off on board graphics so that it takes the video card i just...
I know this is really old, but I had the same problem on my 206m 8584 with a pci-e x1 video card. I had to upgrade bios first, but nothing seemed to change, bios only showed onboard video as option and windows perfectly recognized the exta card. I went to windows video settings, it showed both video, onboard as main and active and extra as inactive, changed the second video to main and active and switched the plug to finally see my enhanced video. Only problem is that bios screen won't show up on pci-e card, so I start seeing something only after one minute :) Hopes this saves someone else some time.
Nov 03, 2010 | IBM eServer xSeries x206m
Dell gx280 wont run I installed new video card in pci e slot
I had exactly the same problem on my friends Dell GX280. It will only let you use the onboard card or the new radeon card not both together. In the end we had to buy a Radeon card that was made specifically for two monitors and disable the onboard card on BIOS. It would not let us use the two seperate cards in unison.
May 06, 2010 | Dell OptiPlex GX280 PC Desktop
Problem with onboard video of a compaq sr2032x
The onboard video card is actually set to secondary when you plug in a PCI or PCI-E video card. If no video image is showing then there may be further damage inside the mother board.
Apr 29, 2010 | HP Compaq Presario SR2032X PC Desktop
Ibm xseries 235 eserver....all of a sudden stopped booting...it was set up through a kvm swtich, the kvm detects a signal and lights up the apprpriate port, yet nothing is displayed on the monitor....
Please expalin how you know "drives are good" (sic) As it would appear to me that this is indeed your problem? Unless as you say the video card has turned up it's toes. As you said the best way to check that is to enable the onboard Video and check, exactly what happens when you do that? Yes it will automatically use the video, it would install a generic video driver,and show video, are you sure the monitor is OK,have you swapped it out? Simply removing the Video card will automatically enable the onboard video, so you won't need to get inro BIOS. Check the RAM too, and remove any other cards in it.
Feb 23, 2010 | IBM eserver xSeries 235 8671
My biostar g31 -m7 te motherboard does not boot when i try to add a msi rx800 pcie video card,,sometimes i get a overclock fail message after i remove the card and reboot,,,how do i get this card to work...
Turn the computer off.
Remove the PCI-E video-card.
Boot the computer.
Press DEL to "enter BIOS setup".
Disable the "onboard video" adapter,
or set the highest video-priority to be the PCI-E slot.
Save settings, but do not "exit" from BIOS setup.
Install the PCI-E video-card.
Disconnect the video-cable from the onboard VGA-port,
and connect the video-cable to the new video-card.
Turn the computer on, and the video-output through the new video-card should be displayed on your monitor.
Nov 05, 2009 | Biostar G31-M7 TE Motherboard
Dell 1600SC Server - trying to install a video card
try repeatadely pressing delete on startup with the monitor cable attached to your onboard graphics socket but keep the new graphics card in. then you should go into the bios. change the graphics setting to your graphics car and then save and reboot. it should now work from your new graphics card
Jun 18, 2009 | Dell PowerEdge 1600SC Server
Randomly lost display on my pc.. and its not a faulty card.
Try to set your PCI-E card as a first one in BIOS. There also should be an option to turn off onboard video.
Mar 07, 2009 | Gateway GT4022 PC Desktop
Unexpectedly lost graphics, but theres a story to the issue.
You mentioned that you disabled the on-board graphics card using the device mamager.
You should disable the on-board video card in the BIOS.
Go to the BIOS config and disable the Video.
Mar 07, 2009 | MSI RC410M-L Motherboard
MSI k8ngm2-h mobo doesn't recognize PCI-E slot anymore!
Just a suggestion for you to try.
This is to check whether your PCI-E card is ok or not.
The BIOS setting option should be on PCI Express.
Take out the power cable from the hard disk - we don't want to mess around with window driver or system that might be the culprit.
Now turn on the computer, if ok, you should see some texts on your screen. This is a confirmation that your PCI-E card is still working. So then for you to work on your windows to solve the problem. Good luck.
Feb 18, 2008 | Intel Motherboard
E-Machines etower 667ir PC Desktop Logo
93 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
