Question about Compaq Presario Notebook
Installation of Turbo C
I am unable to install turbo C on my Acer Laptop having Vista from files stored in pendrive. Can you please give the path or method to install it? pl reply on my mail id a_singh_shekhawat@yahoo.co.in
  • Nainaa Dec 16, 2008
    I have got Set up from my friend but its not showing any option like set up. Do guide.
    Genius:
  • Compaq Master
  • 1,250 Answers
Turbo c compiler is not meant for vista, use different compiler that is vista compatible, like GCC
Posted on Oct 20, 2008
HOW TO INSTALL TURBO C
Download the turbo c from the link below:
http://www.brothersoft.com/turbo-c-download-182798.html
Once the download is done. You need to extract the files and follow the steps below to install it.
1. Open the folder where you have the files extracted and open INSTALL.EXE
2. Press Enter to continue.
3. It'll ask you on which drive you want to install it. type in c (hopping c is loacl HDD) and press enter.
4.Press enter on enter the source path.
5. On the next screen press F9 key to start the installation or select the option start installation and press enter.
6. Once the installation is done your TC is installed in c:\TC.
7. Open C:\tc\BIN and tc.exe.
Hope this should help you!
Rashish
Aug 19, 2010 | Computers & Internet
How can i install turbo c in windows 7 x64
How to install Turbo C++ on Windows 7 We are providing detailed procedure how to install Turbo C++ on Windows 7. The very same procedure can be used on Win Vista. If you are running 64 bit version of Win 7, read this article. Users having Win 7 Pro and Win 7 Ultimate should use the virtual Windows XP Mode to install Turbo C++.
Installing Turbo C++ on Windows 7
1. Extract the zip files to: e.g. C:\TurboC
step1.jpg Extract zip files
2. Run the install: C:\TurboC\INSTALL.EXE
step2.jpg Run the install
3. Press Enter to continue
step3.jpg Press Enter to continue
4. Enter the Source drive: e.g.C and press Enter to continue
step4.jpg Enter the Source drive
5. Enter the Source path: \TURBOC and press Enter to continue
step5.jpg Enter the Source path
6. In directories specify where Turbo C files are copied. E.g. C:\TC . When done go to start instalation and press Enter
step6.jpg Specify where Turbo C++ files are copied
7. Succesfull instalation
step7.jpg Succesfull instalation
8. First launch from your destination e.g. C:\TC\BIN\TC.EXE
step8.jpg First launch from your destination
Jun 23, 2010 | Computers & Internet
How to run tc++ 3.0 in x86 based system
UPDATE: If you get the error Linker Error: Unable to open include file ‘C0S.OBJ’, please try copying the C0S.OBJ from the OBJ folder into the main folder of the compiler. The downloadable archive has been updated with this fix.
The procedures on this post were based on a Windows XP computer. They may or may not be applicable if your operating system is not Windows XP.
Note: Please make sure you followed the instructions carefully before saying that the archive doesn’t work. Thank you.
The download page for Turbo C++ 3.0 was the most, or second most popular page in poochycat.com, my blog whose domain name is about to expire. I’m moving the downloads here. icon_smile.gif
(The rest of this post must be viewed to find the download links and installation instructions)
The Download Link:Turbo C++ Compiler version 3.0 (On MediaFire) (2931) That’s the C program compiler I used to use during my early college terms.
Installation Instructions Download the archive from the link(s) provided somewhere at the top of this post.
  1. Unzip it and place the contents of the archive into a folder inside your Drive C. (e.g., C:\YourFolder)
  2. Please observe:
    This is the TC.EXE file that you MUST run.
    This is the TC Shortcut file, don’t use it.
    The compiler is the file named TC.EXE. Don’t confuse it with the TC shortcut! Simply double click on that and the compiler will run.
  3. Just before you type your program code, please make sure you have the correct path for the INCLUDE Directory and LIBRARY Directory. You can check by clicking on Options -> Directories
  4. The path for the INCLUDE Directory must be C:\YourFolder\INCLUDE.
  5. And the path for the LIBRARY Directory must be C:\YourFolder\LIB.
  6. Remember to change the YourFolder into the name of the folder you are using for your Turbo C++.
Mar 05, 2010 | Microsoft Windows XP Professional with...
I m using vista home premium 64 bit opreting system & i am unable to run some of the softwares that run on 32 bit OS like TURBO c/c++ compiler. every time i try to run it it shows the message "the...
There are compatability issues with many of the 32 bit software titles. The 64 bit version of Vista is not backwards compatable with all titles of 32 bit Vista. You will have to down load the patch or 64 bit version of the titles you are having trouble with. You can try to run it in compatability mode but things like Turbo C/C++ will not function in that mode correctly. They won't debug right.
Oct 12, 2009 | Microsoft Windows Vista Ultimate Edition
CAN'T INSTALL TURBO C++
Actually turbo c++ is not run fullmode in windows vista. So use dosbox software ,where u have to mount the files of turbo c++ .
Aug 03, 2009 | Computers & Internet
I don't have full screen nd give some errors.
i assume u have to be trying this on Turbo C/C++.for this u'll have to search for iostream.h.run TC.goto options-->directories-->then in the paths of include and library files put in the path where iostream is located..if this problem persists,download and install TC from http://www.brothersoft.com/turbo-c-download-182798.html
it would work...
Jun 20, 2009 | Microsoft Windows Vista Home Basic for PC
Problem for installing turboc++4.5 in wista
ok man i too had teh same prob dont back to xp
Before going to the details u have to create a folder (any name will do). Here we name it as Turbo
Copy the TC into the Turbo folder
Run the DOSBox 0.72 from the icon located on the desktop or from the location of the installation folder
Then u are presented with two screens which look like the command prompt in Windows
Now u are presented with two screens. One with a Z prompt. U can ignore the other screen.
There type the following commands at the command prompt [Z]:
Mount [Type in any alphabet that u wish except z] [Type the source of the turbo C] press enter
Now , Type in the following commands after the Z prompt:
Z: mount d c:\Turbo\ [The folder TC is present inside the folder Turbo]
* Now u should get a message which says: Drive D is mounted as a local directory c:\Turbo\ ***
Now type d: to shift to d: prompt .
D: cd TC [The contents inside the folder Turbo gets mounted as a virtual drive (Here D drive)
D: cd Bin
D: TC or Tc.exe [This presents u the Turbo C++3.0 screen]
On the Turbo C++ goto Options>Directories>Change the source of TC to the source directory [D] ( i.e. virtual D: refers to original c:\Turbo\ . So make the path change to something like D:\TC\include and D:\TC\lib respectively )
In order to get the full screen use the key combination of Alt and Enter
When u exit from the DosBox [precisely when u unmount the virtual drive where Turbo C++ 3.0 has been mounted] all the files u have saved or made changes in Turbo C++ 3.0 will be copied into the source directory(The directory which contains TC folder)
It is a good idea to backup your files in the source directory prior to running DOSBox 0.72
For additional help go through the readme file located in the installation folder or look on the website of the DOSBox forum.
The above procedure has been successfully implemented on Windows Vista Ultimate 64 bit
IMP : Don't use shortcut keys to perform operations in TC because they might be a shortuct key for DOSBOX also . Eg : Ctrl+F9 will exit DOSBOX rather running the code .
Jun 17, 2009 | Microsoft Windows Vista Ultimate Edition
I have a hp laptop with windows vista home premium.i want to work on turboc++, but i am unable to do so. kindly giv your assistance.....
Install the software DOSBox ver 0.72 ( 1.2 MB ) (Freeware) from the link below.
http://prdownloads.sourceforge.net/dosbox/DOSBox0.72-win32-installer.exe?download
D: cd Bin
Mar 07, 2009 | Microsoft Windows Vista Ultimate Edition
About installation of Turbo C in vista operating system
I have an easier solution. Please check my blog for more details http://cybercomments.blogspot.com/
Nov 10, 2008 | Computers & Internet
How to install turbo c in vista home basic compaq pressario lapto??
how to run turbo c in full screen mode on vista operating system.
when i am running turbo c it's gives  a message that vista not support full screen. what should i do please suggest me.
Sep 13, 2008 | Compaq Presario Notebook
Compaq Presario Notebook Logo
90 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
