Question about Intertherm Heating & Cooling
My control board burned out and I replaced it. My furnace and ac still remain inop-I also replaced the thermostat with a known good one and I wired the new board exactly like my old one was wired. If I go out to the compressor and push the contactor on manually to start the unit, the fan runs but I cant tell if the compressor is kicking on or not. My lines dont get cold and heat will blow from the vents. Also the only way my blower comes on is if I turn it on at the switch. I have spoken to the parts place and they believe I may have had a lightning strike on the ground near my house and that may have caused the board to burn out. What else should I check and where can I get a diagram for my intertherm unit. It is a 1995 year model and the number on the furnace unit is E1EH-815HA.
    Problem Solver:
  • 25 Answers
To see if it is the t-stat or the system you can unwire the entire t-stat and jump out the wires. never touch the blue to any other wire or you will blow the low voltage fuse on new board. if you jump red to yellow and your condensing unit cycles on the t-stat is wired wrong or wrong style. If not go check the yellow wire at cond. unit and see if power is even going to it.
Posted on Sep 24, 2008
Weather kinf furnace ac system turn on at same time
possibly yes, also a faulty control board in your furnace can do the same. Need more details on heating type and model as well as which ac system is involved.
Jul 04, 2014 | Computers & Internet
Fan won't blow on ac, but works on furnace
The fans heat speed is low speed and the cool speed is high speed. High speed is controlled by the fan relay normally open switch, the low speed is controlled by the temperature delay or time delay.
see diagram
Jun 05, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Induced draft gas furnace will not turn work
Check the 3-5 amp fuse on the control board of the Furnace, tell me if the fuse has a burn spot on it.
Dec 19, 2012 | Heating & Cooling
Electricity supply blacked out for 10 secs and now system wont turn on at all!!
Let is set for awhile, may have tripped the Breaker or it is in Time Delay. The new AC's have a time delay built into the board if the power is interupted if won't start the compressor right away. Or you could of also had a power surge and burned out the control board on the AC or Furnace. Recheck the thermostat to see if you are still calling for Cooling. Hope this helps.....
Feb 01, 2011 | Heating & Cooling
Having a problem with my AC/Furnace. AC was working fine and was turned on for about 3 weeks. Thursday night it cooled off and we opened up until Saturday morning. On Saturday morning the AC would not turn...
I think your problem is poor usage of the device,i.e. overloading the system. try running better cables to your furnace and ac. The reason i am lead to believe that is. If you already hired a pro to come and fix it for you,and he/she could'nt then what else could it be? in my experience ac units use electricity like microwave ovens.and power tools
Sep 12, 2009 | Heating & Cooling
Blower fan wont shut off
Try cycling the switch at the furnace to reset the blower board. If this doesn't work remove the green wire from the blower board(computer board) to eliminate a shorted t-stat or shorted wire between the furance and t-stat. If blower remains on, then blower board is shorted. I've seen all these problems.
May 04, 2009 | Heating & Cooling
Furnace tries to come on then .... hold -AC.
When the thermostat says AC it means there is no power to the thermostat.
Apr 16, 2009 | Honeywell Power Humidifier: Furnace...
Furnace blower motor
I would check the "G" wire at the Thermostat and make sure that it has a solid connection. The other end screws on to a terminal in the furnace. Check this connection as well. This green(G) wire is what activates the 120v relay on the circuit board. You can test this by turning the thermostat to the off position and then jumping the 24v R terminal with the 24v G terminal at the furnace. if the fan comes on then the problem is in the thermostat wire or the thermostat itself.
Jul 08, 2008 | Goodman GMS90703BXA Heater
Furnace problem
The problem is most likely in the control module of the roof air unit. Dometic uses the thermostat to activate and deactivate a relay in the control board of the roof ac unit whiich is just visible when you remove your air intake screen. The two blue with white stripe wires are the furnace control wires.
The furnace turns on and off by the opening and closing of relay. Most likely, the furnace control relay is stuck in the on position. On the thermostate, remove the fur wire and see if the furnace quits afrer it cycles does not quit right away. With the termostat out of the loop, if the furnace does not shut down, the problem is in the control box. They are not hard to replace but you must be careful with the live wiire from the 110 ciucuit breaker. If you are not comfortable with the repair, take it to a dealer. The part number is on the assembly box. They need to know if you have the heat srip option or whatever othert options our Roof AC has. If the furnace still runs with the blue/white wires disconnected, the furnace wires are shorted somewhere between the furnace and the AC control unit.
Aug 21, 2007 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
316 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
