Question about Video Game Consoles & Games
Console showing one red light and screen says system error e 74
  • 57 Answers
That is a Video Output error. Check your HD AV cable connections. Unplug and replug them back in. You can also try to replace your video cord. If that does not work then there is a internal error with the video output device.
Posted on Sep 24, 2008
5 Suggested Answers
  • 152 Answers
SOURCE: e 74 error
Try borrowing your friend's HDD and use it on your console and see if it still has the same problem.
Posted on Dec 25, 2007
  • 3 Answers
SOURCE: it as come up sayin system error e 74 the red
ok wat u do is bring it back to where u got it its still under warranty, it wont cost u a thing, if its second hand take off the shell where hte disc tray is and see if the silver warranty sticker is intact and in the right place if its not bring it back to the shop and complain thats its not, and as a last solution htere is a way to fix it at home u wrap the xbox up in blankets and takeout hard drive turn it on wit inly the av cable in, wait til the light comes on then take out av cable, tehn leave it wrapped up tight-ish until it turns off or makes a loud kinda clikcin noise then leave for a minute to cool down and turn on should work but is only a temporary solution
Posted on Oct 07, 2009
  • 192 Answers
SOURCE: when i turn on my xbox 360 console it flashes red
This is the error of a general hardware error. Your XBox must be serviced.
I hope this helps.
Posted on Oct 23, 2009
SOURCE: Console has lower right hand
E74 mean your Graphics Processor is no longer properly contact with the heat sync.
Remove the case and cover and disk drive. Then remove the cooler fan and shroud. Once clear, remove the motherboard and unscrew the heat sinks from the bottom. Once apart, use 70% isopropol alcohol and a q-tip to clean the contacting surfaces as well as possible. You will now need to drill hole inline with the ones on the motherboard to drop in a bolt capped with a cardboard insulator ring and finaly a lock nut. You may need spacers of 1/16 - 1/8 thickness under your screw mounts to compensate for a "warp" caused by the motherboard getting too hot and the metal clips simply wont do. Then apply dime sized bead of thermal paste to the processor and remount the heat sync. drop bolts and place fasteners.
(NOW THE SYSTEM MAY NEED TO "BAKE"!!!) This is a process not necessary for some units. But do it anyways to be safe.
TO "BAKE" the system: 1. With fan and shroud off and cover off, plug in the system and turn it on. 2. Place heavy towel over the system until it shows 4 circulating red rings. WHen it overheats it will shut down. 3. Now let it cool and remove the towel and unplug 4. Once cooled, replace components and test your system
GOOD LUCK AND PLEASE RATE THIS POST!!
Posted on May 17, 2011
Hi, i have problem E 74 one red light ..... would
E74 is due to an inherent engineering flaw and will continue on new consoles until Microsoft institutes a revision.
E 74, E 79, E 71 is shown on screen and a solution to fix it is by ensuring that your A/V connections on your Xbox 360 is secured. Another possible cause to the error is that there is a power surge or outage on your system.
BETTER U Click here to download repair guide
Jan 03, 2011 | Microsoft Xbox 360 Elite Console
System error E-74 red flashing light
Microsoft offers warranties on 360's up to 3 years on e-74 error. They changed the policy about a year ago!
Mar 14, 2010 | Microsoft Xbox Console
Xbox one red light on bottom right, error 74 showing on screen
If your console is less than 3 years old and has not been tampered with in any way:ie the console has not been opened, microsoft will repair this free of charge. visit, www.xbox.com/support
comment, if you need further assistance, or
Remember to thumbs up this solution if it helps
Feb 13, 2010 | Microsoft Xbox 360 Console
1 red light blinking& error E 74 shows up on the screen.
AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
Sep 28, 2009 | Microsoft Xbox 360 Console
Hello, i have one red light with an e 74 error.my
Do the X clamp fix. I have repaired countless consoles with this fix that had the E74 error
Aug 11, 2009 | Microsoft Xbox 360 Console
Xbox360, i flashing red light bottom right error message
The cause of E-74 with one red light Error might be overheating of your console and for avoiding such error in future you need to put your machine at an open space. Ensure that it is placed near the window or you can also make some external arrangement for cooling of console such as cooling the machine through a pedestal fan.
But as your Xbox already have E74 with one red light Problem which can be solved by only repairing it, no other alternative.
Either you can send your Xbox to Microsoft (Please note that microsoft is no longer providing extended warranty for E74 with one red lightError) and wait for 3-4 weeks. If you don't want to wait for a month, you can also fix E74 with one red light problem with the help of this DIY Video, the guide will explain step by step approach to fix the problem. Choice is yours........
Apr 07, 2009 | Microsoft Xbox 360 Console
When i turn on my xbox one red light come on an it say system error contact xbox customer support systemfehler E 74
One red light means one of the following, according to Microsoft:
This type of error will show an Error On The Screen. The Error List Is As Follows:E64 - Error: Key Not Valid Or Firmware Problem.
E65 - Error: Key Not Valid Or Firmware Problem Or Flashrom Is Not Responding.
E67 - Error: Hard Drive Install Problem, Attempt To Re-Install.
E68 - Error: Hard Drive Install Problem, Attempt To Re-Install.
E69 - Error: Hard Drive Install Problem, Attempt To Re-Install.
E74 - Error: Video Cable Problem. Possible Damaged Video Cable
Depending on what error code you get, try fixing whatever the corresponding error message is, above.
Mar 19, 2009 | Microsoft Video Game Consoles & Games
On my xbox 360 one red light appears in the bottom right hand corner and on the screen it shows e 74 error
this is a scaler chip problem, a problem with the av cables, or a GPU issue. try borrowing someones av cables, if not, you can try baking the system.
Nov 18, 2008 | Microsoft Xbox 360 Console
E74
The E-74 error is also due to overheating and the RROD fix also cures this fault, hope that helps :)
Nov 11, 2008 | Microsoft Xbox 360 Console
E 74
hi reza,
Alot of people have this same problem,
E74 is an error prompt when the xbox goes into safe mode.
Te reasons for going into safemode is buntiful.
The best answer is from overheating.
Try resetting the xbox[little white button]
Good luck
Dec 29, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
41 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
