Question about Rangemaster Toledo 90 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
Rangemaster toledo DF 90 what is the minimum door width through which these cookers can be fitted?
I wish to purchase a Rangemaster Toledo DF 90 in stainless steel. The descriptions claim it is 600mm deep. However, my door is 630mm wide exactly and I wish to know whether the cooker will get through this space, or whether the handles will make it too deep to get through the kitchen door.
I also wish to know whether any doors, handles or attachments can be removed or retracted to fit it through the doorway, or whether there are any other possible solutions to this conundrum. Otherwise I will have to search for another cooker.
    President:
  • 842 Answers
Yes, the handle, doors and knobs can all be removed, in fact (If I remember correctly) the unit is delivered with at least the handle/rail at the top not fitted. I would still suggest that you visit the supplier with a tape measure and suggest that if they want sell you a unit, they reassure you by showing you a packaged unit, or demonstrate the removal of the handle.
Posted on Feb 15, 2009
Can i fit a glass lid to my Rangemaster Toledo 90? It has never had one fitted and wondering if one can be fitted. Thanks
No not if it has never had one fitted by the manufacturer as it wont have a safety device fitted to close the gas supply in the advent that the lid is closed while a burner is still a light which would shatter the safety glass and cause injury to the user. Some glass lidded cookers where imported to England when i was an apprentice gas engineer and no safety device fitted and the lids exploded and where soon made illegal.
Apr 13, 2015 | Rangemaster Toledo 90 (Dual Fuel) Dual...
How do I replace a ceramic top to my rangemaster Toledo 90 cooker
This job is for qualified person. Is not recomadet to doit yourself.
Mar 30, 2014 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Replace ignition button
Hello Angela,
does your cooker looks like this one?
Then one of the very small buttons should be for the ignition.
To replace that, you need to remove the control board, as they are screwed at the back.
So work for an engineer.
But I know a much easier way.
Clean your button with brake cleaner, or thinner or something like that.
Try to find the cheapest spray can with silverpaint.
Be shure that you have covered all the parts that you do not want to be sprayed and only spray that part of the button that needs to be silver.
Every one will tell you that you are an Expert.
Good luck with it, Dik
Sep 07, 2017 | Rangemaster Toledo 90 (Dual Fuel) Dual...
We bought a brand new dual fuel Rangemaster cooker and the adaptation of our bungalow and building works have now been completed and ready for the cooker to be installed. However, my husband ( who has a...
I used to have the same range with 2 electric ovens, but it is available with the lower large oven on gas and the tall oven electric.
The manual for theToledo with tall electric and large gas oven can be found here:
http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/Toledo90Gas.pdf
The manual for theToledo with both electric ovens can be found here:
http://www.rangemaster.co.uk/media/575792/toledo%2090%20dual%20fuel.pdf
The main product page for the toledo 90 can be found here:
http://www.rangemaster.co.uk/range-cooking/toledo-90.aspx
Sep 16, 2011 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Warmer lights up but not getting hot - Rangemaster Toledo XT
Hi Sally
I havd exactly the same problem. I contacted Rangemaster/Aga support line (0845 603 5312 if in warranty, 0870 789 5107 if not) and they told me the heating element was shot.
My cooker is 2 1/2 years old, so out of warranty, but they were good enough to send me a new cooker top (top left hand side only of course) free of charge!!!, I just have to get it fitted.
You have to replace the whole left hand side of the cooker top too - the burner that the wok goes on!
Good luck
May 08, 2009 | Rangemaster Toledo 110 (Dual Fuel) Dual...
Toledo 90 side oven fan not working.
We had the same problem about 2 months after we bought the cooker. The engineer had to change the fan motor.
Jun 01, 2008 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Range master toledo 90
I would follow these requirements if I were you:
The cooker must be connected to the correct electrical supply as stated on the voltage label on the cooker (This is obvious so far!). It should be connected through a suitable cooker control unit incorporating a double pole switch having a contact separation of at least 3mm in all poles (This means one of those big red switches with "COOKER" written on them). The cooker must NOT be connected to an ordinary domestic power point. The cable size used should be between 6mm squared and 10mm squared twin and earth. Where the installation is protected by a 30 milliamp sensitivity residual current device (RCD Breaker), the combined use of your cooker and other domestic appliances may occasionally cause nuisance tripping. In these instances, the cooker circuit may need to be protected by fitting a 100 milliamp device. This work should be carried out by a qualified electrician.
Oct 28, 2007 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Rangemaster Toledo 90 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
221 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
