Flash red and shut down - Televison & Video
    Master:
  • 479 Answers
Either any of the capacitors or --ics-- are blown off on the main power supply board or the fuse on the power supply board is blown out.so please check on the power supply board and get replaced the necessary.the unit is perfect but replacement is necessary.the same problem is faced by many of the clients and after replacement it works properly.
do not worry.
Posted on Sep 24, 2008
I have an old Carrier N1340 air conditioner that works when switched on, green light flashes 4 times, for a few times then it shuts down. There is also a flashing red light inside that unit.
There will be a list of flash codes in your manual or on the inside cover of the unit indicating what the problem is eg. low pressure or high pressure alarm
Nov 15, 2016 | Carrier Heating & Cooling
Ps3 shut down wont restart flasing red light
PS3 shut down automatically and leave a flashing red light,
Please read this post, you can find a solution : PS3 Red Light Blinking Fix
Feb 01, 2011 | Sony Playstation 3 (PS3) Console
It flashes red or green then shuts off
Problem could very well be in your Red and Green tube ,but try adjusting the screen drive controls for Red and Green turn them down a notch on control block which will be behind bottom Front Panel in front of TV.
May 09, 2010 | Sony KP-57WS500 57" Rear Projection...
PS3 shuts down after one second
hi , i hate to say this but you need to do this asap. Call the playstation support line and send it in. your ps3 is experience a corrupted hard drive. This will only get worse and will eventually shut down for good.
Jun 21, 2009 | Sony Playstation 3 (PS3) Console
There is a flashing red and then shut down NV-DS65
battery is not charged or is defectived. or the power supply is not working.
i suggest replacing the battery or getting a new power cord
Apr 23, 2009 | Panasonic NV-DS65 Mini DV Digital...
Error message
My plasma display the "error message condition 1" and red flashing light start blinking and TV screen shut down. Who can halp me to fix the problem??
Jul 03, 2008 | Fujitsu Plasmavision PDS-4221 42 in....
Sony projection big screen
does the led flash when you try to power it up? If so let me know the number of flashes. From your description I would suggest 1 of 2 things happened. (1) The Convergence amp ICs have shorted and blown the 5 amp fuse on the G board, or (2) the red CRT has shorted shutting the set down. Check the fuse and if blown replace the fuse and disconnect the Red CRT PC board from the RED CRT and try powering up the set. If it powers up without shutting down then unplug the set and rehook the RED crt pc board and try again if it shuts down the reds shorted. But if it still wont start with the CRT unhooked or blows the fuse Change the Convergence ICs
Apr 06, 2008 | Sony KP-57XBR10 57" Rear Projection...
Won't turn on.. Operation indicator is red, Lamp indicator is flashing red??
According to the E44W48LCD service manual, the temperature indicator red light states the projection TV shut down due to overheating. Red (flashing) states the projection TV shut down, check the cooling fan.
Nov 09, 2007 | Zenith E44W48LCD 44" Rear Projection HDTV
Closing itself down DEW
camcorder when turned on flashes in red DEW and closes it self down. i have taken all the batteries out and replaced sometimes after a few days the camcorder will work then DEW will rea ppear and shut itself down
Nov 02, 2007 | Sony HDR-HC1 Mini DV Digital Camcorder
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
