Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire washing machine
My washer sometimes makes a humming sound when operating. Never did it when it was new. Just got it 3 months ago. Also washer will stop and start when tumbling. When i turn it off. It will automatically turn on again. Why?
    President:
  • 2,712 Answers
Seems to be some issue with the circuitry. If its still under warranty, I suggest you get it replaced now before you land up with bigger headaches once the warranty runs out (problems usually start once the warranty runs out :)
Cheers!
Posted on Sep 28, 2008
I have a frigid air gallery series washer that lights up and just humms,it will not start cycle. I have checked pump and motor isn't ether one of those making humm sound
Good Afternoon Cloy,
I understand that you are getting a humming sound on your Frigidaire washer, and it will not start a cycle. I also see that you've checked the pump as well as the motor, and neither of those is making the humming sound. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your washer and determine what is causing your appliance to make that humming sound and not run a cycle. Hope this is helpful.
-Best Regards-
WP
May 13, 2014 | Frigidaire Washing Machines
My frigidaire LTF6700FSO will not spin
Your symptom sounds like a jammed drain pump. Was it spinning and then stopped before the spin cycle should have ended or did it not begin spinning when it should have?
Jan 17, 2013 | Frigidaire ATF6000ES Front Load Washer
Frigidaire affinity front load washer
If the unit will not spin at all and makes a humming noise, sounds like something has seized up in the back of the unit. This could be a belt broken, motor seized up, or the transmission, if your unit has one, is gone.
Jul 17, 2012 | Frigidaire ATF6000ES Front Load Washer
Washer did not spin out message E20 appeared on panel. Attempts to start just humming noise.
is the humming comming from the motror trying to run or is it just a humming sound if the machine has washed correctly upto that point then check water pump for faults and or blockage machine will not advance if water trapped in machine the humming sound could be the water pump either free spinning indicating a blockage or humming as it is trying to run indicating a faulty pump
NEVER OPEN MACHINE CASE WHILST STILL CONNECTED TO MAIN POWER SUPPLY
Jan 17, 2010 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire front loader (about 14 months old) won't drain. It hums (or buzzes) loudly and does nothing.
you really need to tell me a little more;is the drum turning does the machine wash other than this hum is everything else ok?I would say there might be a sock or simler stuck in your drain pump as i dont have enough information i cant really tell you anymore.adrian
Feb 18, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Sounds like the belt may be off. Was it moved with the shipping braces out? It may have caused some internar damage. You might check to see if the hum is coming from the door lock area. If the lock is out it won't let drain or spin.
May 16, 2008 | Frigidaire GLTF2940ES Front Load Washer
Starting dryer
THE HUMMING IS THE WATER VALVE WHICH IS OK,CHECK WATER PRESURE AND FILTERS IT MAY BE DOOR INTERLOCK
Nov 27, 2007 | Zanussi WJS1397W Front Load Washer / Dryer
Frigidaire ATF6000ES Front Load Washer Logo
29 people viewed this question
Top Frigidaire Washing Machines Experts
Electrolux
Electrolux
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
