Question about Sony Playstation 3 (PS3) Console
Horizontal Lines Moving Up Screen
Just bought a new 80g (9/08) and when I have it on, no matter if I'm playing a game or viewing the system screen, I get three lines that go across the screen and scroll from the bottom of the screen to the top. My TV isn't HD or anything, but is a Sony Trinitron flat screen from 2004 and I'm hooked up via RC cables. I tried adjusting the screen resolution through the menu and everything seems set up correctly.
  • Realness Sep 25, 2008
    I'm having the same problem... There is a huge horizontal line drifting upwards on my ps3. I can't play games or even watch movies anymore because the picture is so hard to see at times... Mine is only a 40 G and I've only had it for about 6 months... any suggestions???
  • Bat-Dude Sep 29, 2008
    Thanks, Mark!
    I called Radio Shack and they did not have an EMI Filter. I described the problem and your solution. Since they didn't have what I needed to test everything, they suggested I try a Ground Lift (3-prong to 2-prong adaptor) and that did the trick. It was $1.29 for a two-pack at Target if anyone else is interested.
Hi Folks,
What you are describing sounds like grounding or EMI issues with your AC power. If the lines or bars are soft and moving up the screen, typically there is an issue with the ground at the AC plug, or dirty AC from another device in the house (usually the refrigerator). Make sure the TV and PS 3 are on the same circuit (two wall outlets in the same room are usually NOT the same circuit). Check the outlets wiring to insure it's correct. You can do this with a Snap-It circuit tester (about $6.00). Many older buildings might not have the ground wiring properly installed or a previous owner/tenant wired something "wrong". You can get an EMI (electro-mechanical interference) filter at places like Radio Shack. You can put them on the PS 3 and the TV, but I would try one on the fridge first-make sure it can handle the refridgerator's power requirements.
GoodLuck,
MarkEditor
Posted on Sep 25, 2008
Screen has gone grey and has fine horizontal lines on entire screen. Blue screen is out.
Either the screen voltage to picture tube is more than normal, or the video processor IC has damaged. There is an other possibility that there is no voltage at the video output card, plugged on to the neck of the picture tube. Anyway, your set need a through checkup, and the work is somewhat skilled one. Just check this site. Soemtimes you might get some details about this fault. The fault is called vertical retrace lines. Thin horizontal lines all across the screen with an inch apart. One among the posts published in the following site have details about this fault.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1250 posts to different brand TVs now. Pull up older posts there.
Nov 23, 2012 | RCA F32672SB 32" TV
Snes red horizontal lines
When hooking a super Nintendo or an NES system or a sega genesis system to a digital tv you need av cables for it to work then instead of using an rf switch
Sep 30, 2012 | Nintendo Super NES Console
GameBoy Color's screen does not show horizontal
you need to get a game boy advance and it will still play those games
Jan 27, 2010 | Nintendo Game Boy Color Console
PS3 disc games look distorted, while other discs run fine.
oh i know this problem i have the same check the cable with the audio and video if i doesn't work send it to sony or just buy a new one
Oct 02, 2009 | Sony Playstation 3 (PS3) Console
Insert game disk and horizontal lines move fast on screen ???????
Sounds like your TV has multiple video inputs. Make sure the TV is set to the right channel or input. I know on ours if I hit the TV-input button on the tv remote I can change from inputs like s-video, video, cable etc and the Wii only displays properly on one of them.
Mar 28, 2009 | Nintendo Wii Console
System turns to red light standby in the middle of playing
you need to go to your setting and change your automatic shutoff timer. this will cause your system to turn off every 15 minutes no matter what you are doing...
Hope this helps... please rate...thanks
Jan 09, 2009 | Sony Playstation 3 (PS3) Console
Screen has has horizontal white lines and a loud buzz with ps3.
it could be that your rca cables are damaged, you can try using different ones, or it could be that you have a setting to use rca cables turned off in your settings of the ps3.
Nov 20, 2008 | Sony Playstation 3 (PS3) Console
Cannot play games
you may have 2 get a new ps3 i did
May 18, 2008 | Sony Playstation 3 (PS3) Console
Horizontal lines are appearing and moving acrosss the screen of my View Sonic E50C Monitor...
What is wrong with your monitor is that the Horizontal section is going faulty, the lines you are seeing are the Horizontal Retrace lines, usually invisable in a working unit. It is often a faulty capacitor(s) OR a Diode breaking down.. in the area of the Flyback Transformer. Probably time for a new one unless ya can fix it yaself.
Jun 11, 2007 | ViewSonic E50C 15" CRT Monitor
Sony Playstation 3 (PS3) Console Logo
151 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
