Question about Microsoft SQL Server Standard Edition for PC
Can't create a new connection of database SQL 2005 with MyEclipse ]
Dear all,
I can't create a new connection of database SQL 2005. I added sqljdbc 1.0 (jar). I declare :
Driver Name jdbc:sqlserver://localhost:1400;
url : jdbc:sqlserver://localhost:1400[;databaseName=]
Driver class: com.microsoft.sqlserver.jdbc.SQLServerDriver
When I test connect: error port of sql2005.
I can't know port number of sql 2005 and what to do to create a new connection of database SQL 2005 with MyEclipse
Help me!
Thanks a lot.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 163 Answers
Reinstall it.........
Posted on Jul 17, 2009
Creating a new database using an MDF file
An MDF file isn't a backup file isn't the main data file (or master data file depending on who you ask) hence the file extension MDF. You can attach the MDF to the database by right clicking on the databases folder in Enterprise Manager (SQL 2000) or Management Studio (SQL 2005) then selecting all tasks and then Attach Database.
When you do this you will get an error about the log file missing. This shouldn't matter as SQL Server will simply create a new log file for you.
This will only work if the SQL Server was stopped when you copied the MDF file from the old SQL Server. If you copied the file while the SQL Server was running this file probably will not attach either and you will need to get a valid backup of the database.
Download help tool for sql database - SQL Server Restore Toolbox.
http://www.sqlserver.restoretools.com/
You can read up more on SQL Server here.
http://www.filerepairforum.com/forum/microsoft/microsoft-aa/sql-server/498-creating-a-new-database-using-an-mdf-file?_=1416149856104/
Nov 16, 2014 | Microsoft SQL Server 2000 Standard Edition...
How to recover deleted Microsoft SQL server MDF files?
Recover and repair MDF files with simple and efficetive tool to repair and recover MDF files from corrupt and damaged SQL server, which tool support all king of SQL server version and Windows OS. Visit here: http://www.en.mdfrepair.net
Read blog post: http://exchangerecovery.hubpages.com/hub/How-to-perform-SQL-Database-Recovery Corrupt MDF File Repair Utility
Apr 17, 2014 | Computers & Internet
How can i fix the problem by error message 262,level 14,state 1,line 1 CREATE DATABASE permission denied in database 'master' in sql server 2005
RecoveryFix for SQL server database recovery utility is a very powerful utilty to fastly short out your all problems to MS SQL database. By using this application, user can simply repair SQL database. Read more: http://www.sqlrecovery.org/download.html
For more information read this post: http://diskdatarecovery.jimdo.com/2013/07/23/how-to-restore-lost-data-on-server-while-running-sql-server/
Jun 22, 2010 | Microsoft SQL Server 2005 Enterprise...
Need Help to backup SQL database in safe mode
kindly choose the option safe mode with networking and then try.
Sep 10, 2009 | Microsoft Computers & Internet
I am trying to connect to a SQL Server 2005 DB from Visual Studio
You must create an ODBC connection to your SQL database in the Windows Control Panel. Than you can call your ODBC connection via Visual Studio 2005. You can also create a DSN in Visual Studio 2005 and reference in that way. You will not be able to connect to an MDF but instead you have to connect to the SQL Server Service. Of course the username you use to connect must have access that will be created on the SQL server.
Apr 13, 2009 | Microsoft SQL Server 2005 Standard Edition
I installed DB2 in my laptop . then i go to all programs->DBCOPY1(default)-> command line tools -> command editor then write down query to create a table but i cant build it it is showing CREATE TABLE...
Before you create a table you need to:-
1. create a database
2. create a username and password or use the admin generated userid
3. connect to the database
you can then create a table and use the database
Please post if you do not know how to do this and i'll give you some links
Dec 05, 2008 | IBM DB2 Connect Enterprise Edition for PC,...
SQL Server 2000
An easy way to transfer objects (tables, user defined functions, stored procedures, etc.) is to use Enterprise Manager's "Generate SQL" feature. Use this process at your own risk. Doing it wrong could mess up your existing database.
1. In Enterprise Manager, right-click on the old database and choose "All Tasks" then "Generate SQL Script".
2. In the dialog that comes up, click "Show All" then select the checkboxes for "all stored procedures" and "all user defined functions". (You might also want to check some other boxes, depending on your exact situation.)
3. Click the "generate" button and save the script that it creates.
4. Run the script in the NEW database.
If you run the script in your OLD database, it may destroy your objects, and that would be very bad. Make sure you run the script in your NEW database. (While we're on this subject, it's a good time to mention that you should back up your database before you start this process, and you should make changes to a test system before migrating it to production.)
That should move your stored procedures and user defined functions over.
You can use a similar process to move tables, views, users, and other objects over as well.
Jan 17, 2008 | Computers & Internet
Error while trying to login to database - Error establishing sokcet.
this page says you need service pack 3:
http://www.myeclipseide.com/PNphpBB2+file-viewtopic-t-7813.html
and here is Microsoft's information
http://support.microsoft.com/kb/313178
Jan 03, 2008 | Microsoft SQL Server Standard Edition for...
You have a named instance installed with dynamic ports configured (default) named "local". In this case, the connection string would be localhost\local instead of local:1433. You could alternatively configure the service to use a fixed port and then connect using just localhost:. With dynamic ports, you would have to resolve the name of the service through SqlBrowser, which should be running
Nov 03, 2017 | Microsoft SQL Server Standard Edition for...
MyEclipse6.0.1 connection with sqlserver 2000
hi
Try with MS SqlServer 2005 JDBC Driver,
i had a similar problem with 2000 jdbc driver
Dec 03, 2007 | Microsoft SQL Server Standard Edition for...
Microsoft SQL Server Standard Edition for PC Logo
174 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
