I need refill instructions for a lexmark c920
I have a 6180 all in one fax, printer, scanner, copier. The scan bar goes to the bottom of the page area once I turn it on and stays there. It will not scan when prompt either by computer or manually. It was operating but once I moved it across the room it stopped. .
Posted on Jul 02, 2009
Instructions for refilling cartridges on a Lexmark Prevail Pro705 printer
Please note that Lexmark does not recommend the use of refilled, re-manufactured or clone cartridges. You might not get the print quality you expect from the ink that is specially formulated by Lexmark.
Feb 19, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
Refilled yellow toner but not printing yellow
Make sure no protective slips are still on the toner. Remove the printer from the power supply for 30 seconds and then re-plug it back in. If problem still occurs uninstall the drivers and software and re-install.
Please rate this answer! Thanks!
Jun 10, 2011 | Lexmark C920 Led Printer
How to reset Fuser Replacement 80 on C920 Lexmark - new fuser hasn't reset the warning
Go to Configuration by pressing the Check button the right arrow button while powering up the printer. Then choose reset fuser count. Hope this helps.
Jul 13, 2010 | Lexmark C920 Led Printer
Need to refill ink
a good tested refill kit is that
http://inkfilling.net/package-a-for-lexmark-cartridges.html
and the instruction here
http://inkfilling.net/lexmark/instructions-for-lexmark-cartridges.html
Apr 14, 2010 | Lexmark Z600 InkJet Printer
I have a c920 lexmark with a fault code 920.000. my guess is that the fuserisnt heating up... based on the fact that its not getting hot... im guessing the fuser lamp has blown.... is there any other...
Hi, Majorly this Error 920.X display for a cold fuser. Some 920.xx error codes may be cleared by turning the printer on and off.
In general, fuser errors require replacement of the fuser. Fuser errors can be from a cold fuser or an overheated fuser. In your case you need to replace the Fuser.
Feb 22, 2010 | Lexmark C920 Led Printer
Lexmark C920 color print is faded on bottom of page
Quite possible something happened to the printheads.....especially the Magenta one. Might have been 'bumped' out of alignment. They might just need to be wiped clean with a toner cloth. They are usually right above the toner cartridges. Have you tried a color alignment adjustment in Config mode?
Mar 12, 2017 | Lexmark C920 Led Printer
What is a 991.00 error
Assuming you are working on a Lexmark C920. The 991.00 service paper option relates to paper being jammed behind one of the paper drawers. Remove the paper drawers and check the connecters and also the housing for the tray its self.
Clear any errant paper and replace the drawers and all should be well.
Sep 23, 2009 | Lexmark C920 Led Printer
How to update s/n on Lexmark C920
go to lexmark site and download printer files
Aug 10, 2009 | Lexmark C920 Led Printer
126 people viewed this question
jasbo
jasbo
