Question about Sansui VRDVD5000 DVD Recorder/VCR
DVD records a black screen if tv is on standby.
Records fine when tv is on - defeats the object somewhat, I need it to record when I am out! If I am in I will watch the telly itself!
  • osulliun Sep 24, 2008
    DVD recorder is tuned ok. I can use the DVD recorder to watch normal TV normally. But thanks anyway.
    Sergeant:
  • 196 Answers
You have tuned the dvd recorders channels? dont forget a recorder dvd/hd/vcr is actually a tv set without its own screen and to record from channels you need to have its on board channels tuned in... what you have been probably doing is using a function on many recorders that records direct tv... what this means is it records the feed back signal through the scart lead of what ever channel your tv is tuned to at the time that is why no tv on = no signal
Posted on Sep 24, 2008
I cant get dvd recorder to record ext 2
Firstly, is the scart lead plugged in fully? Does it get the sound or nothing?
Is the recorder sitched to the correct input? It may be trying to pull a signal from the TV which may not be passing through the picture from the sky box.
Also, is the scart lead fully wired? Some only work one way so try spinning it round between the recorder and sky box.
Nov 24, 2011 | Philips DVDR70 DVD Recorder
Digital tv -analogue vcr records and time records and plays back only with the picture on. It will not record with picture on standby
Of course it won't record if the TV is in standby as there is no signal. If you wish to record TV programmes without having the TV switched on, you need a freeview or freesat box for your Video Recorder.
Hope this helps.
Nov 15, 2010 | Hitachi C21FL20F TV
My DVD player/recorder, records color but plays black and white
Check in the menu to see if there is a function where you can change from ntsc or pal,you need to be on pal
Oct 29, 2009 | Televison & Video
Linking DVD recorder to external set top box
The TEL0713-250 records fine from my Strong settop box, but only in 576 definition Higher definition sees either nothing or black and white. Check the outpur format of your STB
Apr 06, 2009 | Televison & Video
Vcr recorda blank when digital tv is put on standby.
this is because you are recording a direct connection (what is on the screen is recorded) that is an option with some equipment.. unfortunately this means if there is nothing on the screen well you get nothing..
You need to record from the machines own built in tuner dont use direct record.. a vcr/pvr/dvdr after all remember is like a tv without a screen that can record it has its own channels to do this
Sep 30, 2008 | Televison & Video
Panasonic dvd recorder dmr-ex75
Change the AV settings on the DVD or TV to be the same format. Feeding AV into an AV-S gives B&W
Sep 16, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
DVD-VR320 combo DVD player
I think its the dvd players internal settings that need to be adjusted. If there is a menu set the sky box to the connection it is plugged into. Although this might sound strange some units when you connect them up will play fine through that input but unless the settings of the player is adjusted iut will record a blank screen because its default setting for recording might not be either the connection method you are using or the input you are using. I hope this makes sense.
Aug 26, 2008 | Samsung DVD-VR320 DVD Recorder/VCR
DVD recording.
Sounds like the DVDR is recording from the digi-box through the TV, so when the TV is switched of or into standby the signal is lost, causing the recorder to pause.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
Feb 05, 2008 | Philips DVDR3380/05 DVD Recorder
Is there a solution?
I have a similar setup. Your problem is because you are selecting the recording on the digital tuner of the TV. When you do this you need to keep the TV on and canot switch channel.
You should make sure you use the digital tuner on the DMR-EX77 recorder and then you can use the TV as you like.
Oct 09, 2007 | Panasonic DMR-E80H DVD Recorder
Sansui VRDVD5000 DVD Recorder/VCR Logo
100 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
