Question about OKI B6200 Laser Printer
Okidata-B6200- The unit gets the same type of jam from all three tray. When it pulls paper the second page comes about a half inch out of cassette and unit errors out and say open cover A remover jam. Looked into history of errors on unit. The rpinter is getting 008-153 error in log. I have been unable to find error in service manual. It seems like unit has a problem with separation. Called Okidata tech suppt had me order feed rollers. Replaced feed rollers same issue.
  • 3 Answers
Check the reg sensor for dirt etc and paper setting is correct in the paper tray
Posted on Dec 12, 2008
Brother hl-2140
sounds like your seperation tyre is worn. this is the tyre/pad thats either on your paper cassette itself or the bottom of 3 rollers inside, replace this
Oct 11, 2013 | Office Equipment & Supplies
Paper is not being pulled from tray properly
Change your drum unit, it seems the drum is spinning good, let me know where the jams happen! In the fuser unit! in the cassette!
Dec 05, 2011 | Kyocera Copystar CS-1820 Black and White...
There is a paper jam...how do I unjam it
Hi dorothyhover,
Here's how you would clear paper jam from your Brother HL 1430:
1. Remove the paper cassette completely from the printer.
2.
Pull any jammed paper up and out of the printer.
3.
Open the front cover and remove the drum unit assembly.
4. Pull any jammed paper up and out of the printer.
Do not remove the drum unit assembly with additional force at this time if you cannot remove it easily. Instead, pull the edge of the jammed paper from the paper cassette.
5. Open the rear cover and pull the paper towards the back of the printer, the fuser may get dirty with toner powder and may result in toner scatter on the next printed page or pages. Print a few copies of the test page until the toner scatter on the printed pages clears.
6. Close the rear cover and install drum unit assembly, close the front cover.
Hope it helps.
Thank you for using Fixya.
Apr 28, 2011 | Brother HL 1430 Laser Printer
Paper will not feed but printer goes through it print cycle
Try this, without turning off your printer, unplug the power cable from the unit, after you have done that, on your printer, hold the Ok and cancel button to gether and while you are holding it down, plug the power cord back and keep holding the buttons for about 5 sec.
once the unit turns off, use the power button and turn it on. the unit would print and alignment sheet and this should fix the issue
So you need ten sets of a fifty page document for this mornings meeting. It's 8:30AM and your meeting is at 9:00AM. You begin with your project and the copier jams. You clear the jam but it keeps jamming! It's not pulling in the paper. Sure you can call the repair person, but you need the copies now! There's nothing you can do, or is there?
All office equipment that feeds paper has a component inside that pulls the paper out of the paper tray and into the machine. Most are made out of rubber and just like the tires on your car they wear out. When a roller is worn and dirty they will cause paper jams. The purpose of this article is to show you how you can clean or rejuvenate the rollers long enough for you to complete your job and have your repair person come out and fix it properly.
Alternative solutions
When your machine is jamming, first locate where the paper is jamming. Which paper tray? Is it tray 1 or tray 2? Also which size is jamming? On machines that have more than one paper tray you can switch paper trays and then you can skip cleaning the rollers. Make sure when you change cassettes that the copier registers the correct size. The machine will think it is a different size and it will jam. The sensors are set for a specific timing and it will know the difference in length from letter size and legal size. I also would try using the bypass tray or manual feed tray if so equipped. This will get you up and running quicker than cleaning the rollers.
Determining if the rollers are the problem:
If you need the specific tray to be functional we will get busy with the repair.
First make a single copy in the tray that is jamming. By doing this you are determining where the paper is jamming. If it is jamming in the exit for instance, you have another problem. If it is jamming in the center of the machine, again it is a different problem. But if it jams at the cassette or paper tray area the next step is removing the paper tray. Shine your flashlight into the paper feed area and see if there are any pieces of paper torn off inside or something blocking the paper path. Now that you have ruled out a blocked paper path, you can clean the feed roller(s).
Tools Required:
Flashlight, strong cotton towel (so it will not rip off in the machine), WD-40 or Rubber roller rejuvenator.
Note: Never use alcohol to clean rollers. It dries out the tread and the remaining tread will get ripped off and then it still will not feed. Use WD-40 it works great!
Cleaning the rollers:
Shine your flashlight into the paper feed area and locate the rubber rollers that feed the paper in. Grab your towel and saturate it with cleaning fluid. This can be WD-40 or your favorite roller rejuvenator. Start by cleaning the roller and spinning it all the way around not missing any of the surfaces of the roller. Then go over it again with the dry part of the towel. As I said there are many different types. Some have a set of three rollers. One Pre-feed roller, this pushes the paper into the other rollers. One feed roller and one separation roller. Others have a half moon style. These are harder to clean because they have a clutch system that keeps it at home position when not feeding.
WARNING: If you try and turn these to clean them you will damage the clutch mechanism! There are two ways you can clean these types. First you can actuate the clutch by pushing down on the solenoid or release lever. This sometimes can be hard to get to. You can also start the copy process and shut off the machine exactly when the feed roller engages. This takes some patience and practice but it is better than damaging the clutch. Once you get it where you can clean the roller repeat the procedure above.
Some alternatives to replacing feed rollers:
There is a material called feed roller tape. I have used it when I didn't have the right roller in my car stock. It works with some styles mainly half moon styles. Just peel off the adhesive and wrap it around the worn roller surface. They also have some that stretch over the old rollers. I have never used this but I have been told it will get you up and running. On old copiers or printers that you can no longer get parts for you can apply clear silicon on the feed surface and let it dry twenty four hours. It works but I am inclined to use the real thing. You can also use generic rollers manufactured for almost all equipment. I have mixed feeling about these because I have had to go back and change them again later. For the best repair I use genuine OEM feed rollers. They are still inexpensive and they will last you longer and you will have fewer headaches.
Feed Rollers
There are many types of rollers and feed systems. Here are some common feed rollers with their part numbers. Rollers will normally come in a maintenance kit but they may need to be replaced approximately half way through the maintenance kit cycle.
You can use this link as a help also.
Thanks for using fixya..
Nov 06, 2010 | Lexmark X2470 All-In-One InkJet Printer
Cassette not lifting making noises.
If the paper is in the paper tray correctly, you can try to remove the affected cassette. Look inside for a wade of paper blocking the paper present sensor. If so remove the jammed paper. If that is not the case, you will have to have the lift gear replaced in the paper feed unit. It is a Black half moon gear... It is not easy to replace..... Mostly, it is the top paper tay. If you can't afford to have the work done? I would not use the tray & change one of the other trays to the paper tray..... Good Luck
May 29, 2010 | Canon imageRUNNER 400S Copier
My HP Color Laserjet 3600n had a paper jam. The
Your best method of troubleshooting is the manual sensor test as this is a generic paper jam error.
on your sensor tests:
0 = off
1 = on
A = TOP OF PAGE SENSOR
B = PAPER LOOP SENSOR
C = N/A
D = FUSER PAPER SENSOR
E = DELIVERY-TRAY PAPER-FULL SENSOR
F = FUSER PRESSURE-RELEASE SENSOR
G = MEDIA SENSOR
H = N/A
I = MP TRAY SENSOR
J = CASSETTE SENSOR
K = DOOR OPEN DETECTION SWITCH
L = DEVELOPING ESTRANGEMENT SENSOR - CLR
M = DEVELOPING ESTRANGEMENT SENSOR - BLK
N = MP TRAY MEDIA POSITION SENSOR
A-F are paper path sensors - you can toggle them and watch if they change from 0 to 1. If they do, the problem is not in that area.
G can have states from 0-7 each one representing a different type of paper - shouldn't have anything to do with jamming.
hope this helps. probably a tiny piece of paper or toner somewhere. could also be a torsion spring out of position on a flag.
May 10, 2010 | HP Color LaserJet 3500 Printer
CHANGE PAPER TRAY DRAW
Do you often face technical problems for Okidata printers? Just contact our experts Okidata Customer Service at 1-866-877-0191 for best assistance. Free online tech services are available 24*7 at toll free number. For more info, visit: http://printertechnicalhelp.com/okidata-printer-technicalhelp.html
okidata printer 18668770191 customer service-aizo5avvrofwceza0ykjsgo4-1-0.jpg
May 03, 2010 | OKI B6300 Laser Printer
Oki b6200 paper jam
Have you checked to see if there is any paper jammed in the sensor, at the back in the 150-sheet feeder assembly, if not the paper could be stuck the 150-sheet assembly
Feb 26, 2009 | OKI B6200 Laser Printer
Help needed on ricoh ft 4015 copier
1-you need to determine if the two are part of the same problem
If the jamming occured first with no signs of copy quality issues then, it depends on where it's jamming. Locate the 1st jammed paper, the one that is furthest towards the exit. this stops all other paper after it. for example if there are papers in the fuser -by the drum and coming out if the tray the problem is most likely in the fuser area. Are the papers being crumbled? or just stop at that location?
2-the half dark copies could be a couple of things
a) the seperation unit is going bad and making the copies rise up against the drum
b)does the lamp that come on to scan the original stay on the whole lenght of the paper or does it turn off half way down the page? if yes the cable that connects to the lamp is probably broken and not making contact at the half way point as it is scanning.
Sep 17, 2008 | Office Equipment & Supplies
Paper Feed Not Automatically Switching to Multi-Purpose Tray
Sounds like the paper out sensor for the cassette is either broken or jammed. Pull out the cassette tip the machine on its back and you should see a black arm hanging down. This should be able to swing back and fourth freely. Unless it is missing or broken.
Jun 08, 2007 | Canon LaserClass 2050 Plain Paper Fax
OKI B6200 Laser Printer Logo
1,083 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
