Question about Creda W120VW Front Load Washer
Drum is sparking when spinning the clothes
When the machine goes into spin there is a banging noise and you can see sparks around the drum
  • Roberta Smith
    Roberta Smith May 11, 2010
    Sparks could indicate the motor is failing or the drive.
    Robert
  • Creda Master
  • 3,463 Answers
Sounds to me as though the main drum bearings have gone and the drum is catching the internal parts.
I f the drum is turned by hand and it feels rough or is noisy, then it is the main bearings.
Posted on Nov 30, 2008
Why does my front loader make a banging noise while spinning?
Ive checked thru the top and back cant notice anythin brohen but when i do spin tbe tub the banging noice is coming from in tbe drum and its pretty wobbley
Aug 28, 2015 | Washing Machines
My kenmore 417 wahser making too much noise, it looks like the inner tub hitting the outer plastic housing. How can I fix it?
Have you tried moving the clothes around in the drum to balance the drum BEFORE you was them? If that works, you have solved the problem! Most people forget that when cloth gets wet it gets heavy so leaving the clothes unevenly placed in the drum dry will make a real problem when they get wet!
Dec 26, 2012 | Kenmore Washing Machines
Hotpoint wf240 - jumps around when spinning laundry - the problem seems to be the drum turns too fast before the spin so the laundry is balled up before the spin - has anyone any ideas on how to fix...
Ensure that your machine is on a level surface with equal weight on the four legs. There are adjustable feet on these machines so as to balance the load on each support. These supports are adjustable by twisting them clockwise/anti-clockwise to get the correct balance.
Jan 05, 2011 | Hotpoint Washing Machines
Banging noise during spin cycle
weight not distabuted in washer move cloths around so its even
Feb 10, 2010 | Washing Machines
Washing machine makes a loud banging noise during cycle and when I check it the machine has changed position (unit is turned slightly sideways) How to correct
Hi
Does this happen every time???
If YES... then the machine is not balanced on the floor well.... the 4 stands on which the machine rests have adjustable screws... You will need to fasten or loosen the nuts that will adjust the height of the legs on which the machine rests.... all the 4 legs need to be firmly on the floor .... If one is too high then the machine rocks on its side...
If NO.. only sometimes...
You are overloading the machine with heavy clothes... distribute your wash clothes by weight...
Regards
Berry
Feb 04, 2010 | Washing Machines
GE WSXH208A makes a lound noise during the spin
check to see if the washer is balanced (cloths are evenly placed in drum) if it sounds like banging noise
Jan 20, 2010 | Washing Machines
Loud banging noise when machine goes into spin mode. sounds like it is banging on the side. Please help !
Usually this is an out-of-balance condition caused by too much weight on one side of the tub, move the clothes around and try again.
Apr 26, 2009 | Washing Machines
Banging noise
You may have had a foreign object slip under a loose drum baffle. Manually rotate the drum to locate wwhich baffle it is in.
Apr 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Spin cycle noise problems
It is likely that you have an unbalanced load. Try spinning the machine with only water in it. If there are no noises now, you will need to re-distribute the load. We clothes are heavy!!
Jan 13, 2008 | Kenmore 24032\24036 Top Load Washer
Creda W120VW Front Load Washer Logo
280 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
sonic boom...
sonic boom...
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
