Question about Emerson MT-1564R Car Monitor
Tearing at top of MT-1564R screen
I have a PC213XS color micro video camera providing video feed to an MT-1564R monitor, and the image regularly suffers from "tearing" (distortion and interference) at the top of the monitor screen. Is there anything I can do to fix this problem? If not, is there any other LCD monitor whose power/video connection is compatible with the MT-1564R's? The power cable for the monitor has been hidden within the body of the car itself, so I'd prefer not to have to replace all the cords.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 108 Answers
There is a possibility that you have a weak video signal. You can boost this with a small video amplifier. This is most commonly seen in set-ups that have multiple monitors or when you have long video cable runs like you would see in an RV back-up camera system.
Posted on Sep 28, 2008
Fuji Finepix S5700 digital camera. LCD green-pink
try to playback previous images ..If screen looks good on playback and or main menu..Camera likely has problem with CCD imager and camer digital processor board.If camera also looks bad on playback and menu..its possible the LCD IS BAD..easy test is to hook up camera on a monitor or computer and see what picture on camera mode looks like..If it also looks bad on a different monitor..Then CCD imager could be bad..If playback and camera mode lokk bad on monitor ..then you have a video process board problem ...please let me know
Dec 18, 2007 | Fuji FinePix S5700 Digital Camera
Lens screen stuck open and no image on LCD view screen.
It is jamming, the only really fix is to have it repaired, that costs a lot and it is sometimes better to just replace the camera.
Mar 15, 2014 | Sony Video Cameras
Monitor screen changes from regular color to a green tinted screen?
Is the cable connected securely? You may need to check your video card also. You may be able to disconnect the cable and get a red, green, blue icon on the screen. If that appears normal then there is nothing wrong with the monitor itself, it may be the cord or the video card.
Hope this helps!
May 31, 2008 | Dell 1503FP 15" LCD Monitor
CTX P772 17" LCD Monitor Problem
This is caused by sending a video signal to the screen at a refresh rate higher than 60hz. A LCD Doesn't refresh the image by scanning from top to bottom like a traditional CRT or picture tube. They are hard set to 60hz and can not understand anything else. Setting it to anything else will cause it to not display a video signal, picture tearing (little blocks with horizontal movement), Offset video or convergents issues (colors appear offset giving it the 3d movie look with out glasses on)
To fix it you need to go into your operating systems display settings and pick out a LCD monitor with a refresh rate of 60hz
Hope that helps
May 12, 2008 | CTX P772 17" LCD Monitor
Color unbalanced, uneven across the frame
Things to try. I don't promise solutions. Check your Monitor. Reading the description lead me to think of a tube display rather than a chip. Otherwise order a head cleaning tape and give it a rotation.
Mar 09, 2008 | Panasonic AG-DVC200 DV Digital Camcorder
What are the effects of Adobe RGB?
Adobe RGB enables more vivid color reproduction, for Adobe RGB is capable of more color space than sRGB. It offers more flexibility than sRGB on image processing and image retouching. Please note, however, a normal PC monitor cannot realize the color reproduction effect, for the available color range of the monitor is restricted by its specification. Further, an image with Adobe RGB ICC profile may be reproduced in poor color depth unless color management is provided in advance. Meanwhile, there may be cases that the Adobe RGB effect is realized in printing out, as some colors can be reproduced by a printer.
Sep 15, 2005 | Konica Minolta DiMAGE A200 Digital Camera
My pictures display poor image quality on the screen or when you print them out.
PhotoPC 800 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Poor image quality
hotoPC 650 captures images in 24-bit color (16.7 million colors). Your pictures will not display maximum image quality if your monitor or computer's video controller doesn't support this color depth. Additionally, if your pictures are taken in 1154 x 864 mode, try increasing your video resolution above 640 x 480. You may need to upgrade your system to achieve the best possible image quality. If your pictures look better on the screen than when you print them out, you may need to upgrade your printer. An EPSON Stylus ink jet printer, for example, provides excellent image quality. If you used drag and drop to insert your pictures, they may appear grainy. Try importing them into your documents instead.
Sep 13, 2005 | Epson PhotoPC 650 Digital Camera
Emerson MT-1564R Car Monitor Logo
Top Emerson Car Audio & Video Experts
xxxxxx xxx
Are you an Emerson Car Audio and Video Expert? Answer questions, earn points and help others
